What did you do with your Chinese baby digger today?
   / What did you do with your Chinese baby digger today? #551
didnt take front wheel off yet ---- too much **** has to come apart and no time right now to do it. I left the track a little loose and so far if I turn careful its still on.
I still need sharper edges on the bucket to cut the hard dirt thats like concrete.
   / What did you do with your Chinese baby digger today? #552
Well, yours will be the first pix of the idler wheel bearing(s) when/if you post it, Sonny.
   / What did you do with your Chinese baby digger today? #553
When I get done with this tile fixin I will take it apart,-- UNLESS it get so bad the track wont stay on at all.
I have pushed almost 300 feet of backfill dirt over the tile line and so far the track has stayed on. I dont have it as tight as it was when I got the digger last year,---- may have been too tight at that time. It looked o.k. but could have been a tad too much so I just took the sag out and quit at that point. Took a couple tries then it stayed straight now so we try that and see how goes. So far it hasnt fallen off.
I still need to do something to sharpen more of the bucket. I really want to make my own bucket that will cut hard dirt and not pull as hard as the one that came on it.
I been using the finger as a ripper to loosen the top 18" of hard dirt and that does help a lot.
For its size it does great --- we all know they are NOT a 450 Deere but didnt cost what a 450 does either !!!! Its either this or a spade and I am not able to spade stuff anymore!!
  • Good Post
Reactions: 1hp
   / What did you do with your Chinese baby digger today? #554
I just saw a photo of the idler wheel removed from its bracket, on a public FB group. Posting it here to share.
It seems to be 2 ball bearings, and the shaft is secured with roll pins. Looks like easy fix with off-the-shelf parts. Even it you let the bearings fall apart and damage the shaft, replacing the shaft should not be hard.
If your idler wheel wobbles, don't wait too long.
   / What did you do with your Chinese baby digger today? #555
Idler wheel has wobbled since day one out of the shipping container new!
Anyway he now has a brother.
   / What did you do with your Chinese baby digger today? #556
Preventative maintenance, this bolt continues to get loose, I tightened it, it came loose, I blue loctited it, it came loose, today, it got red loctite. This is the drive motor(slew)that rotates the housing.
   / What did you do with your Chinese baby digger today? #557
   / What did you do with your Chinese baby digger today? #559
Do you find out when it falls out? Or are you checking it frequently?
Looks pretty accessible. Is your ring gear guard only partial coverage? Mine is like that.
   / What did you do with your Chinese baby digger today? #560
Can the head be drilled and then safety wire it to something nearby? It can't back out if it can't turn.
2010 Ford Taurus Sedan (A50324)
2010 Ford Taurus...
2019 INTERNATIONAL 4300 26FT CDL REQUIRED BOX TRUCK (A51222)
2019 INTERNATIONAL...
2006 MACK CV (GRANITE) BOB TAIL KILL TRUCK (A50854)
2006 MACK CV...
Toro Workman Cart (A50322)
Toro Workman Cart...
2021 Doosan DX350LC-5 Hydraulic Excavator (A49346)
2021 Doosan...
2022 CATERPILLAR 335 EXCAVATOR (A51242)
2022 CATERPILLAR...
