What did you do with your Chinese baby digger today?
   / What did you do with your Chinese baby digger today? #551
didnt take front wheel off yet ---- too much **** has to come apart and no time right now to do it. I left the track a little loose and so far if I turn careful its still on.
I still need sharper edges on the bucket to cut the hard dirt thats like concrete.
   / What did you do with your Chinese baby digger today? #552
Well, yours will be the first pix of the idler wheel bearing(s) when/if you post it, Sonny.
   / What did you do with your Chinese baby digger today? #553
When I get done with this tile fixin I will take it apart,-- UNLESS it get so bad the track wont stay on at all.
I have pushed almost 300 feet of backfill dirt over the tile line and so far the track has stayed on. I dont have it as tight as it was when I got the digger last year,---- may have been too tight at that time. It looked o.k. but could have been a tad too much so I just took the sag out and quit at that point. Took a couple tries then it stayed straight now so we try that and see how goes. So far it hasnt fallen off.
I still need to do something to sharpen more of the bucket. I really want to make my own bucket that will cut hard dirt and not pull as hard as the one that came on it.
I been using the finger as a ripper to loosen the top 18" of hard dirt and that does help a lot.
For its size it does great --- we all know they are NOT a 450 Deere but didnt cost what a 450 does either !!!! Its either this or a spade and I am not able to spade stuff anymore!!
  • Good Post
Reactions: 1hp
   / What did you do with your Chinese baby digger today? #554
I just saw a photo of the idler wheel removed from its bracket, on a public FB group. Posting it here to share.
It seems to be 2 ball bearings, and the shaft is secured with roll pins. Looks like easy fix with off-the-shelf parts. Even it you let the bearings fall apart and damage the shaft, replacing the shaft should not be hard.
If your idler wheel wobbles, don't wait too long.
   / What did you do with your Chinese baby digger today? #555
Idler wheel has wobbled since day one out of the shipping container new!
Anyway he now has a brother.
   / What did you do with your Chinese baby digger today? #556
Preventative maintenance, this bolt continues to get loose, I tightened it, it came loose, I blue loctited it, it came loose, today, it got red loctite. This is the drive motor(slew)that rotates the housing.
   / What did you do with your Chinese baby digger today? #557
   / What did you do with your Chinese baby digger today? #559
Do you find out when it falls out? Or are you checking it frequently?
Looks pretty accessible. Is your ring gear guard only partial coverage? Mine is like that.
   / What did you do with your Chinese baby digger today? #560
Can the head be drilled and then safety wire it to something nearby? It can't back out if it can't turn.
Bryant 650AN048-E A/C Unit (A52377)
Bryant 650AN048-E...
2012 SULLIVAN PALATEK AIR COMPRESSOR (A52576)
2012 SULLIVAN...
2023 John Deere HD40F Draper Head (A53342)
2023 John Deere...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A52377)
2012 Vermeer...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
1987 LANDALL 48ft Hydraulic Slide Axle T/A Drop Deck Trailer (A51692)
1987 LANDALL 48ft...
