rScotty
Super Member
- Joined
- Apr 21, 2001
- Messages
- 9,964
- Location
- Rural mountains - Colorado
- Tractor
- Kubota M59, JD530, JD310SG. Restoring Yanmar YM165D
It will work, but weighting the front in order to lift more at the back sure can put a lot of bending stress on all the connecting castings of the tractor - the bellhousing and transmission cases especially.Back to the remedy of a Electric Winch. 5000 Lbs. At HF. 179$ Then only a couple cheap pullies would be needed HF. 8$ stainless steel. If the 3Pt. is rated 1600 Lbs. this is a easy and simple solution. Worst case front end weight added! or load the FEL bucket.
If you are going to do that, it makes sense to check that it has a good full length loader subframe running from front to rear.
rScotty
