pmsmechanic
Elite Member
- Joined
- Dec 6, 2013
- Messages
- 4,436
- Location
- Southern Alberta, Canada
- Tractor
- 4410 and F-935 John Deere, MF 245
I've used paper clips as well. The ones with scored edges work better than the totally smooth type. I tried welding a water tank. It worked but then went and cracked in a different spot with the next load of water. I'm thinking the sun degraded the plastic.I have a 200w amazon kit Amazon.com
Repaired a large in ground valve box that had been split and discarded when run over by a truck. Worked good. Looks like getting nice finished results might take some serious practice, sanding, painting, etc.
I used paperclips for stitches. Simply push them into the material across the break with the hot iron then weld over them.
My plan is to repair a leak in a 4k gallon water tank.
