Welding plastic
/ Welding plastic #1
blacktruck
Gold Member
Texarkana, TX
Cub cadet 2450, JD 420, Ford LGT18H
Recently I have developed a need to weld a broken fender on my tractor. I did a search and ran across some old threads on this. I'll make a guess and think that most likely the technology to even do that has changed a bit since those were posted. Does anyone on here have any experience with a commercially available kit? My SIL collected most of the pieces after backing the tractor into the wall while cleaning out the shed but judging by the pieces in hand, I am thinking he didn't get them all. Any recommendations for filler material to use?
/ Welding plastic #2
I have a bunch of plastic welding rods. My kit is a Steinel but there are lessor cost kits. Harbor Freight even has one. The latest plastic repair kit out there is the one that looks like a 2 tipped solder iron. It uses little staple looking wires. Pull the trigger with the staple installed and it turns light red. Simply push it into the 2 pieces. Repeat as needed. I've had good luck with it. Vids on line too. The regular plastic welding rods come in different breeds like HDPE, PVC, LDPE etc. You need to know what you're welding to be successful. The staples don't care.
/ Welding plastic #4
I like to repair with the wires as noted above. It provides good stability and strength.
I will then melt the plastic in the area by lightly dragging one of the “hot” wires over the crack to fill it in once stabilized
/ Welding plastic #5
I have a 200w amazon kit Amazon.com
Repaired a large in ground valve box that had been split and discarded when run over by a truck. Worked good. Looks like getting nice finished results might take some serious practice, sanding, painting, etc.
I used paperclips for stitches. Simply push them into the material across the break with the hot iron then weld over them.
My plan is to repair a leak in a 4k gallon water tank.
/ Welding plastic
All good responses gents.
Much appreciated. I will look for a kit next time I go to HF. I have pretty good luck with everything I have bought there and it's handy to get to. After he damaged the tractor, I tried to replace the entire unit. Two problems with that. Price and availability. It was pretty high priced but I would have bought it anyway but the big problem there were none in the US or overseas to be had so it looks like I am going to learn plastic welding. Not that I am happy about the damage to my tractor, I am looking forward to repairing something like that. What is the typical material used in most small tractor fenders? I am sure there will be pieces missing so filler will be necessary.
/ Welding plastic #7
I have a cracked fender extension on my M9 open station (bought it that way) that I need to fix at some point but I'll use fiberglass mat and resin on the underside and sand and paint the now cracked area.
Works good for me. In fact that is how I secured the OEM Riv nuts that got loose in the roof of my other M9 and strengthened the stress cracks as well and the roof is blow molded plastic.
/ Welding plastic #8
You'd be amazed by the number of things made from the same plastic as Tupperware. Try it first in an inconspicuous spot of course.
/ Welding plastic #9
I've done a lot of repairs on ATV plastic. Most of it is High density poly ethylene. HDPE. LDPE rods work fine on them as well. My tractor fender acts like ABS when I try to melt the grille cracks. I haven't figured it out. Fiber glass mat and resin didn't hold, several plastic rods didn't stick but I was able to do a nice repair with the staples. One other thing on the staples. You can buy them and just use a lineman pliers and hold the staple over a candle to heat it up. You really don't need the electric gun. You can even make your own staples out of thin stainless wire for custom repairs.
/ Welding plastic #10
I've used the sub $20 soldering iron plastic welder from HFT and it works fine, do NOT press as the copper tip will break at the 6mm threads going into the iron when hot... but I've successfully ran a die down it and it lived again... it comes with some stainless screen material which you can bury in the plastic and help out.
/ Welding plastic
Yea. I have a little experimenting to do for sure. I have a lot of experience working with composite materials that all accept the addition of some sort of an adhesive and filler material. I would have given that a go but was told as mentioned above that most adhesives won't stick to it. I am looking forward to trying this when I get home.
/ Welding plastic #12
The SS screen sounds like a great idea. Adding it to my plastic welding box.
/ Welding plastic #13
As far as filler, assuming I don't know what the parent material is, I try and remove enough of it from the part (from an unseen location) to use as the filler. Will not only be a material match but color as well.
/ Welding plastic #14
When I 1st got interested I visited a motorcycle junk yard. They gladly let me pick up pieces of assorted colored plastics. I still have some. There is a burn test as well to determine types but it's not that accurate. A couple are easy to determine but many others burn similar.
/ Welding plastic #15
I've been using the Polyvance 5700HT welder, which is an iron type, for awhile and it is a welder. You preheat and melt the base plastic then melt the right filler plastic into the SMALL grove between the two pieces, just like stick welding. Do the repair on the back side. I like to add the SS screen to the back when I'm done and melt it into the repair with the iron and smooth out by holding the iron just above the join and later the screen until all the plastic has the same color before I let it cool. If you can weld metal you can do plastic. Just slightly different technique.
/ Welding plastic #16
Squirrels ate thru a corner 'bout the size of a dime thru the fuel tank on the SIL Craftsman snowblower and there was none available. I used a strip of plastic cut off the rim of a 5 gallon bucket for filler. While not easy it was doable, the melted plastic has absolutely no surface tension, get it one degree past the melting point and it would fall thru.
/ Welding plastic
I will definitely have a learning curve to get past. With more and more of the bodywork and accessories being made of plastic anymore, it seems like the information about the content or type of plastic used should be easier to find. I pride myself on not scuffing or banging up my equipment and a one project deal at my SIL's garage left me with a fairly gaping hole in a fender. I'm certain that I am not the only one to have this happen. I am retiring soon and it is time to learn about this. I am certain that I can make it stick together, I am mostly concerned about finding filler material for the missing pieces. I probably have an area of 2"X3" missing. Fortunately it is in a flat area. I'm not concerned about a color match, just compatibility. I appreciate all the replies. Keep them up. I will be getting into welding metal also when I get back so there will be questions.
/ Welding plastic #18
Might also read up on some of the new adhesives out there. Many plastic welding applications were killed off due to super advanced adhesives for the auto industry.
/ Welding plastic #20
A lot of "plastic" fenders on tractors have a fiberglass or some other fiber component to them. Very rarely are they a plastic that could be welded back together. I was working for New holland when they introduced Plastic fuel tanks on their Genesis tractors and some of them were getting holes in the tops from something rubbing or puncturing them (can't remember what exactly) but they gave us welding instructions which satisfactorily repaired the tanks and stored the structure. But they were a much different material than the current plastics you would find on a tractor fender. I'd suggest an epoxy or fiberglass repair first, or contact the company to find out what type of plastic it is and if it is indeed repairable. I'd bypass the local dealer if they start with a sales pitch on a new fender. This happens a good bit and they know how to fix stuff at the mfgr level I'm sure.
2003 MAC TRAILERS 45' WALKING BOTTOM TRAILER (A60430)
2003 MAC TRAILERS...
UNUSED ATS POWER ATS-PC90 HEAVY DUTY PLATE COMPACT (A64281)
UNUSED ATS POWER...
2016 Manitou MHT10230 50,000lb. 4x4 Rough Terrain Telehandler (A60352)
2016 Manitou...
PALLET OF EXERCISE STEPPERS (A64281)
PALLET OF EXERCISE...
(2) UNUSED 12-16.5 TIRES W/ 6 LUG RIMS (A64280)
(2) UNUSED 12-16.5...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A65563)
IMPORTANT PLEASE...
