Flail Mower Let's talk flail mowers
/ Let's talk flail mowers #8,081
I could not tighten the belts as much as I wanted to, because raising the gearbox too high to tighten the belts caused it to strike something. The belts were loose but not loose enough to fall off the pulleys.
You could have multiple issues going on here.... low belt tension for sure. If the belt tension seems too low, don't mow with it until you get things figured out.... you'll just smoke belts.
The belts are tensioned by raising the gear box (and I assume an outboard carrier bearing) to raise the driver sheave? Could you be imparting a weird twist into the gearbox by not raising them equally? I'd disconnect the pto from the tractor and turn by hand to diagnose further.
BTW- the NAPA A40 belt specs are published online: wrap molded/polyester cord made by Gates. This is not a robust drive. If you bought the mower new the manufacturer should be helping you through this or take it back.
/ Let's talk flail mowers #8,082
What happened after that? Did it eventually get normal?
I tried increasing the tension of the belts, but the gearbox had a loud striking noise and I reduced the tension just enough to remove the striking noise. The belts still felt too loose. I couldn't increase the tension anymore without creating the striking noise.
The belts broke midway through my 3rd mow and I had about 4 acres left. Luckily I ordered a spare set of China belts with the mower so I put them on to finish up. No issues the rest of the job. I haven't had to mow since. The Goodyear belts are sitting on my workbench for next year.
I cant think of what could be hitting. When you adjust the belt tension, are you loosening the bolts at the gearbox too?
/ Let's talk flail mowers #8,083
I think I’d be tempted to design a idler/tensioner pulley to make it easier to maintain the correct belt tension.
/ Let's talk flail mowers #8,084
I have a bestco flail HD 7 ft. I burnt up my first set. Salesperson said every new flail operator burns up the first set because they cut too short allowing the hammers to engage the earth...2nd set, I started cutting a couple inches taller with the front of the mower higher than the rear for better feed. And I put belt dressing on liberally. So far so good. There is tension instruction inside the cover, 3/4" deflection I believe. Check your manual.
I did follow the manual as far as leveling the mower with the top pin. I actually glued a level onto the side of the mower. It is totally level front-to-back.
There are four bolts which hold the gearbox onto the mower, and a tension bolt a few inches right of the back left side. I raised the gearbox using the tension bolt, but when it was set to where the belts felt like they had the right tension (I didn't have a tension measuring device), there was a striking sound in the gearbox when the PTO was activated, as my video shows. I reduced the tension bolt slowly until the sound went away, but then the belts seemed too loose. I tightened the 4 bolts holding the gearbox to the mower before operating it.
I set the back roller gently (not crushingly) on the ground using the 3-point. There are no rocks, stumps, or uneven ground. I have not played with the flail height adjustment, since I just need a mow, and any height is better than not mowing at all.
/ Let's talk flail mowers #8,085
One thing I've considered, is that the striking sound could be being caused by a misalignment which is possible to correct by adjusting the position of the gearbox before the 4 retainer bolts are tightened, while leaving the tension bolt extended to tighten the belts.
Oh, and I'm using the highest quality V-Belts with Kevlar/Aramid, and they are still burning up.
/ Let's talk flail mowers #8,087
Any belt will slip and burn if the tension starts out low.
If you can resolve the tension issue and the stock belts still slip, installing raw edge belts will be a noticeable improvement without reworking your mower... they really hook up.
/ Let's talk flail mowers #8,088
Not saying you are doing this because it sounds like you have a belt tension issue? But mowing too fast in too thick material will cause the belts to slip. Spray on belt dressing helps. Shorter belts may be exactly what you need. How much deflection is there in the belt when it is tightened ?
/ Let's talk flail mowers #8,089
Yes, I release the 4 bolts holding the gearbox before adjusting the tension bolt, and then tighten them back up before operating the mower.
As I said in another message, maybe adjusting the position of the gearbox before tightening the 4 bolts might be able to stop the striking.
/ Let's talk flail mowers #8,090
I agree that this is a belt tension issue.
When I increase the belt tension so that it's tight, I get grinding noises in the gearbox which I am not able to accept.
As per the manual, I release the 4 bolts holding the gearbox to the mower, adjust the tension bolt, and then tighten the 4 bolts back.
I am going to try to adjust the position of the gearbox to avoid the grinding noises, if possible, while keeping the belts tight with the tension bolt. There are 4 bolts which hold the gearbox to the mower, and there might be some wiggle room.
I am not mowing too close or forcefully into the ground, nor am I mowing too fast.
/ Let's talk flail mowers #8,091
And by the way, the drivetrain is nearly horizontal, just as the mower is perfectly level. So there can't be much stress in the U-joints.
The belt tension is the only explanation.
/ Let's talk flail mowers #8,092
Couple of photos showing how I had to add shims on my mower, in order to get the two pulleys line up properly with each other.
I doubt it left the factory with misalignment like that - who knows what the previous owner did with it during the 20 - 30 years he had it?
It was an easy fix.
/ Let's talk flail mowers #8,093
Sorry to rain on an interesting discussion (I've only been through 1/10 of it!!!).
I am having a frustrating problem with my Betstco flail mower belts repeatedly failing.
(I hope links to pertinent outside images and videos is acceptable -- no ads.)
My email to Betstco (I've heard about Keith but I don't know if he's there anymore):
I am having frequent belt breakages with my EF125 flail mower.
It happened first with the OEM belts last week, and again with the new belts I got today, which were A38/4L400 (1/2" by 40" outer circumference).
The video below is with the PTO at its slowest speed (not 540 RPM) and the flail mower raised off the ground.
Something was striking the gear box when it was raised too high to increase the belt tension.
I loosened the tension bolt until that striking sound went away, but then the belts felt loose and very flabby.
I used them anyway to mow with, until one of them burned out about 25 minutes into mowing:
I am next going to try A37 ( 1/2" x 39" OC).
I do not know if am overloading it (EF125). It seems to mow okay but there is a slight smell of burning rubber until the belt breaks. I have removed all grease residue from the pulleys using a rag and a strong cleaner like acetone.
I could try raising the flail mower higher off the ground. Right now the roller sits gently on the ground and a level shows that the mower is balanced front-to-back by the adjustment of the top pin. There are no obstructions except thick grass, and the ground is mostly flat.
Have the same mower and experience with the belts, my original set didn't last but a few days even after adjusting each time before using. Hit up napa for a set of Kevlar belts and have not touched them in almost 3 years since. I did a lot of power transmission work back in the day and never experienced belts melting and smelling like they did, total garbage.
/ Let's talk flail mowers #8,094
I have ordered 38" and 39" outer circumference Kevlar belts.
Apparently the U-Joint on the implement side is striking the top of the gearbox when it is raised up too high.
With the original nut still included, it is tighter at the tension bolt's tightest position, but still gives too much:
If I remove the nut and increase the tension all the way, it has much less give:
Apparently this is a problem with this model, since a 40" outer circumference belt requires raising the gearbox so high that it is being struck by the implement-side U-Joint.
I checked the gearbox and there were no metal filings, dark oil, or damage visible through the fill hole with a flashlight, and the gear oil level was good. There is no sound when the gearbox is lowered by easing the tension bolt, but then the belts are too loose and burn up.
I am going to try the 39" and 38" belts, but they may be hard to install without removing the pulleys, since the 40" belt already requires a screwdriver to guide it onto the pulleys when the tension bolt is totally retracted.
/ Let's talk flail mowers #8,095
I have been using Kevlar belts. The nearest NAPA store is 50 miles away, so I've been using Tractor Supply and O'Reilly for belts.
Any belt, even Kevlar, will burn up if not properly tensioned.
I'll try shorter belts which don't require raising the gearbox so high that it gets struck by the U-Joint.
/ Let's talk flail mowers #8,096
Here are more videos showing the U-Joint hitting the top of the gearbox:
A shorter belt than the A38 (1/2" x 40" OC) would seem to be necessary.
Betstco was on the phone with me for almost an hour today and was thinking of sending me a new gearbox, but I don't think that's necessary. The U-Joint strikes the gearbox when it's raised too high, so shorter belts to not require raising it too high would seem to be in order.
/ Let's talk flail mowers #8,097
Is it clear to anyone what the striking noise is?
It seems to be the U-Joint on the implement side striking the gearbox when the gearbox is raised too high to increase the belt tension. If the belt tension is lowered to get rid of the noise, the belts are not tensioned enough and will burn up. I plan to use smaller belts to avoid having to raise the gearbox that high and causing the U-Joint to strike.
/ Let's talk flail mowers #8,098
See my earlier post, where I hand-tested it and you can see the deflection. I still think it was too loose even in the best case. Shorter belts is indeed the plan.
I am not mowing fast -- I am going very slow (Kubota turtle speed or less). The belts were slipping because they did not have enough tension, even for the lightest load.
/ Let's talk flail mowers #8,099
One problem is that 38" and 39" outer circumference belts are much harder to obtain than 40" OC belts. I've had two orders for them canceled because of lack of supplies.
/ Let's talk flail mowers #8,100
From the design of the mower, it looks like the deck that the gearbox is mounted to raises with the long adjuster bolt. Loosen the deck bolts and as the adjuster bolt gets screwed in, the deck raises which raises the pulley, tightening the belt. Is this correct?
2021 Kubota SVL75-2 Track Loader (A63689)
2021 Kubota...
2008 MACK GRANITE KILL TRUCK AND TRAILER (A65643)
2008 MACK GRANITE...
2000 Yale GLC030A 2,500lb Propane Foklift (A61572)
2000 Yale GLC030A...
2003 Keystone Cougar Model 286 Camper / 5th Wheel (A66285)
2003 Keystone...
1999 Coachman Catalina RV/Camper VIN # 3FCMF53S2XJA29020 (A65563)
1999 Coachman...
2016 PETEBILT 579 69" SLEEPER (A62613)
2016 PETEBILT 579...
