Buying Advice Questions about potential purchase, not sure where to start
/ Questions about potential purchase, not sure where to start #61
...but does rust matter?
I wouldn't even look at a CUT that's been stored outdoors. Not because of rust, but because the tires, seat, dash cluster, and every bit of plastic on the thing is going to be trashed.
So, that leaves you with buying tractors from prior owners who were not idiots, and actually kept their CUT's in a garage or barn, where they belong. Rust should be a zero issue, I've owned 60 year old tractors with no rust anywhere to be found, and even sometimes original tires (if kept out of the sun).
Note I said "CUT", not "tractor", to keep the big boys from jumping onto my statement. Guys like Hay Dude have big machines that probably do end up sitting outdoors a lot during the season, as they're awful big to haul home and put indoors every night. Different type of machine, different situation.
You are going to love having a tractor for your property. It sounds like this is all very new to you. You are getting a lot of good information on this thread, but you need to really need to see, touch and try to get a better understanding.
There are three dealerships within 20 miles of you. Visit each of them. Tell them about your property, and your plans for using the tractor. Tell them you are a newbie, and ask them to educate you about compact and sub-compact tractors - their features and capabilities. Ask them to give you a demonstration, and ask them to let you operate one (the tractor and the loader). Get some literature.
Do that at each dealership. You will learn more with each visit. That is just step 1. Go back again, and see if any of them are "speaking" to you (ergonomics, price, features, zen.,..). If you make several visits, you will learn more each time.
You'll keep getting advice here, but you really need to get some first hand experience.
Thank you, I absolutely agree at this point. This is the logical first step, and I already asked my dad to come with me when he's back in town.
Also, thank you everyone so much for the insight on HST. I watched the video and now get exactly why I need this.
/ Questions about potential purchase, not sure where to start #63
Uhmmm, just about every tractor at the dealership is stored outdoors.
Yep, over the long term, it's better to keep them under shelter, but lots aren't and still function.
/ Questions about potential purchase, not sure where to start #64
Yeah, but we're talking weeks or months, versus years.
My life-long hobby is boating, and I've seen first hand how sun eats more materials than salt and water ever will. You want to ruin any rubber or plastic? Leave it out in the sun for a few years.
My tractor indeed has some sun damage to the cowling and dash, probably having sat out for 10-12 weeks prior to purchase. If I had noticed how bad it was, I'd have waited for them to order a new one, as I didn't get any special deal for taking from stock.
/ Questions about potential purchase, not sure where to start #65
although the list of what to look for (leaks, cracked hoses, smoke color, weird sounding / inconsistent engine sounds) but does rust matter?
I might also suggest this is more of a baseline of a set of questions to ask if you do have someone look over the tractor if you're not comfortable judging for yourself. I've often found asking some of the baseline questions gets you a LOT more useful information than just "is it good". You don't always have to know how to do everything but knowing enough to ask whether someone else does is frequently useful in judging if they're bull****ting you or not :)
As to rust.. yes but also no but mostly yes. Some surface rust in an of itself isn't really a huge issue IMHO. But it would be a red flag that the tractor possibly hadn't been well stored or taken care of. Also even used I'd steer you towards newer machines which shouldn't normally have a lot of rust unless they were somehow used hard. If there was much rust anywhere other than wear and weather points (a little on the underside of the frame or fenders or where there's a small paint scratch somewhere is fine, significant rust on moving parts or large splotches of rust not so much)
/ Questions about potential purchase, not sure where to start #66
Good call. Just go get on 'em and at the dealer. Find a dealer that is patient and willing to coach you. Shoot, I just picked up a tractor this summer and there was/is a learning curve. The ROPs confounded me getting in and out of shop. Bushing had to be swapped out on my box blade so it seated in quick hitch. Learning to connect the implements to the pto...many things to learn. It's fun, but be patient with the tractor and yourself as you learn.
/ Questions about potential purchase, not sure where to start #67
Comments on a couple of points:
HST vs gear drive. Classic gear drive on a tractor is about the same as manual transmission in a car. But gear drive has one very important limitation. You have to remain in whatever gear you started in. You can't shift after you get moving because that would grind and destroy gears, there aren't synchronizers in the transmission. Maybe some modern models have synchro rings, I don't know. While HST automatically provides whatever gear you need
Straight gear drive is ok for plowing or something that will run at constant speed. But my example shows its limitations: My orchard is all slopes. I need to start in a low gear uphill, then full stop and choose a higher gear when I reach level ground. That's not very productive. I bought the second Yanmar for its low height to get under orchard trees, and also for its PowerShift. That's about the same as a car A/T except its direct drive after each clutchless shift.
Loader forks: I have clamp-on forks to attach to the front loader bucket. Under $200 for the pair. This avoids the cost, complexity, weight of a quick-attach front bucket used alternately with quick-attack front forks. I'm not convinced that a homeowner tractor needs the quick attach feature. Quick hitch on the rear, and rear loader forks, sure!
/ Questions about potential purchase, not sure where to start #68
Forks are handy, but they can wait. It sounds like the wood she wants to carry are chunks that can be thrown in the bucket. Clamp on forks might be handy later for hauling brush.
/ Questions about potential purchase, not sure where to start #69
Agreed. Aside from that, forks really aren't very useful on a machine of the size she is likely shopping. My forks and frame, even totally empty, would be eating something like 70% of the max capacity of the loader on a 1-series or that Bobcat machine that was recommended earlier.
I wouldn't bother with forks on any machine that small, unless I had some special unique need for them.
/ Questions about potential purchase, not sure where to start #70
Looking to purchase my first tractor. Have decent lawn tractor (JD x350) but it's proven inadequate for any projects beyond cutting grass.
There is a John Deere dealership nearby, and a Kubota dealer even closer, so I would like to limit my search to these brands.
I currently live on a 3.8 acre property in Washington. It's slightly hilly, very rocky soil (sometimes boulders), there's several trees but it's mostly a meadow, and it's constantly on the verge of being swallowed by blackberry. The property was neglected prior to purchase, so I'm in the process of restoring it and transforming it into my sanctuary. Use cases are moving wood, I would love to get a brush hog (as I've paid for this several times now and it's baffling how quickly blackberry grows), moving sod, filling holes, evening out land / tilling, and as a helper for ambitious gardening plans.
I think it's time for me to start considering a tractor. My budget is probably around $20K with some wiggle room.
Additional considerations: I've never used a tractor before, I'm not very mechanically inclined, and as such, I would love to have something user friendly and reliable. I don't know if this matters, I'm in my 30s and a woman, so I want to come prepared to any dealer so I don't get taken advantage of.
To be honest, I'm not 100% sure a tractor is the right thing for me. The anonymity of the internet will allow me to admit I'm sorta an idiot and in over my head, and maybe I should just stick to hand tools and manual labor.
Either way, thank you for any insight you can provide, I sincerely appreciate your help and advice.
.....Just back from a camping trip. Lets see what I can add, if anything.
Limiting your search to those two brands...Seems wise to me. Both are good. Kubota would be my first choice in the small/medium size tractor just because that is their area of concentration.
Dealer New vs Nice but Used? It all depends on the person doing the selling. You absolutely need to have someone you trust on your side to give you advice and help with this search. And that person needs to to be there in person. If you have such - neighbor or relative - and that person understands mechanical things, I would have no qualms about buying used.
You should be able to find an excellent machine in your price range. That is a reasonable price and should get what you want. You want something wide and stable. It should have a front end Loader, 3pt hitch, 4wd, power steering, and be in nice condition with under about 1500 hours and not over ten or so years old - though he age is less important than the condition. HST would be a bonus because HST makes a tractor so easy to use. A well maintained used tractor like that should last a lifetime with little or no repairs. Maintenance and condition are the keys.
If looking at used, make price secondary. What you want is one that the previous owner appreciated and enjoyed.
I don't know anyone who faithfully follows all the maintenance in the owner's manual. But try not to get too far behind. Frankly if I keep to half the factory recommended schedule that feels about right to me.
BTW, weather is hard on tractors. A shed is best, though I use a lightweight treated tarp covering the tractor down to about half way down the tires. Not perfect, but sufficient. It keeps sun and moisture off while letting it breathe. Cover it every evening and tie it at the corners so it doesn't flap.
Yes, you can get by without a tractor. We did on our place for years. Almost anything a tractor can do you can do with hand tools and manual labor. It just takes longer.
The big exception is picking up something heavy and moving it. That is what the front end loader does, and for us that was the most important labor and body saver.
Good luck,
rScotty
/ Questions about potential purchase, not sure where to start #71
It would help all of us if you could post a picture of what size of wood you'd like to be able to move or the bramble patch that needs clearing, etc. so we all have a better understanding of what you really want to accomplish.
/ Questions about potential purchase, not sure where to start #72
I currently have a New Holland TC40 that I bought new in 2006. Used it on 6 acres for years. Only worked 3 acres of it. It has been an outstanding tractor. You can find a good used one for around 17K. If you can afford to buy used, I would be looking at 30 to 40 HP tractors by Deere, Kubota, Massey, New Holland from the early 2000's with low hours. JMO. Good luck.
/ Questions about potential purchase, not sure where to start #73
Quick hitch may be handy if you swap rear implements much.
Personally I usually have a backhoe on - for digging or for ballast to offset a big load on the front, but most commonly because it's still on from the last time I used it.
Very occasionally I swap to the rotary cutter, but that's pretty much a one-and-done job, and there no point in having a quick hitch with just one implement. Once a year I might get up the rototiller, or occasionally the auger.... the auger won't with with a QH at all, and none of the other implements are at all difficult to hook up or make using a QH an improvement - especially as the QH has to come off for the backhoe.
If I ever find myself switching between two 3ph implements more than every few days, I'll look at getting a QH. Until then, it's just another thing to deal with - would not advise unless it actually solves a need.
/ Questions about potential purchase, not sure where to start #74
I have a quick hitch (Deere iMatch), and I love it. I'll go weeks without switching implements, but then will have a single day or weekend when I switch implements 5-6 times, such as when aerating and seeding and fertilizing. They're a great convenience once set up, but may require slightly longer driveshafts or other mods to some implements, to work with them.
Ironically, I switched implements far more often on my prior tractor, which didn't have a quick hitch. It worked fine, but I'm a relatively strong guy, and moving an implement an inch or two to line up with the tractor wasn't a huge deal for me.
If the OP is only buyng 4-ft implements, then those are probably not a big deal for a female operator to shove around and line up. But if going larger, then it may become more important, depending on the strength and willingness of the operator.
/ Questions about potential purchase, not sure where to start #75
My tractors have extendable links and telescoping arms. No need for a quick hitch. Also a 5' pipe will line up 4' implements easily enough.
/ Questions about potential purchase, not sure where to start #76
One other thing to check out would be YouTube. I would suggest looking up Tractor time with Tim. He mostly uses a small 1025r Deere for most work (not all though), so you could get a good idea what you can do. The 1025r is quite capable for a small machine.
/ Questions about potential purchase, not sure where to start #77
I'm usually a bigger is better sort of guy, but in this case, I think a Sub-Compact Tractor would be a good choice in this case given the size of the property, the nature of the tasks, and the experience level of the owner. Also a new Bobcat tractor and loader for less than $14k is good for the budget.
Like, I said, I usually think bigger is better, but this video shows what you can do with a SCUT.
/ Questions about potential purchase, not sure where to start #78
Definitely. But once you've done a few implement changes without even leaving the seat of the tractor, you'd fall in love with the quick hitch.
If I raise my 3 point near max, I can release the levers and swap implements from the seat. Even easier if I draw the hydraulic top link in, it's not even a stretch! Only one of the implements I still own today has a driveshaft, since I've sold my rear-mounted snowblower and brush hog.
/ Questions about potential purchase, not sure where to start #79
I've never used a quick hitch. I can see the advantage - especially when many tractors had the old "economy" type of 3pt hitch that used chains and turn buckles for side sway, threaded rod for the lifting arms, and one piece draft links.
Those economy 3pts required muscle and leverage to maneuver an implement into position to hook it up.
An alternative that some brands offered was an optional upgraded 3pt hitch with leveling boxes, telescoping draft links, and rigid sway bars. Those make hooking up an implement much easier. No wrestling required.
Still, I wouldn't make a tractor decision based on the type of 3pt hitch it has. They all work, and are easily changed.
rScotty
Good luck,
rScotty
This is excellent insight, thank you for your reply. Also, hope camping was fun!
These basic tenants are a good break down for something to look for. I have a 2 car garage that houses my mower and believe a tractor would fit in there next to it.
As an update for anyone interested, I did talk to my dad about coming with me. Due to hours of operation of some of these locations and my own work hours, I'm going to have to get a day off from work to visit the dealers in person.
For context, he's not mechanically savvy but seems to have become obsessed with the idea of tractors, wanting one of his own (just doesn't have the space nor right property for it) and watching YouTube about them for the past year rather obsessively.
He did, however, convince himself that it is not a tractor I need, but rather, a skid steer. Probably out of my budget at the cursory glance (woah so expensive), but I would love everyone's thoughts on the matter. Clearly, you all are tractor people, and I am stubbornly in the position it is a tractor that would suit the different needs I have - and falls more within my budget. And I just like it more? I don't know. He seems more caught up on the lifting power of a skid steer, which I don't think is really the point of this purchase for me personally. I'm not going to be moving pallets of bricks around construction sites.
What are your thoughts on a tractor versus skid steer?
Also, questions about wood: it's manageable right now. I think, if I had a tractor at my disposal today, I would have used it to move about 30 split logs from the top corner of my property to a burn pile rather than carry them. I think that would be the extent of it. If one of the big firs that I had around me were to catastrophically fall, then...I would probably chainsaw them up to manageable pieces to move them and also, probably get hired help.
The question about brambles: I've done a pretty okay job with managing them with a heavy duty weed wacker. Just blew out the clutch on this today annoyingly when I caught it in a buried steel cable though, so no more of that until I fix it (which, now thanks to you folks, I am going to fix it myself :D). If I keep them under control, that's all I would need to do - that being maintenance. If I don't, I would need to cut them back with a powerful implement. The location of the brambles are now in tough ledges built out by rocks, along fence lines, and around a pit that the previous owners were using to burn trash (that I have now removed the trash and need to fill the hole).
In addition, what is your position on a brush hog versus flail mower - another distinction that my dad asserted was better - and I didn't have enough information to refute other than a brush hog was the implement that was always used when it was cleared.
Thank you everyone for the insight and discussion. I'm reading through everything that is being posted and am learning so much!
