Blinker Lights with Brush Guards
/ Blinker Lights with Brush Guards #1
Gee Ray
Bota L2501, NH TL80A
I bought a New Holland TC21 from my neighbor. The warning lights set to the outside of the ROPS. They are both broken off. I have been trying to find replacement 2 sided amber lights that have a guard to protect the lights. I have found a few guards but they are simply pipe around the lights. I was hoping to find pipes that are wide enough to cover the lights and have a screen to protect the lens.
Any ideas ?
/ Blinker Lights with Brush Guards #4
Are these generic round amber lights, or are they shaped?
My Kioti uses round ones, and I found guards from small business that fit them. They were advertised for Kubota, but they helped me with the right size.
/ Blinker Lights with Brush Guards #5
Moved my lights on my MF GC series to inside of ROPS.... No more broken lights.... Found out my lights were expensive ($125 each) the hard way....
Think if I ever break them again I will go with aftermarket automotive/truck lights....
dsc01777-jpg.615143
/ Blinker Lights with Brush Guards #6
Any ideas ?
Check with New Holland, your hazard lights may have a properly sized guard as a bolt-on dealer option.
/ Blinker Lights with Brush Guards #7
Blinker lights. Two things affect my blinker lights. My Buck brush only grows two feet high at a max. Can't get to the blinker lights.
And - my tractor never leaves my 80 acres. So who cares about the blinker lights.
/ Blinker Lights with Brush Guards #8
Used some stainless tubing from scrap yard to make guards. Grape vines some of the worst to strip off lights. Haven’t lost a light since. Could easily attach some expanded metal for more protection. Tractor supply cheapest place to source replacements.
/ Blinker Lights with Brush Guards #9
/ Blinker Lights with Brush Guards #10
Once the lights are guarded, the next weak link is their wires, exposed under the fender.
/ Blinker Lights with Brush Guards #11
/ Blinker Lights with Brush Guards #12
Don’t use hazard lights often now like when I was making hay. Do help the neighbors some with storm damage. People are less knowledgeable and respectful of equipment on the road. Really pity the road maintenance crews.
/ Blinker Lights with Brush Guards #13
Nicely done. Got any of that pipe left? ;)
"some stainless tubing from scrap yard" or a local fab shop. There are online metals and dealers in most cities. Possibly a comm. college welding program.
/ Blinker Lights with Brush Guards #15
So, that's a "no," yes?
I’ll check the size when I get back home. I would not be an economical source.
I’ll pickup drops of different kinds at the scrap yard. Steel, $0.3, stainless, $1.50 per pound. Stainless bolts, nuts and parts are nice to weld up for tools or parts to steel easily and strong with mig. Big plus with stainless is no paint. Have bought specific stock from eBay and specialty metal suppliers.
I’m too old, slow and particular to make money fabrication for others. Do enjoy making stuff and trying out ideas. Do enjoy seeing what very talented people can create on this site. Innovated solutions to many problems.
/ Blinker Lights with Brush Guards #16
If you don't think you'll be running into things very often a slightly cheaper/easier way is you might look at mounting them to magnets. I've read where some have had good luck with them and I'm kinda looking at that but with also mounting a small cable to it so it won't fall completely to the ground. I've got some 3" magnets that have a 90 some odd lbs pull rating so shouldn't have to worry about vibration or lighter stuff hitting them.
I finally broke a light on my "97 JD-770 last year after 25 years of driving thru butt puckering brush and tree's, but JD wanted $55 just for one so I just went 3rd party and got the closest look alike.
/ Blinker Lights with Brush Guards #17
140 acres of woods or wants to be woods again jungle with copious amounts of limbs and Tarzan vines. Always attacking the tractor tender areas. Hate to go MadMax but don’t like getting hurt.
/ Blinker Lights with Brush Guards #18
My apologies, I left out the ;)
/ Blinker Lights with Brush Guards #19
magnets
I got a box of 1.25" x 1/8" round 'super' magnets (forget the correct name for them) Used a forester bit to rout out a depression in the bottom of a set of HFT magnetic lights (old incandescent variety) and, with tw0 (2) of these suckers epoxied in the plastic base they held on better than the factory magnet they came with.
By routing out the depression, I made the plastic thinner between magnet and vehicle's steel - you want it as close as you can safely get.
The idea of a retaining wire is a good idea.
/ Blinker Lights with Brush Guards #20
I can take aluminum or stainless sheet, wrap it around a 4-inch PVC pipe and rivet it together to make the loop.
The price of a pipe for a mere 4-inches of length for two lights is pricey.
It leaves no seams and is smooth all around though.
Thanks for your very clever idea! I tend to break mine off on dumb locust trees.
2006 MAC 35ft. 75yd. Tri-Axle Aluminum End Dump Trailer (A64556)
2006 MAC 35ft...
2014 Ford Taurus Sedan (A64557)
2014 Ford Taurus...
Small Cowboy Statue (A64557)
Small Cowboy...
2023 SolarTech Silent Advisor FD-304 Towable Solar Speed Limit Board (A64553)
2023 SolarTech...
2013 Ford Escape SUV (A64557)
2013 Ford Escape...
2017 Ford F-250 4x4 Crew Cab Pickup Truck. (A64194)
2017 Ford F-250...
