Blinker Lights with Brush Guards
   / Blinker Lights with Brush Guards #11
   / Blinker Lights with Brush Guards #12
Don’t use hazard lights often now like when I was making hay. Do help the neighbors some with storm damage. People are less knowledgeable and respectful of equipment on the road. Really pity the road maintenance crews.
   / Blinker Lights with Brush Guards #13
Nicely done. Got any of that pipe left? ;)
"some stainless tubing from scrap yard" or a local fab shop. There are online metals and dealers in most cities. Possibly a comm. college welding program.
   / Blinker Lights with Brush Guards #14
So, that's a "no," yes?
   / Blinker Lights with Brush Guards #15
I’ll check the size when I get back home. I would not be an economical source.
I’ll pickup drops of different kinds at the scrap yard. Steel, $0.3, stainless, $1.50 per pound. Stainless bolts, nuts and parts are nice to weld up for tools or parts to steel easily and strong with mig. Big plus with stainless is no paint. Have bought specific stock from eBay and specialty metal suppliers.
I’m too old, slow and particular to make money fabrication for others. Do enjoy making stuff and trying out ideas. Do enjoy seeing what very talented people can create on this site. Innovated solutions to many problems.
   / Blinker Lights with Brush Guards #16
If you don't think you'll be running into things very often a slightly cheaper/easier way is you might look at mounting them to magnets. I've read where some have had good luck with them and I'm kinda looking at that but with also mounting a small cable to it so it won't fall completely to the ground. I've got some 3" magnets that have a 90 some odd lbs pull rating so shouldn't have to worry about vibration or lighter stuff hitting them.
I finally broke a light on my "97 JD-770 last year after 25 years of driving thru butt puckering brush and tree's, but JD wanted $55 just for one so I just went 3rd party and got the closest look alike.
   / Blinker Lights with Brush Guards #17
140 acres of woods or wants to be woods again jungle with copious amounts of limbs and Tarzan vines. Always attacking the tractor tender areas. Hate to go MadMax but don’t like getting hurt.
   / Blinker Lights with Brush Guards #18
My apologies, I left out the ;)
   / Blinker Lights with Brush Guards #19
magnets
I got a box of 1.25" x 1/8" round 'super' magnets (forget the correct name for them) Used a forester bit to rout out a depression in the bottom of a set of HFT magnetic lights (old incandescent variety) and, with tw0 (2) of these suckers epoxied in the plastic base they held on better than the factory magnet they came with.
By routing out the depression, I made the plastic thinner between magnet and vehicle's steel - you want it as close as you can safely get.
The idea of a retaining wire is a good idea.
   / Blinker Lights with Brush Guards #20
I can take aluminum or stainless sheet, wrap it around a 4-inch PVC pipe and rivet it together to make the loop.
The price of a pipe for a mere 4-inches of length for two lights is pricey.
It leaves no seams and is smooth all around though.
Thanks for your very clever idea! I tend to break mine off on dumb locust trees.
167 (A52708)
167 (A52708)
VOGELE VISION 5103-2 ASPHALT PAVER (A60429)
VOGELE VISION...
2023 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A56857)
2023 Caterpillar...
Case-IH 370 Steiger (A57148)
Case-IH 370...
2025 MACK GRANITE GR64F DUMP TRUCK (A59823)
2025 MACK GRANITE...
Brent 420 Grain Cart (A56438)
Brent 420 Grain...
