Gravel/Loam Screen
/ Gravel/Loam Screen #1
MadJack
Litchfield, Maine
86 Ford 2110 4x4
I've had this screen kicking around for several years. I picked it up as 'scrap' with a bunch of scrap during a clean up job. And I had a few red oak logs laying in the yard from this spring. (browntail killed the oak) So while milling lumber, and the last logs in the yard were the oaks, I cut 3.5" x 7.5" timbers and some 2" planks. Frame is grade 5 bolts, planks are attached with lag bolts. I broke too many galvanized lags to ever use them again. I'll re drill and bolt everything as time allows, but it works well in my small pit!
/ Gravel/Loam Screen #2
I've got a 5'X8' screen I use for both sand / stone separation and screening compost. Expanded metal, so pretty fine.
The difficulty I have with it is finding the best screen angle for the material at hand. Every time I think I should build a structure with a shaker engine, I kick myself awake and recall how infrequently I really need to use such a screen.
But when it's needed, a screen sure is a time and money saver
This screen is 4' x 6' made with 1/4" straight rod, and one inch openings. (flat, not woven)
I have also thought about the shaker, but My OCD brain would explode knowing something is out of balance! Especially on purpose.
Then there is the whole maintenance deal with something rarely used.
I already can see improvements and add-on parts coming, but for now it's separating rocks from finish material.
2006 JLG 600S TELESCOPIC BOOM LIFT (A62129)
2006 JLG 600S...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61567)
2006 Generac...
4 Shelf Rolling Cart 6ft x 3ft (A61166)
4 Shelf Rolling...
2012 Freightliner Cascadia (A63118)
2012 Freightliner...
14ft Service Bed (A61165)
14ft Service Bed...
(2) 1500 Gallon Tanks w/ Pump (A64047)
(2) 1500 Gallon...
