Another Battery!
/ Another Battery! #41
Batteries seem to be a crapshoot the last few years. We've also had trouble with battery cables and connectors corroding. I ordered some nice looking brass battery connectors from Amazon. Although they looked nice, they formed a hard corrosion between the connector and battery post inside of a month. In spite of the red/green pads and sealed AGM batteries.
Finally found some vintage 1950's truck battery cables made out of stranded copper, with old fashioned soft lead battery post connectors. They work great, but I can't find anything like them for sale new.
Let me know if you find good copper cables and lead connectors.
rScotty
I make my own, crimp and solder them. Then I treat the small exposed portion and seal with heat shrink.
/ Another Battery! #42
I went out to use the tractor and move some wood chips around. Turned the key and nada, zilch, no clicking, no lights on dash, nothing. 5 years and 21 days on the Legend from Napa. I was sort of surprised because ever since I put that Legend in on 8-01-2019 it's had a BatteryMinder 1500 hooked up and plugged in.
I was hoping that would get me 10-15 years of life from the battery, but nope! So I'm not sure if the battery just had a specific lifespan or if my BatteryMinder Chargers are just not up to snuff; or I was expecting/hoping for to much! Probably the last!
I guess I'll just have to stick with a 5 year lifespan on batteries. I know that's what a lot of you have all said but I was sort of hoping to beat the odds and get a battery to last for a really long time! I ran down to Napa and got another one and I'm still "hoping" for a "long" lifespan but I'm not going to hold my breath!!
$110.00 in 2019 and $224.00 in 2024, $114.00 difference for the same darn item - that "probably" won't even last 5 years this time! Go figure!!
Oh well, I need my beast to fire up at any moment that I have the need so that's what it takes. It's just sorta hard to accept that big of a change in cost for the same darn thing!!
It must be one of those volatile inflation items that don’t count. Until you need one!
/ Another Battery! #43
So if you were in the battery business and you could sell a battery that lasts 5 years or 10 years which one makes more money? Bendix-Purolator sold Starter drives, each drive lasts 50k? or 100k? miles.
Then they switched to oil & air filters. Filters get throw away after 3-5-7k miles. Way cheaper to manuf. filters than starter drives.
/ Another Battery! #44
12 volt Walmart battery in my 8N Ford tractor lasted an unbelievable 18 years ! Naturally when it failed I replaced it with another Walmart battery, that was about 5 years ago.
I have a Walmart battery in my farm tractor that has passed 8 years and still starts the tractor after sitting a month out more at a time.On my diesel pickup I have over 6 years on two Walmart batteries. Most of the time I only get around 5 years out of them
/ Another Battery! #45
As per their well known MO. "Planned Obsolence"
CHINA WINS AGAIN
/ Another Battery!
I tend to buy batteries from Walmart and Interstate. Both offer multiple grades and I buy the better grades for the heavier plate construction. The only special treatment they get from me is an occasional start and run if they are not used on a regular basis. I would be pretty disappointed if I only got 5 years. Typically they go over 10 years for me. Regular short life in a battery is an indication of a problem over charging or a drain. One thing I always do is apply No Ox Ide A to the terminals EVERY time they are disturbed. Dialectric grease does an excellent job of protecting insidious moisture but not much else.
Flogger, You're one of those guys I'm "trying" to copy! I too use No Ox ID whenever I need to monkey around with the connections but that hasn't seemed to help with long-lifespan, just with keeping connections non-corroded.
Like most that have replied, it seems as if approx. 5 years is usual for most batteries. Then there are the usual few that claim 10 years or longer!
That was the main reason for my original post - I'm trying to finally get into that "exclusive" club!! Membership constantly evades me though!!
/ Another Battery! #47
I've been using a small solar charger over the winter for both my Deere's. I keep them in a shed, and running AC power out to the shed would be too expensive, so I tried my hand at solar battery charger/maintainer. So far, its worked great for the last couple of years.
/ Another Battery! #48
Years ago my battery just didn't seem to have enough get up and go in it. So finally after thinking about the different options I came up with a simple solution that has served me very well. I purchased a small solar panel, attached a negative and a positive cable with spring clamp ends. I then attached the solar panel to the top of my hat and then attached the negative cable to the left ear and the positive cable to the right ear. I now have more energy than the energizer bunny! Patton pending.
/ Another Battery! #49
A couple of things that can help longevity:
Never let the battery go below 12.4 volts, that's supposedly when sulfation starts.
Use desulfation whenever possible, no matter what.
Minimize the voltage cycles the battery sees. They can take many thousands of shallow cycles, say from 12.6 to fully charged, but only a few deep cycles. That's why keeping them on a good maintainer is so helpful.
/ Another Battery! #50
I get my batteries at Rural King, typically around $79 today. My tractors get group 24. Typically last just around 5 years w/ no tender.
A lot of time, a just buy good heavy batteries for my diesel truck, when they get weak, they go in tractors or generators, Then go to things like diesel transfer pump or trail camera. Ha! A weak truck battery last forever on a trail cam. Kinda like hand me downs.
/ Another Battery! #51
Look at the AGM batteries on Amazon. Not much more than a flooded type and will last a long time in an application that shakes them around a lot like a tractor.
If you use a name brand battery minder even a flooded type battery will last a long time in an application that is not used regularly like an antique vehicle or a tractor.
I gave up trying to keep batteries on all of my small engines and just use jumpers to start them when needed.
/ Another Battery! #52
My oem JD 790's( I have two) had last nearly 15 years and were replaced for peace of mind not failure. I am on my second set on these 1998 JDs. I have had to replace two ground cables and three terminal connectors in all that time. Batteries last, wires are my consumable.
/ Another Battery! #53
I've never had great luck with tractor batteries. I was told the vibration didn't help them. On the other hand the battery I got when I bought a 2004 Tundra made it just short of 10 years.
/ Another Battery! #54
Lucy ones and not so luck ones that is the Answer or Sometimes you feel like Nut so you buy a battery and you get a good one or maybe NOT!!
/ Another Battery! #55
Have been told the simple “add water” batteries have the best life, if distilled water is used when needed. If ignored an AGM will last longest.
/ Another Battery! #56
I just remembered, the only automotive battery that had given me any grief were in my cj7 when I switched to the fancy AGM optima, those were warranty replaced twice in three years. After the third replacement they voided its warranty. Switched back to a die hard, ten years no issues. Optima were garbage.
/ Another Battery! #57
Did you keep an eye on the water level in the battery? I've had batteries last a lot longer than 5 years. The ones that I've lost while using a battery tender on them were because I wasn't keeping them topped off. Charging an old battery that's low on water with ANY kind of charger is a good way to make it go boom, so be careful.
/ Another Battery! #58
At $224 for a new battery , the price is close to that of a lithium iron Phosphate battery. I have seen them around $280 price for a group 24 with 6 and 10 year warranties. there are a few companies offering lifetime warranties at higher prices. over the years I have had lead acid batteries last as long as 15 years . In the last ten years I have had a few car batteries fail around 5 years. Now in my daily driven cars I change them out at 5 years and use the old battery in a welder or a tractor that I can easily jump start if the battery fails. My motorcycles all have lithium batteries now, price has come down enough on those to be worth while. haven't had a problem with with one yet.
/ Another Battery! #59
Trickle charger!!! I have a CETK on my John Deere 4310 one on my 5000 watt Honda generator, one on my 1973 Pontiac T/A, one on my 2008 Yamaha Grizzly bought new never changed original battery, one on a 2000 corvette and one on my 2010 Hustler zero turn 60" mower. Once you put them on you never change batteries.
/ Another Battery! #60
I have a hate relationship with batteries. I want a gadget with the following features:
  • desulfator
    works off battery
  • Wifi status reporting with open API -- works off battery
  • trickle charger/minder -- requires plugging in.
  • Permanently mounted
I have found products that come really close to having all of these features. I bought a Yale battery powered forklift about five years ago for basically scrap because the owner said the battery was going bad. It's still working. Not sure if its because of the desulfator, but it didn't hurt.
I could easily design one of these, but have so many other projects going. I'd have to charge at least $100 for this, and don't think anyone would buy it at that price point. Probably needs to be closer to $50.
KMC 3pt 6 Row Vine Lifter (A64119)
KMC 3pt 6 Row Vine...
New Carbon Steel 4.75-12T Shackles, 38 Total (A62679)
New Carbon Steel...
2019 Ford F-550 4x4 Service Truck (A61573)
2019 Ford F-550...
2025 IREV Electric Scooter (A64194)
2025 IREV Electric...
2017 Ford F-250 4x4 Crew Cab Pickup Truck (A61573)
2017 Ford F-250...
John Deere 12in Channel Tooth Bucket Excavator Attachment (A64194)
John Deere 12in...
