Another Battery!
/ Another Battery! #21
I've had more batteries fail that have been left on battery tenders (several brands) than not.
I'm by no means a battery expert, but I have read that.....that it is no good to leave them on a maintainer all the time. They say to take them off every other week or month or have one that cycles because it is better for the battery to discharge then recharge in cycles?
/ Another Battery! #22
Darkblack, I read about people like you and I hope to someday achieve that goal but so far it seems unobtainable for me. I will keep trying but as I stated - even with a "smart" charger hooked up it seems to evade me!! Just not as lucky as you are I guess. Thanks for your input though - it gives me continued "hope" that I may "someday" be one of the lucky ones.
I believe it has a lot to do with where you live. Hot weather shortens the life of vehicle batteries. I believe batteries last a lot longer in colder states like NH, than in hot states like Arizona. I saw a listing on it once. It was striking how short average vehicle battery life was in hot climates.
I also never use battery tenders. If the vehicle is sitting more than 3 weeks and has a computer drain on the battery, I just do a normal rate charge about every 3 weeks
/ Another Battery! #23
My 17' Ridgeline has a 8 year old battery (as of Oct at least). I keep it on a NOCO 5 battery charger when I'm not using it for any length of time. That charger also has a desulfination mode that I use a couple times a year. It works. And how do I know ? I use a battery tester to check internal resistance (actually capacitance) inside the battery. It tests it and especially after a charge cycle and settle time (next day test). I also had a battery for my Steiner last 12 years recently. It was a cheap Walmart battery. I did the same testing and charging regiment to it too. I've had lawn and garden tractor batteries last long periods as well. But not all. Some fail of course as they are cheaply made and not good quality like a better car battery is.
Here's the charger I use.
And here's a tester like I use (not this exact one as they keep changing them)
/ Another Battery! #24
There are a lot of crappy brands for battery maintainers out there. Some of them undercharge, leading to sulfation of the battery, some overcharge, boiling off the electrolyte. If you are going to leave a maintainer on the battery for an extended period, yo really need to be using a good quality smart charger.
/ Another Battery! #25
That is not the case for flooded lead acid or AGM batteries. They do best when kept fully charged (using the appropriate charging and float voltages). Since the appropriate voltages vary with temperature, it's important to have a temperature compensated charger for best life. I prefer a smart charger that also has a desulfation feature. True smart chargers (good quality ones) are not constantly pumping electrons into the battery: they monitor the battery condition and only charge as needed.
NiCad and Lithium batteries do tend to like to be cycled occasionally. For best longevity, most lithium batteries also like to be stored somewhere roughly around half full (somewhere in the 25% - 75% of full charge range) when they will not be used for an extended period.
/ Another Battery! #26
The optima yellow top battery in my tractor is 8.5 years old. I put it on a BatteryMinder brand charger maintainer any time I won't be using it for more than a week or two. (Model 1215C - electrically very similar to their model 1500, but more weatherproof.) It's temperature compensated and has a full time desulfation circuit (using high frequency pulses, not high voltage as some do).
My antique truck has a 24V system with two 12 V batteries in series. I have an on-board NOCO Genius 2 bank charger (similar to their current GENPRO 10x2 charger, but mine is an older model), temperature compensated with desulfation and charges each battery independently - which is a much better way to go than using a 24V charger. I connect it any time the truck is not likely to get used in the next week or two. The batteries were in the truck when I bought it. No idea how old they are. I've had it for 5 years. The batteries seemed a bit on the weak side when I bought the truck, but the desulfation seems to have brought them back. They are still going strong, and test well with a load tester.
I bought a used UTV a little over 1-1/2 years ago. The original battery was trashed so I replaced it. A local dealer and an ATV service guy both told me I'd be lucky to get two years out of the little battery these things use. I went for a Yuasa AGM battery, hoping to get a bit more life out of it. The receiver for the wireless winch control is always on, creating a drain on the battery. I keep it on a BatteryMinder charger/maintainer specifically designed for AGM batteries any time the UTV is not in use. The battery is 1.5 years old now and still going strong. I'm interested to see how it holds up.
/ Another Battery! #27
9 years for the basic Exide in my machine. It's now starting to show weakness. I'll have to find a replacement before winter since the tractor is used to plow.
@John_Mc Yes, I agree, I too only use a smart charger.
/ Another Battery! #28
A good battery well maintained will last 4 to 5 years. I had one make it to 6 years, but that is about the limit of a wet cell battery.
My last pickup truck battery lasted 13 years.
My original tractor battery last 11 years, current tractor battery is 12+ years old and still working fine.
Zero turn mower battery last 10 years.
I generally average 10 years on my car battery's
Never had a maintainer on any of my batteries.
/ Another Battery! #29
With over 60 batteries to take care of I do my best to treat them nicely.
Started using BatteryMINDers and Canadus desulfators a long time ago, later also PulseTech products.
Some batteries (Optima Group 31 and normal car size, four each) were constantly on maintainers mentioned above and lasted over 20 years. Well, they started acting up when no longer plugged in, but were charged by solar chargers (still with desulfation).
My '10 M6040 battery is still going strong, rarely charged other than by using the tractor, but has a permanently installed Canadus. The '13 L3800 gets treated to desulfation every now and then, when I remember to put a Canadus on it.
Basically, each vehicle/trailer/battery is a bit different, and treated differently, but I think the key is (as mentioned by others above) to use quality maintainers.
I've also found regulated 10W solar panels that seems to work very well. Some batteries are constantly on one of the six I have, others more occasionally, just like with the maintainers.
I don't remember having a single battery lasting less than five years, but the majority makes it past 10. Some are inside for the most part, the majority are outside.
/ Another Battery! #30
Things lasting half as long but costing twice as much. I’m sounding like Dad a little more each day. Troubling that increasing initial cost doesn’t necessarily mean a longer lasting product. One of reasons we have down sized from half a dozen tractors to two.
On a related subject have been pleasantly surprised by these newfangled capacitor jump starters.
Easily starts extending stored diesels with failing batteries or even completely dead. Appreciate flashlight feature in a dark tractor shed, light weight and so much easier than jumper cables. Safer too. Will help get a little more life (year(s)) from the batteries and comfort in knowing I will not be stranded.
/ Another Battery! #31
Amazon.com
That appears to be a lithium battery jump starter, not a capacitor-based one. Have you actually used the brand in the link? I'm in the market for one one of these days.
/ Another Battery! #32
The JD strongbox battery that came with the 4320 lasted 14 years. The battery that came with my F150 lasted 6 years. I never did anything to maintain them. Actually, I never give the batteries a second thought.
/ Another Battery! #33
Do you use both regularly? 14 years is great life for a tractor battery, given the heat, vibration, and occasional periods of disuse that many tractor batteries see.
Lead acid batteries like to be fully charged. They will self-discharge over time even if the vehicle in which they are installed has no "phantom loads". Modern vehicles tend to have more phantom loads, so the battery drains more quickly when idle. Regular use keeps them topped off from the vehicle's charging system. Sitting idle for extended periods without a maintainer causes sulfatation, shortening the life.
/ Another Battery! #34
I’m no expert on how it works. It has a small battery of several cell phones worth but uses I would think capacitor tech to deliver the punch in amps to start a vehicle.
Yes I have used that one. AUXITO brand LED light upgraded also. Started Dodge diesel with two batteries that just clicked and B26 tractor with completely dead battery. Drops the charge to 73-86% so needs recharging after use. Did start the B26 several times from one charge till I eventually replaced the battery. Self discharges so need to check charge every 3 months.
/ Another Battery! #35
I have a fairly large Noco jump starter, and it helped fire up my Peterbilt once.
Took for granted it has lithium batteries so just like with the cordless tool batteries, it only gets charged when under supervision.
Maybe that's overly cautious, but I'd hate to lose the garage and everything in it to a battery technology I don't fully trust.
/ Another Battery! #36
I've given up on trying to get long life out of batteries. The trouble a dead battery causes me is often ten times what I'd save postponing the purchase a year or two. I replace them every 3 years. That keeps things available for unexpected tire failures....
/ Another Battery! #37
The only thing I am absolutely sure about a battery, is once you let the charge go flat, you have shortened the life of the battery by a huge percentage
/ Another Battery! #38
I tend to buy batteries from Walmart and Interstate. Both offer multiple grades and I buy the better grades for the heavier plate construction. The only special treatment they get from me is an occasional start and run if they are not used on a regular basis. I would be pretty disappointed if I only got 5 years. Typically they go over 10 years for me. Regular short life in a battery is an indication of a problem over charging or a drain. One thing I always do is apply No Ox Ide A to the terminals EVERY time they are disturbed. Dialectric grease does an excellent job of protecting insidious moisture but not much else.
/ Another Battery! #40
Religion, politics and batteries! Always a topic with a lot of viewpoints. The L3400 I bought used in 2014 came with a Napa battery, and it's still in there, always starting perfectly. I use the tractor rarely, less than 25 hours a years sometimes, and I do stick a $5 Harbor Freight maintainer on it when I know it's going to sit for more than a couple weeks.
John Deere 350 Sickle Bar Mower (A66408)
John Deere 350...
New/Unused Wolverine Quick Attach Trencher (A65583)
New/Unused...
Year: 2018 Make: Towmaster Model: TC-16 Vehicle Type: Trailer Mileage: Plate: Body Type: Trim Lev... (A61567)
Year: 2018 Make...
UNUSED WOLVERINE SB66 - 66" ROCK BUCKET (A64281)
UNUSED WOLVERINE...
30x57 Welding Table (A65640)
30x57 Welding...
2017 Nissan Altima Sedan (A64557)
2017 Nissan Altima...
