Hydraulic pipes
/ Hydraulic pipes #1
pycoed
West Wales UK
Zetor 7045; Yanmar YM1820;Wheelhorses C121, C101, A8;Cushman Turf truckster
Right, I've fixed a double spool valve I had surplus behind the seat of my 1820, read up all about the need to insert a plug in the Yanmar hydraulic distributor & the need for a power-beyond sleeve in the spool valve, so I'm all set to plumb her up.
What size hydraulic pipes do others use? My main concern is the return to tank (connection on side of transmission) which will reduce the already limited footspace on the left. Pressure & return I think can be tucked under the seat & out of harms way, but the tank return will be in the footspace - I'm thinking an M16 banjo to 3/8 hose will be the most compact option both at tank & spool valve end but I did wonder if 1/4" would handle the flow (which isn't great - about 3 gall/min AFAIK). Could this cause problems with aerating the oil which will have to return above oil level it seems? Am I overthinking this - after all it will get only occasional use - it won't be running a log splitter 24/7?
I've used an online hose builder from Flowfit here in UK for all the pipes needed to fit a joystick spool to my Zetor, but that was easy - all 1/2BSP connections.
/ Hydraulic pipes #2
I’m no expert and am learning for a project myself but as I understand hydraulics even if you are not using this specific valve the power beyond and return will have constant flow
/ Hydraulic pipes #3
I wouldn't go less than 3/8" for the return. 1/2" is overkill for this size of tractor.
Flowfit is great, I used it all the time before Brexit. All my hoses and fittings for my homemade loader came from them. Great prices and they used to have free shipping above a certain amount spent.
/ Hydraulic pipes #4
Tank return has flow only when valve is actuated. Other times the flow goes thru the power beyond hose and thru the 3 point. Having said that, yes there is hydraulic flow any time the engine is turning.
/ Hydraulic pipes #5
Use a Aux. pump and tank. The way my Ford setup and it's simple. Cheap also! I can even Remove, Replace the Whole FEL. in a matter of minutes. And then the Tractor is Back Org. Fully intact. Handful of bolts and the Hyd. pumps Dr, shaft is ran off the Crank pully! Yesterday's Tractor, Stiener has the setup. Doing it that way for over 60 yrs. I rebuilt the ford just for the loader. 48Hp. and know what it can do, Had the Yanmar 24HP, No FEL. Had it 16Yrs. My lawn mower and Tiller. I had to replace both the Bearings Seen how light duty the front end of it is! And a huge Scar on one of the Axels Sure did. Rice Patty tractors!!
/ Hydraulic pipes
Just found that the plug on the left side of the gearbox is actually 3/8BSP! Checked the output & return on the hydraulic distributor & they are both 3/8BSP too! That'll make connections much easier since I have lots of 3/8BSP fittings in my collection. I hope the internal plug fitting is actually 1/4NPT 18 as stated in the manual excerpts I found online, since I've just ordered one
/ Hydraulic pipes
Just completed connections (see below) - all works fine:) with one proviso: I had 4 new 1/4 BSP QD connectors in the workshop- can't remember where I got them from - probably in a box of stuff from a local auction... Anyway,when I connected a test cylinder to these, on using the spool I could hear the relief squealing in either direction. Connected the cylinder directly to the spool & all worked as expected.
On checking the 1/4 QDs I found they would barely pass diesel through them when connected, so obviously faulty.
I'll order some 3/8BSP QDs, but they'll be a tight fit onto the spool - I want to use them direct to the spool to minimise connections etc.
I just intend to use the one spool for now on a small logsplitter I built a few years back. I'll check whether the tractor will handle a rear loader I have that also uses only one spool, but I think this little girl will struggle with that.
The pressure hose to the spool is just a bit too long, hence the routing with bends under the seat. It would sit better routed like the PBY hose, I'll order a shorter one alongside the QD's
/ Hydraulic pipes #8
Your design and fabrication turned out very well, I think. (y)(y)
Do you know the hydraulic HP (flow x pressure) available on your machine? It might give you some insights on the log splitter cycle.
(I love your shop; lots of items to be out to use and seemingly well organized.)
All the best,
Peter
/ Hydraulic pipes
No idea of the flow /pressure - the ram is one of the bucket curl rams from a loader & I currently use it on the hydraulics of a Cushman Turf Truckster which has a 3 cyl Kubota engine & a hydraulic pump driven by a single A belt! It works fine for speed on the Cushman, power not so impressive, but most of my logs come from hedge-laying (I don't think that's a thing over the pond, but Google it to see - some is VERY impressive- mine not so!). It would be rare for me to be splitting much thicker than 15" & most would be around 6" so this little splitter works well enough, especially when I cross-cut sensibly around awkward crutches etc.
/ Hydraulic pipes #10
I know hedge laying rather well. However, the climate here, where it is there is almost no rain for six months from April to October isn't exactly favorable, and with a total rainfall in the
250-300mm range, so hedges don't exactly thrive. Other parts of California are more favorable. I think you live in an ideal local for hedge laying, and yes, I know it is a skill, like dry wall fencing.
All the best,
Peter
/ Hydraulic pipes
All the best,
Peter
Everybody loves workshop pics so here are a couple of mine.
When I built it 40 odd years ago I never dreamt I'd need to get a 10ft tall tractor or modern pickup inside, so it's a nuisance that I can't. I bet if I'd built it to take a 10ft tractor I'd probably now have a 12ft one anyway:D. Thats the rule with sheds: youcan NEVER EVER build them big enough.
I did build an extension to it last year & moved the milling machine & welders into that which now means I can actually get a car or small tractor into the garage without having to move stuff around.
The metric lathe,( which I don't use much - I cant "think" in metric. e.g. .05 mm means nothing to me whereas I can "see" 2 thou.(y)) is still blocked in with a pallet truck full of old electric motors & stuff I'll take to the scrappy when I get around to it. I prefer to use my Kerry lathe - the controls are ergonomically right for me & everything seems logical with that.
Still waiting on 3/8BSP QD's which proably won't be here until Tuesday now since Monday is a Bank Holiday here.
250mm rain is a typical winter monthly total here with about 100mm per month through the summer, though last year was the wettest I can remember we had to send the tack (summer grazing) cows back after 2 weeks & could cut no hay at all(n)
/ Hydraulic pipes #12
I noticed your tread on your rear tires is reversed. Is there a reason for that?
/ Hydraulic pipes
Thanks, I hadn't noticed! I reversed the wheels to give more track & must have mixed them up.:unsure: I'll swap 'em over today after I've finished bashing rushes with my Zetor & flail.
I've just done the same on a Wheelhorse rear agrityre<DOH> I had such a wrestle to break the bead (hasn't been off since 1978 I reckon) that after I'd tubed it I couldn't face taking it off again & probably nipping a new tube. So that one is staying!
/ Hydraulic pipes #14
I had to take my Org. Bridgestone to a tire shop and break the Bead. They even had the Hammer out on them! Late 70's model YM2000. No way after seeing what they had to go through. I could hardly get them to loosen up. I was installing a New Full Tire Nylon Insert were they cracked. Replaced the tubes and not the first complaint. Gempler had the full tire insert. Doubtful I'll ever wear them out. The lugs are still Huge! Big difference! I actually turned one around to see just how close they would be. I didn't even bother putting both on after seeing how close to the fender it was.
The rears was already Reversed for extra stability when I bought it in 2008. Not much doubt after seeing that with the splits
2018 Ford Escape AWD SUV (A61569)
2018 Ford Escape...
25' SINGLE AXLE VEGETABLE TRAILER 5TH WHEEL (A62130)
25' SINGLE AXLE...
2025 Electric Cart (A61569)
2025 Electric Cart...
2021 John Deere 3046R Tractor Loader (A63116)
2021 John Deere...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
Kubota L2501 (A62177)
