pycoed
- Joined
- Mar 28, 2007
- Messages
- 180
- Location
- West Wales UK
- Tractor
- Zetor 7045; Yanmar YM1820;Wheelhorses C121, C101, A8;Cushman Turf truckster
Right, I've fixed a double spool valve I had surplus behind the seat of my 1820, read up all about the need to insert a plug in the Yanmar hydraulic distributor & the need for a power-beyond sleeve in the spool valve, so I'm all set to plumb her up.
What size hydraulic pipes do others use? My main concern is the return to tank (connection on side of transmission) which will reduce the already limited footspace on the left. Pressure & return I think can be tucked under the seat & out of harms way, but the tank return will be in the footspace - I'm thinking an M16 banjo to 3/8 hose will be the most compact option both at tank & spool valve end but I did wonder if 1/4" would handle the flow (which isn't great - about 3 gall/min AFAIK). Could this cause problems with aerating the oil which will have to return above oil level it seems? Am I overthinking this - after all it will get only occasional use - it won't be running a log splitter 24/7?
I've used an online hose builder from Flowfit here in UK for all the pipes needed to fit a joystick spool to my Zetor, but that was easy - all 1/2BSP connections.
