Exterior outlet on pole barn/corrugated metal
/ Exterior outlet on pole barn/corrugated metal #21
Not sure I fully follow your description here. Would the LB be inside, to handle the 90 degree turn necessary to run from indoor -> outdoor? And then thread into the back of the weatherpoof box?
I think I can see how that would work, but would be a change from the current wiring in the building which is all MC and 4" square metal boxes. I prefer to be consistent if possible (for whatever reason the looks of things matters to me :)
There are lots of ways to skin a cat!
Yes, I was thinking that the LB would be inside, but you certainly could use a box and MC if you want the consistency. With MC, I think you might be able to use a threaded fitting through the wall to the weatherproof box.
Originally, I was just thinking an appropriate sized nipple could be water tight at the external weatherproof box, with a gasket/rubber washer at the metal outside, metal, a second gasket on the inside, and a washer or box or LB on the inside. Sorry not to have been clear enough the first time. Is this any better?
Bottom line: whatever works well for you. I just sweat the building penetrations a bit as they are guaranteed to be headaches later if not done well.
All the best,
Peter
/ Exterior outlet on pole barn/corrugated metal #22
There was no girt behind the location where I wanted to place the exterior outlet, so I screwed a piece of plywood between the girts above and below. I fastened a 4" box to the plywood at the place I wanted the outside outlet. I drilled a 1" hole through the plywood and sheet metal siding and used a 6" pipe nipple to connect the inside and outside weatherproof box.
I've since used the plywood to mount other equipment, and added a double duplex outlet for convenience.
/ Exterior outlet on pole barn/corrugated metal #23
This mine from 10 years ago. I think I used it once. Inspector approved it.
Thanks. Looks about how mine ended up, aside from the bubble cover (I hate those things!)
For Sale L4479 Snowblower and Subframe
For Sale L4479...
Giyi GY-STB47 QA Telescopic Boom (A60463)
Giyi GY-STB47 QA...
2017 KINZE KNOTCHED SINGLE DISK FERTILIZER OPENER FOR 3000/3500 SERIES PLANTERS (6 ROWS) (A55315)
2017 KINZE...
2005 Isuzu NQR 4 door box truck with folding gate (A61307)
2005 Isuzu NQR 4...
1608 (A57192)
1608 (A57192)
2017 ADDCO ROAD SIGN DH1000-ALS (A60736)
2017 ADDCO ROAD...
