Exterior outlet on pole barn/corrugated metal
/ Exterior outlet on pole barn/corrugated metal #1
drumminj
Gold Member
Tennessee
Kubota L4701
I've wired up the inside of my shop building and now looking to add an exterior outlet on the side-shed/porch. The inside isn't finished -- just metal fastened to the girts with thin foil-faced insulation in between.
How do folks normally mount outlets in this situation? Surface-mount outdoor rated box and just drill a small hole to pass the wire through from inside? Or mount a new construction/interior junction box to the posts and do a rectangular cut-out into the siding with a weatherproof cover?
If an outdoor junction box, do you just use sheet metal screws to secure it to the building? In either case, how do you ensure a weatherproof seal with the siding?
I'm sure I can figure something out that will work but would love to hear what others recommend, or recommend against.
/ Exterior outlet on pole barn/corrugated metal #3
I think that's what I saw on my neighbors hay barn. A square, water proof cover on a square hole. Swing open the cover - reach inside and connect the extension cord. When the cover is shut there is a waterproof recess in the bottom of the cover to accommodate the extension cord.
That way everything, that could be affected by weather, is kept inside the barn.
/ Exterior outlet on pole barn/corrugated metal #4
You have a great metal barn. I would not run an outlet through a wall. I would go down, under up and out. It greatly reduces leaks.
All the best,
Peter
/ Exterior outlet on pole barn/corrugated metal #5
I went through the metal since I had a concrete floor. I used an approved out door weather proof receptacle box surrounding the receptacle.
You have a great metal barn.I would not run an outlet through a wall. I would go down, under up and out. It greatly reduces leaks.
All the best,
Peter
This won't work as like Citydude I have a concrete floor. So I'm at least drilling a hole big enough to run romex or armored cable through.
Thanks for the info. Did you just screw the box to the sheet metal siding then? Or somehow secure it to a girt?
/ Exterior outlet on pole barn/corrugated metal #8
I secured it to the girt. I did this before finishing the interior.
/ Exterior outlet on pole barn/corrugated metal #9
You could possibly substitute steel (not aluminum) rivets instead of sheet metal screws if your metal panels are strong enough. I wouldn't use them on thin metal panels. They also make backers for rivets if you want to reinforce the panel so the rivet doesn't pull through.
/ Exterior outlet on pole barn/corrugated metal #10
That would be all I would do to the siding. Drill hole, run romex, then screws waterproof box to the siding and into a pole barn support post.
(15) Polyethylene Road Bed Protection Pads (A60463)
(15) Polyethylene...
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
2017 Wacker Neuson LTV6 Towable Light Tower (A56857)
2017 Wacker Neuson...
2009 Kubota RTV1140 (A57148)
2009 Kubota...
CATERPILLAR 140M MOTORGRADER (A59823)
CATERPILLAR 140M...
KJ K0720 7'x20' Metal Gate (Deep) (A60463)
KJ K0720 7'x20'...
