Compacting gravel driveway
/ Compacting gravel driveway #81
We used to use #2 crusher run for the base for all our parking lots and roads we built when is was working.
This was always specified by the engineer. This has fine dust in it from being run through the crusher. Wet it down good with a hose before compaction ! I would be careful with the vibrating roller. I assume it would be a 10 ton.
I've seen tire roller systems used to pack crusher run for gravel driveways, but nobody has them where I live. They're also really expensive. I used to just put my bucket down at a very slight angle set to float, when I back down the center with my scraper blade, forming the crown and the bucket packs and smooths the surface. Unfortunately my spool valve doesn't work in the float position any longer, so I have to mess with the bucket in a fixed position and constantly adjust the pressure.
/ Compacting gravel driveway #82
I had a Nephew that lived in Seattle. He loved it. To many people and people noise for me. I really liked the Public Transportation system though.
I’m 40 min North by Northeast near Granite Falls, out far enough to get away from most of the traffic but still close to shopping etc.
/ Compacting gravel driveway #83
I've given up on gravel entirely. 2 years ago I purchased a couple tri axle dump loads of asphalt millings and the contractor not only spread the millings but vibratory packed them down. That was 2 years ago and it still is just the way it was laid down, No more gravel for me.
/ Compacting gravel driveway #85
In N FLa millings/RAP have just gotten so darn expensive; min of $800 for a dump truck load. With the trucking issues, mine problems, whatever the federal law about US ships between US Ports, rail issues, Amazon, name it; asphalt companies want Paid well to get rid of their millings.
They are a good product for sure; but when you get to $800-1200 per load (16 CY roughly); there start being better options. A truck load might do about 72 square yards at 5-6" depth; we could do 6" of poured concrete for about 25% more (if your doing the labor). And although millings are good, I'd be hard pressed to tell you they are equal to concrete or asphalt.
/ Compacting gravel driveway #86
Let me try again with the story that was deleted before being posted.
A Contractor was re-doing, tearing out and replacing worn out interstate. He would grind the old off, install a new base and pave over. One of his water trucks had a major mechanical breakdown. The time to get back in service was estimated as 3-4 weeks by his shop. He contacted a local heating oil company and explained his dilemma. He asked if he centralized his equipment could they do fuel refills for him. They advised sure.
He had the shop transfer the water boom and other equipment to the fuel truck and converted it to a water truck. Well the fuel truck had in big bold letters, DANGER DISEL FUEL NO SMOKING ON BOTH SIDES AND THE REAR. Well the first day it was in use people would drive by and point. About the third day the EPA showed up. He explained the situation and the EPA guy advised him to get some brown wrapping paper and duct tape and cover up the signs on the sides and rear because they were tired of getting phone calls that he was spraying diesel fuel on the gravel.
/ Compacting gravel driveway #87
I think gator man likes to argue so much that he forgets what he writes. ;)
Nope Gator man was setting here reading the post before posting it and BLIP it was gone.
/ Compacting gravel driveway #88
The K.I.S.S approach works well for me...1-1/4 minus, tailgated out over a solid base.
Wet or dry doesn't seem to make a difference, and I think I recall the trucking company telling me the weight percentage difference between wet/dry is about 1% in practice. We pay by the ton here, and I'm going to stick with getting it when I want it vs. saving a few pennies.
/ Compacting gravel driveway #89
We are probably not helping our OP much her at this point; but clay content maters, if a specific pit has more clay content, and it comes Wet, you'll be fighting pumping rock for days and days before you can finish and prime/Pave. For road work, I'd always prefer it come too dry, and we add water o site, than too wet, and we are scarifying and trying to dry it.
/ Compacting gravel driveway #90
That's why I time my products delivered at least a week after it rains. But in the grand scheme of things, how many gallons of water does gravel hold? 250 gallons is a ton. I've never seem dripping gravel, or crushed stone for that matter. But not what I ordered...
Most crushed gravel and stone can absorb about 2-3 % of their weight in water to reach a saturated surface dry (SSD) condition. So one ton could contain 5 - 7 gallons of water. Most quarries also wash their stone, so matter what, it will have some water.
DOOSAN G25KW GENERATOR (A60736)
DOOSAN G25KW...
2014 LOAD KING BELLY DUMP TRAILER (A58214)
2014 LOAD KING...
2019 FORD F-350 FLATBED (A60736)
2019 FORD F-350...
2025 GPS Trailer (A56857)
2025 GPS Trailer...
2014 FREIGHTLINER CASCADIA (A60736)
2014 FREIGHTLINER...
20' SINGLE AXLE INDUSTRIAL TRAILER (A59823)
20' SINGLE AXLE...
