Compacting gravel driveway
   / Compacting gravel driveway #71
I lay a windrow of blue shale down one side and a windrow of river gravel down the other side. As I work and shape the drive it blends together and sets up like concrete. The last time my main drive was done I was 14. I am now 68 and shape and smooth it each spring to keep it up. It never gets more than an imprint of a tire no matter how much rain we get.
   / Compacting gravel driveway #72
I'm getting crashed stone delivered and spread on my old gravel driveway. I will crown and level it. Then a guy with vibrating roller will come over and compact it. Would it be a good idea to have stone dust spread on top before compacting? Please share your experience/ideas/suggestions...
Ive never done it but around here u can get ash fines from the beet factory hve heard it really packs down , might try a semi load
   / Compacting gravel driveway #73
It would be a waste of money. In a steady or heavy rain, the stone dust will just wash away. What grade of gravel are you getting? If you're getting 57's, what I do is put fill dirt on top of the stone before you grade and crown it, and that material will mix in with the stone and it will work like a binder. We have clay where I live and that is like glue when mixed with 57's. Then you just grade, angle back to the center to form the drainage slope and then back down the center with your scraper blade gently knocking the center back and that will form a natural curved crown. Rolling that with a tire roller will work great to pack it and jam the dirt in with the stone. Some of the dirt will run off the top with rain, but underneath it will pack well. I used crusher run on our 1/2 mile long driveway using that method back in 1999, and then I graded it and crowned it. The dirt from the sides of the road acted as a binder when I angled the crusher run back to the center and then when I backed down using my blade, I got the crown I wanted and I had the bucket down as well that smoothed it. I never had to pack it, since the bucket did some packing, and I've just been regrading my road since 1999. I have not purchased any more gravel since that time, although I'm finally getting around to need it. It took 8 loads of crusher run to do the top finish back then, but I also prepared the base by grading and putting a slight crown on it first. I also removed any large stone that worked their way up during the prep. The driveway came out so smooth and solid, I could drive 50 mph on the road.
   / Compacting gravel driveway #74
Wet gravel is heavy. Gravel is also delivered by ton weight. When you buy wet gravel you are also buying water at the price charged for gravel.
That’s weird. Here in Western Washington we pay by the yard!
   / Compacting gravel driveway #75
We used to use #2 crusher run for the base for all our parking lots and roads we built when is was working.
This was always specified by the engineer. This has fine dust in it from being run through the crusher. Wet it down good with a hose before compaction ! I would be careful with the vibrating roller. I assume it would be a 10 ton.
   / Compacting gravel driveway #77
The shale packs like concrete, but we can't buy it where I live. I don't use river stone, because rounded stone tends work against packing. I've seen a lot of people using shale in the Northeast. They also have natural gravel pits up there from the glaciers, so they don't use crushed stone since it's so expensive. You only tend to fine crushed stone and crusher run used for highway projects.
   / Compacting gravel driveway #78
Probably because it rains so much in Washington State it would be hard to get dry gravel. :D
I let people believe that and while it is partially true I believe it rains just enough!
   / Compacting gravel driveway #79
I had a Nephew that lived in Seattle. He loved it. To many people and people noise for me. I really liked the Public Transportation system though.
   / Compacting gravel driveway #80
I'm blessed with a 3200 acre pasture that is full of it. Trade shale for sand with my river rat neighbor. It makes a durn hard drive that is still workable.
207279 (A52708)
207279 (A52708)
2024 Superior Utility Trailer, VIN # 4M8EZ1426RD000880 (A57453)
2024 Superior...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Service Truck (A59230)
2023 Kubota U48-5 Compact Excavator with Angle Blade and Hydraulic Thumb (A56436)
2023 Kubota U48-5...
Forklift (A56857)
Forklift (A56857)
