cat 1 quick hitch bushings needed
/ cat 1 quick hitch bushings needed #1
LittleBill21
Elite Member
PA
Mahindra Max 26XL, White
/ cat 1 quick hitch bushings needed #2
They are about $5 each at Tractor Supply. You don't need the fancy ones with pins.
so do i need 6 per attachment? i am reading i need cat 3 bushings?
/ cat 1 quick hitch bushings needed #5
Both my quick hitches are the Land Pride QH15 Cat 1. I have 2 bushings on each implement, on the pins that slide into the quick connect hooks. I don't use them on the top hook.
While considering a quick hitch note that all implements you plan to use must have approximately the same attachment width. Mine are not so I went with Pat's Quick Hitch instead.
do you need bushing per implement with Pat's?
/ cat 1 quick hitch bushings needed #8
Not sure how many attachments you have, but if you look up... "Lift arm bushing" on tractor supply, you'll see that you need. For my quick hitch, I needed a cat 1-2 and a cat 2-3. Made for the best fit so my attachment wasn't bouncing around. You might be able to buy in bulk of you have multiple attachments?
/ cat 1 quick hitch bushings needed #9
With Pat’s you buy either the Category 1 or 2 hitch. If you’re using a category 1 implement on the category 2 hitch, you will need the reducer bushings for the implement pins and top link.
/ cat 1 quick hitch bushings needed #10
I use 1 inch water pipe on my CAT 1 pins and hold it in place with a bolt and elastic lock nut....
Don't think this "kit" would be unreasonable...
That is a good price for all those bushings!
For most of my stuff, the "pipe" style bushings work fine and, as mentioned, they are made to be "nested" to achieve whatever category you need for your quick hitch. However, some attachments (like my overseeder and weight box) are really heavy and tend to slide around a lot and need the shoulder style bushing to keep them secure. Figuring out which attachments need which style of bushing has been a bit of trial and error for me.
/ cat 1 quick hitch bushings needed #11
Not sure about the word "reducer" used here....
/ cat 1 quick hitch bushings needed #13
Totally agree, and get the bushings for the top link also. The top link and lift arms take different size bushings. But they are cheap enough. A pair of bushings usually are priced around $3.
pat doesn't use washers? i see washers mentioned in the reviews?
/ cat 1 quick hitch bushings needed #15
I have a mixture of bushings and lift pins on my equipment that I set up for my quick hitch. I started buying the expensive ones to slide over a cat 1 pin and secure with a roll pin
Then I either used cat 3 pins or cat 2 with a 3 bushing tack welded to it.
You have to drill out the mounting hole to use the larger pins. But you wont bend them with a compact tractor.
/ cat 1 quick hitch bushings needed #16
I will say, my bushings for my quick hitch are used on my flail. Its lift pins go between 2 pieces of metal that hold the pins in. Now if you have equipment that has the one side mounted pins... That other type may be a better option. These would rattle out if the bushings weren't "sandwiched" between the 2 pieces of metal.
I would like to post a picture to explain what I mean. But the app won't let me and hasn't for about a year I bet. Admin has no idea, so on a side note... If someone knows how to fix that, let me know.
/ cat 1 quick hitch bushings needed #17
What operating system are you using? If it's Windows on a PC, just right click on the picture and select "copy". Then right click again and "Paste" it in the space along with your reply. Make sure the cursor is at the spot where you want the picture to appear.
/ cat 1 quick hitch bushings needed #19
I'm using the app on Android. I'll have to try that and see it works sometime... Didn't even think of that idea.
Edit to add... Copy and paste doesn't work in the app.
/ cat 1 quick hitch bushings needed #20
I used some 3/4" black pipe. Cut it to length the slit it. Opened it up into a U then tack welded them to the bottom lift arms. If they wear out, they're easy to cut the welds and replace. It's soft iron (steel) so they won't wear the pins or my quick hitch.
1143 (A63745)
1143 (A63745)
2017 Ford F-250 Ext Cab Pickup Truck (A61573)
2017 Ford F-250...
Street Sweeper (A60352)
Street Sweeper...
FLEX HEADER REEL FOR 20' HEAD (A63291)
FLEX HEADER REEL...
E-Z DUMPER T/A DUMP TRAILER (A63291)
E-Z DUMPER T/A...
Jacobsen LF510 5 Gang 100in. Commercial Reel Mower (A61572)
Jacobsen LF510 5...
