Ford 1210 Lift Fail
   / Ford 1210 Lift Fail
So, look at the pic below, if oil came out from the port on the left of lift cylinder assembly with an o-ring seal then you are good as that is indication of pump working along with lift spool valve (3-point). it is good to have the gauge but you do not need it now.
View attachment 882013View attachment 882014
Now as far as pressure. The hyd pump is a positive displacement gear variety. The pressure it develops along the flow is based on engine RPM. At the pump rated flow (GPM) and about 2400 engine rpm it should develop around 2100-2300 psi. That pressure is dangerous so need to be careful attaching or detaching pressure gauge there.
You need to look the orientation of the seal you have installed. That's where i suspect the culprit is.
JC,
Great information. Yes, oil did come out that hole you indicated, and was turning motor with starter. Was pretty good stream. The seal was installed exactly like the pic you sent above. I pulled the screen and the screen was dirty but not so much that oil was totally restricted. Will find a new screen and try that route. BTW, there is a smaller hole on the other side of the head directly opposite that one with the O ring. But i dont see that in your pics, is mine different for a reason? Wish i had taken pics of it all before reassembly. May have to pull it apart to get pics as a permanent file.
JC,
Just wanted to mention this as added info: when i pulled the head and piston out , the sleeve stayed in. I pulled the piston with a magnet and was difficult to get out even with the bad seal. I tried to get the sleeve out by wiggling it and it wont budge. Is it possible the sleeve has expanded beyond the size of the piston? allowing the oil to seep around it?, OR can the sleeve be cracked ? I did notice that it was hard to get the piston, with seal, back in but it was easy to slide after about 2 inched past the cylinder top? Grasping at straws here as am lost. Logic says it should work.
JC,
OK, now i have another problem. I pulled the input filter and was trying to find a new one. I used this number SBA340500340 and there in none to be had, anywhere. So what do i do now? Do you have a source for an alternative filter? I think the old one is too far gone to cleanup and reuse. Fould out a long time ago to never rely on CLEANED UP filters.
   / Ford 1210 Lift Fail #14
You will not find a new screen. You need to reuse it. I would get an old tooth pick, get a plastic dish, out diesel fuel in it. You need to soak the screen in the liquid and use the tooth brush to clean. Do that several times along with using compressed air. Mine was plugged just the same. that screen is made out of Stainless steel and it is of a very good quality.
   / Ford 1210 Lift Fail #15
In the case of piston, if you remove what ever you have hanging on 3 point, then you can simply raise the 3 point arm, that in turn will rotate the counter shaft and the push the ram rod forward and the piston easily will come out. In my case , I was able to take sleeve and piston out together as one unit. I then used a wooden hammer handle to push piston out of sleeve, that simple ! look at the pic below you see 3/4 round circle that the end of sleeve sit on. I would recommend to get a rubber mallet, or dead blow hammer and a wooden stick about 1x1 acting like punch and then strike the edge of the sleeves to free it up. It should come out easy. I don't think you can crack the sleeves. The back of piston has a concave piece that the ram rod rides on. There is potential side to side force that can potentially deform the sleeve... highly doubtful in my opinion.
   / Ford 1210 Lift Fail #16
I addressed that in couple of posts earlier. Need to re-use. Now if I destroyed the the screen then I would have Jerry rigged some in line filter of some sort. Remember that the screen is on the suction side of the pump and does not see much pressure, so it does not need to be so robust. See the before and after below.
   / Ford 1210 Lift Fail #17
Yes the screen was meant to be carefully cleaned in Diesel fuel & reused.
   / Ford 1210 Lift Fail #18
That hole is over pressure release so the hyd oil could bypass the piston so seal would not be damaged. Imagine having a 700 lbs brush hog and hit a big hole or something. The pressure developed , looking at the weight hanging and moment arm can cause a huge torque and developing a very high pressure in the lift system, perhaps higher that the pump can develop. That is shock loading and there is a check valve with calibrated spring that divert the shock load to the diffy, saving and giving seal a long life. Below I have a pic of that relief mechanism.
   / Ford 1210 Lift Fail #19
yup, I used a paint tray and put a cup of diesel and did not take much before it was OEM clean.
Ut oh. Thats not good. So i guess the filters are like the seal, none made anymore? I found , after i paid high dollar for one, the size of the seal and you can find them on Ebay for way less than $10 dollars. I simply measured the high dollar one and recorded it and looked on Ebay and they are there. From China and takes a couple of weeks to get. Size is 48MM x 60MM X7MM. Got two on them on the way.
Thanks for that info. Will dig out my cleaning materials.
Club Car Electric Utility Cart (A55851)
Club Car Electric...
2023 FORD F-650 SUPER DUTY CAB AND CHASSIS TRUCK (A59823)
2023 FORD F-650...
2009 Jeep Grand Cherokee 4WD SUV (A59231)
2009 Jeep Grand...
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
2019 Ford F-550 4x4 Dur-A-Lift DTAXS39 39ft. Bucket Truck (A60460)
2019 Ford F-550...
2012 JACK COUNTY TANK 130 BBL STEEL (A58214)
2012 JACK COUNTY...
