Flail Mower Let's talk flail mowers
/ Let's talk flail mowers #8,041
If they do not have a stocking dealer right now SICMA they can have
a dealer in England will ship them to you if they have the hammer
knives in stock.
The SICMA folks in Italy would know if any of their stocking dealers
in North America has hammer knives, otherwise you would have to
wait 6 plus weeks UGH, for a mixed freight container from Europe.
I could contact SICMA directly about a replacement set of hammer knives
as there should be zero issues with US customs and Canadian customs
as Italy still has Most Favored Nation status as far as I know.
Rome is 9 hours ahead of you so you could call them at midnight your
time and reach SICMA at 9AM their time on sunday morning your time
being midnight P.S.T.
/ Let's talk flail mowers #8,042
I am brand new to all of this and need a recommendation for a flail mower to pull behind our new JD 5090E: 90hp engine, 75hp PTO, 8000lbs, 92" wheelbase, cat 2 hitch.
A few weeks ago we closed on 92 acres just outside Austin, TX. Mostly flat with black clay soil. There are many unmaintained and overgrown acres that we want to clear and restore back to its natural Blackland Prairie state. The mower needs to be able to handle the heavy brush as well as provide good mulching (to help the native flora). We also plan to use the mower to keep some grassy areas and lawns cut and hopefully maintain some trails.
I figured a mower about the same width as the tractor would be a good balance between speed and maneuverability. Especially with the ability to side shift.
We need to start mowing very soon so availability will be a factor.
I have been looking at the following models:
  1. Maschio CORAZZA 210S/230S
  2. Del Morino FARM 214
  3. Peruzzo Bull 2200
  4. WoodMaxx FM-96H
  5. Nova MXZ-220
The WoodMaxx and Nova are nearly 1/2 the price of the others, which makes me worry about their performance and reliability - but I know price does not always equal quality. I like high quality tools and am a buy-once-cry-once kind of guy, but obviously don't want to waste money for no reason.
They are all "heavy-duty" mowers, which I am not sure if we need, but the point may be moot as the HP of our tractor exceeds most of the light and medium duty mowers I have seen.
Is there any objective basis to the marketed max material diameter cut capacity? The Maschio CORAZZA claims 4" and the Peruzzo Bull claims 4-5" which seems crazy big while the WoodMax FM-96H describes it's hammers as for "clearing saplings 1in diameter or less" which seems quite small. The Del Morino doesn't make any claim at all. Are we talking 4" of fir, oak, or mesquite here?
Appreciate any and all advice. Thanks!
- Mike
/ Let's talk flail mowers #8,043
  4. WoodMaxx FM-96H
  5. Nova MXZ-220
- Mike
With that HP I wouldn’t go with anything less than 8’ wide.
The only way less would be with a ditch bank flail.
/ Let's talk flail mowers #8,044
I tend to cut small saplings and heavy growth/unfamiliar areas with my medium duty rotary cutter first then maintain with my relatively light Caroni 6’ flail.
/ Let's talk flail mowers #8,045
Need help identifying this flail mower that I am planning on buying ... I know it need some knives and ? Thanks for your help.
/ Let's talk flail mowers #8,046
I regularly mow some rough, rocky trails. Over the past 23 years, that work has slowly beaten my Wood 5' brush mower almost to death. I'm looking at replacing it. I've been considering a flail mower, but I'm a bit concerned that it's really not the right tool for this kind of work. I'm not really concerned about a nice-looking cut: this is just to keep the brush and weeds down so folks can easily walk the trails, rather than wade through it.
I’ll regularly have to raise it up well above typical mowing heights to clear some of the rocks - and I’ll forget where some them are and beat on those rocks.
Will a flail mower stand up to that sort of thing?
Currently mowing with a 23 year old 33 HP New Holland TC33D. Some chance I might upgrade to a +/- 45 HP tractor one of these days. The TC33D is great for getting in to tight places, but a little on the small side for some of my forestry work.
/ Let's talk flail mowers #8,047
hardwood76
Does it have a roller in the rear (don't see one in your photo)?
/ Let's talk flail mowers #8,048
  4. WoodMaxx FM-96H
  5. Nova MXZ-220
- Mike
I am sending you a PM
/ Let's talk flail mowers #8,049
I have an offsettable ditch bank flail with the heavy hammers, it does a nice job and I have hit some rocks with it. It is nowhere as tough as my old brush hog is. I use it more then the brush hog as it can be off set to mow which is nice in many places. But if I'm going into a rough pasture were I'm mowing mostly in reverse and backing into hedgerows and rock piles it is the brush hog I go with.
/ Let's talk flail mowers #8,050
I'd also be interested in recommendations for a ditch bank mower for my M59 HST for cutting along field edges and fence lines to control weeds and brush. I have rocks and roots and fallen branches to deal with.
/ Let's talk flail mowers #8,051
Either a Maschio or Del Morino Orchard and Vineyard boom mounted flail shredder with cast hammer knives.
/ Let's talk flail mowers #8,052
I have the chinnese version a Victory bank mower their heavy duty model in 78";
I also have a boom arm mower it's a Twose 400 hedge trimmer.
It is a heavy mower and it makes my Branson 8050 bounce around a wobble a bit especially when you get everything off camber. One of these days I'll mount it on my NH 8160 to see how much better it feels.
The ditch bank mower,
And this is the boom arm mower, it is also a handfull at times on a tractor that's tipping the scales at a bit over 11,000 pounds before the mowers.
Both mowers are very handy and do a good job, the ditch bank mower is faster to hookup and cuts a wider swath and is a bit easier to work with.
The boom arm mower is much more versatile and has more reach, it also takes much more attention while mowing as the terrain changes and obstacles get in the way.
They both have their place and I use them both at times along with a brush hog.
Both of them are equipped with "hammers" not the Y blades.
/ Let's talk flail mowers #8,053
  4. WoodMaxx FM-96H
  5. Nova MXZ-220
- Mike
I have a Peruzzo brush bull 2200 behind my 40hp L4060. It's a bit heavy & I'm tapped out on HP a lot, but it runs it. I can cut wrist sized scrub oak with it. I've ran into football sized rocks a number of times & the machine is fine. I did take some damage finding a 70lbs chunk of railroad track.
Bushings on the slide mechanism have been a weak spot, but not super problematic. Had to replace roller bearings which wasn't easy.
I'd think twice about another Peruzzo Brush Bull 2200, but mostly related to being a hair big for my machine than durability. Would be fine for a 90hp machine.
/ Let's talk flail mowers #8,054
View attachment 881568View attachment 881569
View attachment 881571View attachment 881572
View attachment 881573View attachment 881574
The county "mows" the side of the local road with one of those, varying ground as well as in a vertical position to shred the tree/shrubs as they grow back every few years to crowd the road.
/ Let's talk flail mowers #8,055
OOPS!!!!!
The blades seem to be holding up fairly well to some hard abuse. But I may start hunting for a new set, or try to make my own.
4130 Chromoly?
/ Let's talk flail mowers #8,056
I bought a 10' Maschio Tigre 300 last June. I'll never own a brush hog again. It's built like tank, can clear up to 4" woody undergrowth and then turn the pasture into near yard quality. They are well worth their high cost and weight.
/ Let's talk flail mowers #8,057
OOPS!!!!!
View attachment 883399View attachment 883400
4130 Chromoly?
Wow what was that, was it just weeds or did it have some wire mixed in?
Couple of years ago I bought two new sets of 96 side slicers from Flailmaster at excellent price and they have stayed pretty sharp so far!
Not sure what kind of steel, but it's very hard.
Old Vs. new:
/ Let's talk flail mowers #8,058
4130 Chromoly?
Finding the correct alloy is just the start. Getting the heat treatment right is a major part of their longevity: Too soft, and they wear too quickly. Too hard and they are brittle, chipping or breaking when they hit something hard (and flinging bits of shrapnel when they do).
A lot of the chrome alloys are very particular about their heat treating - much more so than regular high-carbon steel.
/ Let's talk flail mowers #8,059
Hello Flail Nation.
I’m looking for a Canadian source for hammer blades for my Sicma TE200. Tram sales in western Canada used to carry the Sicma line but no longer. They apparently have 7 hammers left in stock. I need 26. I have reached out to Flail Master but have not heard back yet. Any one on here have a source for these. I’m not opposed to ordering them from the USA but a more local source would be better.
Thanks
I found a Canadian source for the flail hammers. Found them at a company called AgriCan in Quebec. $460 for 26 hammers delivered to my door in NE BC. I bought the bolts and nuts locally. They are not an exact match but very close. Tested them out today and I’m happy with the results. A lot less vibration as well, probably due to the odd chunk missing from a few of the old ones.
/ Let's talk flail mowers #8,060
It was a mixture of grass and blackberries. I have a mixture of the larger Himalayan blackberries, and a local variety that my neighbor calls "mountain blackberries" with smaller berries, and a very tart taste, and they come about a month before the Himalayan berries. But those mountain berry vines are very stringy, and I had some of those balled up in it. No wire.
Still, with a few stickers, a mess to pull it all out.
UNUSED INDUSTRIAS AMERICA C10 10' FEEDER TROUGH (A60430)
UNUSED INDUSTRIAS...
CATERPILLAR 239D3 SKID STEER (A65053)
CATERPILLAR 239D3...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
STORAGE FEES (A59914)
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A61307)
2-Row Peanut...
2022 New Holland Boomer 45 (A64126)
2022 New Holland...
