etpm
- Joined
- Jun 30, 2021
- Messages
- 2,386
- Location
- Whidbey Island, WA
- Tractor
- Yanmar YM2310, Honda H5013, Case 580 CK, Ford 9N
If the rod bearing caps were removed can they just be bolted back on and torqued properly? I ask because since the pan is off and the rod ends are exposed why not just unbolt the bearing caps and then try to push the pistons up. If they can't be moved then the problem is stuck pistons. It may even be possible to tap on the underside of the pistons if they are stuck to try to get them moving.
Eric
Eric
