Stuck yanmar 165D
/ Stuck yanmar 165D #62
I don't think it's Cyl. problem. Just a Guess! I'm with Ca. I would be looking at trying to look inside the Bell housing. The Ford Clutch that was stuck and you could see were someone tried to use a Prybar on the Clutch itself to get it loose. The shop agreed as soon as he showed me it. Prybar!
I didn't see it split but kind of wish I did. To be stuck that bad my guess Rust!.. What are we looking at with your tractor? Major rust and corrosion.
/ Stuck yanmar 165D
I think a talk with the shop is in order.
/ Stuck yanmar 165D
Looking at the loader under frame, I could see where it could possibly be done by myself. Just detaching the rear under frame bolts from the rear would leave the rest of it intact and all I would have to do is place some blocks under the loader frame. Then the tractor could be separated and the rear end supported. But, I think I will have the pros do it
/ Stuck yanmar 165D #65
The satisfaction of doing it yourself would be huge in this case, over just paying someone to do it. You have so much time and effort already invested in this project!.
However, there is a lot of concern about doing your first split. My first time ended up getting sold rather than splitting it, but that tractor was HUGE! (Ford 7710 4x4 with a Bomford boom mower on it)
We all have to make our on decisions, but seriously...I would love to hear you say that you did it, over paying someone else to do it.
David from jax
/ Stuck yanmar 165D
I hear ya.....I will have to think on it
/ Stuck yanmar 165D #67
Are you anywhere close to other Yanmar owners who might have done it? (You might update your location in your profile; it can help others help you)
Or have someone with mechanical talents who might undertake this with you just for the fun of it?
All the best,
Peter
/ Stuck yanmar 165D
Thanks for the link.....seen it before. Just not sure I want to do it. I live rural Anamosa, Iowa
/ Stuck yanmar 165D #70
290 hours would make it barely broken in. Did the neighbor explain why they parked it 7-10 years ago? The rust/corrosion could easily be from sitting in an unvented shed, but strikes me the history may be more important as to why they stopped using an essentially new tractor. If you've already paid for it, they may be more forthcoming with the real story, and then you'll have some valuable info on both the tractor and your neighbor.
/ Stuck yanmar 165D #71
If you're positive it's stuck rings, try white vinegar (cleaner, not salad dressing) in the cylinders, then when she moves, a good flush with seafoam/oil/atf/penetrating oil/etc./whatever to displace the vinegar. then oil change.
/ Stuck yanmar 165D
My neighbor was a Lieutenant with the Cedar Rapids Police Department and on his days off, he did landscaping. He babied this thing as he does with all of his stuff. He parked it in his machine shed when he retired from CRPD and also stopped his landscaping as well. Where he parked it, that's where it sat until we moved it. Since we are here in Iowa and have some pretty wicked humidity, that is likely what caused the flywheel to get like that.
I just got the remaining ATF/xylene mix out of cylinders (they were now about 2/3 full each) and drained the pan. So, a fair amount moved past the rings. So, I'm leaning more towards flywheel now. Put a fresh filter on and oil in it. Will talk to repair guy this week on my days off.
/ Stuck yanmar 165D #73
Removing the loader is the hardest part of splitting the machine. And it's not that difficult to do really. A few YT vids to watch and you are ready to take it off.
I would drain the hydraulic fluid from the machine 1st and foremost before the split. The reason being, the suction metal pipe has a jumper hose to take off during the split.
Using 3-ton or better jack stands or even a section of a tree trunk at the right height will keep the back end fixed.
An engine hoist is best for the front end. I've also seen it done with the 3-ton floor jack and ratchet tie-downs. Many YT vids out there.
The rest of the split is using your cordless impact with impact sockets. Just first a few short bursts to free the bolts.
Even this thread on the site is for a bigger machine than yours. Wasn't hard for him to do it either. Plenty of images to see.
/ Stuck yanmar 165D
Thanks, but I know I will be in over my ability on that, just don't have the resources. I will take it to a shop
/ Stuck yanmar 165D #75
I bought our YM165D back when they were the newest offering from Yanmar. It would look like yours....except I loaned it out after 40 good years and a flood took it away and destroyed it.
Anyway, it does't look like rings to me. I think you should take off the top of the transmission case and see if things turn. It is easy to remove the shifter cover. Just a few bolts. You can resuse the gasket with some sealant or even without. The gasket is above the fluid level.
Your trick of using the PTO only works to turn the engine if the transmssion is not stuck.
Also, disconnect the front hydraulic pump if you have one forward of the front crankshaft pulley. It disconnects with a masterlink on the chain coupling.
I don't think any of this is beyond your ability. Frankly I like your work better than any modern shop I know of. And if you are close to Colorado, give me a personal message. I might be able to help - I've been helping people with Yanmars since before TBN.
rScotty.
/ Stuck yanmar 165D
How do I disconnect the front hydro pulley from the master link? I want to give that a try
/ Stuck yanmar 165D #77
Well, the front hydraulic pump driven off of the crankshaft nose was an option for the YM165 loader. The loader could also be driven from a diverter valve connected to the tractor's own hydraulics.
So first thing is to see if yours even has the front pump. It may not. But if i does the pump is obvious there behind the front bumper. There are two hoses, the Cessna pump, and the chain coupling.
The master link may/may not be accessible. Normally one would turn the engine to gain access if the master link is hidden. If not, I have no easy ideas....But it is worth a look, and those pumps can sieze up.
The masterlink has a spring clip on one side. Just like a bicycle chain. You expand the clip by twisting a screwdriver in the slot and then with your other hand simultaeously move the clip laterally so that it comes off. Wear safety glasses.
/ Stuck yanmar 165D #78
According to the parts manual it may not have a master link. Don't know yours is like this but something to look at.I think the electric clutch set up was primarily for a belly mower or snow blower but really don't have a clue or a clue what you have.
/ Stuck yanmar 165D #79
Winston, that diagram shows something completely different. That is a picture of a front PTO. The front PTO was also an option for the YM165, but I never saw one that had both a front PTO and an auxiliary front hydraulc pump.
They are not related.
/ Stuck yanmar 165D #80
Sort of thought that but just putting the page out there in case that is what Millard has.
John Deere 5055E (A64126)
John Deere 5055E...
2006 Ford F-750 Fuel and Lube Truck (A59230)
2006 Ford F-750...
2018 FORD F-150 (A65643)
2018 FORD F-150...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A61307)
2-Row Peanut...
Landhonor Mini Skid Steer Quick Attach Grapple Bucket (A66285)
Landhonor Mini...
New/Unused CFG Industrial H15R Mini Excavator (A65583)
New/Unused CFG...
