False alarm. Turns out there is a metal shield (2nd picture, around the shaft) to protect the bottom seal that got loose for some reason and was making noise on certain occasions. Since I have the gearbox out, I'll still take the cover off and inspect it and also try to figure out why the shield got loose in the first place. Probably brush got behind it somehow.Did some mowing yesterday. It was mowed about a month and half ago, so it was only about 2 ft tall weeds and what not. Not too bad. I typically deal with stuff as tall as the ROPS and up to 3" thick.
Oh and somewhere in that brush cutter, there is a bearing going bad. It only makes a noise every once in a while but it's there. Probably just a bad cage on one of the bearings. May treat it with a new pair of chains as well.
then worked on the field for a few hours.
Nobody is doing hay nearby anymore, what once was farmland is now houselots. Where the nearby dairy used to be is now Kohls. Home Depot, Lowes and Walmart have stores where the cattle used to graze.
This guy is finding it easy to find lunch. I laugh at "no-mow May", snakes and field mice love that tall grass.Soon, you will get to the part where Jesus Christ pays for all of our sins, so it’s all well and good to work it continuously now.I read in the Bible that we should let the land rest every 7th year
willy
Had a decent day today, a benefit tractor pull just down the road,
My brother took his little WD's down and I ran one of them. He has 2 WD's and my Nephew has a WD and an IH 460 to play with
He pulled in the 3500#, 3 1/2mph, 5 mph and open class, he won in the open and did good in the others, beating his grandson by less then 2 feet in each.
In the 4000# class we both pulled along with his grandson,
In the 3 1/2 mph class all three of use did good a couple ribbons.
in the 5 mph class the tractor I was on did real well, pulled a second place and later we learned the 1st place was DQ'ed for speeding so actually ended up as first,
the others were in the top 5 or so.
Then we got rained out before the 4500# class could pull, I ended up coming home, the others waited it out and finished pull about 5:30 or 6 this evening.
Haven't heard how they fared yet.
My brother,
and the other WD that I pulled,
