UTV's and ATV's general discussion.
/ UTV's and ATV's general discussion.
No grunt, no spin stump pulling today. Kinda did think it would fell like towing.
/ UTV's and ATV's general discussion. #352
I needed to check where I have to install some drain pipes to make it easier to get the tractor through the woods. Figured it was much easier to jump in the SxS and make a loop around.
/ UTV's and ATV's general discussion. #353
Been using my Can-am pretty much daily around my place. Putting a lot of miles on it. Can't believe how handy it is, hauling stuff around, spraying Mormon crickets, spraying weeds. Love this thing!
/ UTV's and ATV's general discussion. #354
Nice! I think I just rolled 100 miles tonight, only had it for about two weeks. It is a nice machine, with a great ride.
What is the pipe on the roof, I never saw anything similar.
/ UTV's and ATV's general discussion. #356
Mine had nearly 4000 miles on it now.
There's actually 2 pipes up there. One of the things Can-am could have done better(at least on this particular year/model) is the location of the OEM air intakes. Both intakes (belt and engine air) are under the bed of the unit. Here in the desert, this time of year a lot of the roads and trails develop silt beds - very deep, very fine dust. All that dust kicked up by the tires gets sucked into the belt chamber and the air filter housing - it can completely plug up an air filter in 20 miles of driving. Can-am sells "snorkel" kits that move the air intakes up high - but they are super expensive and obstruct the view through the rear view mirror. So I made my own "snorkel" kit using 2" ABS pipe. Only cost a few bucks and now both air intakes breathe from the top of the windshield. Since I made this mod I've not had to clean out either the belt chamber or the air filter. It may look weird...but I don't care!
/ UTV's and ATV's general discussion. #357
I could get used to the appearance, especially knowing what it does.
Our Club Car 1700D uses the driver's side boxed frame rail as the engine air intake and takes air at the very front of the rig near the radiator. Not sure how many makes do that?
/ UTV's and ATV's general discussion. #358
I need to check the electronic fan on our Honda 700-4; BUT ours gets hot when not running down the road. It doesn't really like high work load, slow speed stuff, and the overheat light comes on fast.
No problem like that with our 2019 Honda 700-4. Like mentioned before, may need to check your radiator and coolant level.
/ UTV's and ATV's general discussion. #359
As I recall, that's how it is on my HiJet, too.
/ UTV's and ATV's general discussion. #360
Not a good place for something that could see deep mud or creek crossings in our neck of the woods. Any thing below at least seat level is likely to suck water in my uses and I don't go looking for mud. When we flash flood even tractors do some wading to clear obstructions in creek or ditches to allow the water move.
2013 Hyundai Volster Coupe (A59231)
2013 Hyundai...
Swict 7' Fork Extensions (A60463)
Swict 7' Fork...
Giyi GY-CYHC Mini QA Side Shift Forks (A60463)
Giyi GY-CYHC Mini...
2020 FORD F-550 CAB AND CHASSIS (A60736)
2020 FORD F-550...
FENCE PANELS (A58214)
(INOP) VOLVO A30D OFFROAD DUMP TRUCK (A60429)
(INOP) VOLVO A30D...
