Reduction gear starter for the YM2310?
/ Reduction gear starter for the YM2310? #1
etpm
Whidbey Island, WA
Yanmar YM2310, Honda H5013, Case 580 CK, Ford 9N
Hey all,
I was reading about reduction gear starters for other Yanmar engines and wondered if anyone knows of one for the YM2310? About 6 months ago I bought a new solenoid for my tractor and it has started to fail already. That business where you turn the key and there is the loud click from the starter gear being thrown into the flywheel but the motor doesn't energize. The solenoid is not rebuildable. I am upset the new solenoid has failed so soon. But not terribly surprised. So I am thinking that a new starter might be the best. A gear reduction starter. Anybody know of a part number?
Thanks,
Eric
/ Reduction gear starter for the YM2310? #2
Hey all,
Thanks,
Eric
Long ago I posted a longwinded description of the higher-wattage gear drive starter I put on the YM240. It cranks frantically fast. Recommended! Any gear drive starter specd for yours or a higher hp Yanmar of the same era should fit.
Just match the rotation direction, number of gear teeth, and the mounting hole diameters and spacing, and look at a photo to see that the solenoid electric motor on top won't interfere with anything. The one modification I needed was the wire down from the key switch had to be extended a few inches.
Stuff from Amazon is returnable if it won't fit, and the starter/alternator vendors there with thousands of good reviews are a good source. Mine came from DB in 2006, it still works like new.
/ Reduction gear starter for the YM2310? #3
  • Tech_Electrical_Starter Motor_Reduction Type - Rollaclub.pdf
/ Reduction gear starter for the YM2310? #4
Check your YM2310 p/n to the ones listed in this snip. Price at the time was really good.
/ Reduction gear starter for the YM2310? #5
Had this one rebuilt in 2011. New Solenoid and rebuilt the motor. $72.76.
The starter for Ym2310 SM-1277 and the YM2000/240 Starter SM-146 Fredricks so the Motors are different.
May not be rebuildable. My rebuilt works as it did when they rebuilt it. On it today and The Oil lights out in the count of 5. Rain or shine Hot or cold!! ;)
2012 HINO BOX TRUCK 26FT NON CDL BOX TRUCK (A59905)
2012 HINO BOX...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2014 Dodge Charger (A59231)
2014 Dodge Charger...
2023 FORD F750 CAB & CHASSIS (A57880)
2023 FORD F750 CAB...
2015 GENIE GTH-1056 TELESCOPIC FORKLIFT (A59823)
2015 GENIE...
