Oil & Fuel fuel injection pump
/ fuel injection pump #21
Loosen the lines AT THE INJECTORS (all of them)
and crank the engine and look for fuel squirting out of the loosened lines..
If no fuel out of the lines, that means the pump isn’t pumping..
The mechanic is going to pull the pump.. and probably order u a new one..($1100.00 + service call)
It’s probably just a stuck control rack in the inj pump.
/ fuel injection pump #22
What would cause this type of problem in a very young, low hour tractor?
Well Im not a mechanic and the tractor is under full warranty so Ill let him do his thing
Am I correct in saying this is the fuel pump?? Actually disregard ...it is the fuel pump....LOL
/ fuel injection pump #25
I have the same problem with my CK2510. Was running fine and then wouldn't run. Recognizing my mechanical knowledge limitations I ended up having it flat-bedded to a dealer 20 miles away. Only $145 for one-way. I deduced the same things ya'll are saying. Fuel issue, stop solenoid or relay, fuel injector (I hope not).
It ran fine after fuel filter change. The problem was at first intermittent. My fuel is fresh, I checked for fuel flow and even emptied removed and inspected the fuel tank and lines. That was when I called the flat bed. But the dealer is scheduling 2 weeks outs and drop-offs go to the end of the line, so I expect the soonest they will look at it is tomorrow.
My dealer is 2 1/2 hours but the actual dealer i bought it from is in St. Johns which is 4 hours away. So there was a mechanic supposed to come out last week from a John Deere dealer on the request from my Kioti dealer....never showed......was supposed to show up this afternoon and once again never showed up....My tractor has been in my garage for 3 weeks now and I cant get anyone to come look at it....I am glad though that its still under warranty but kind of useless if no ne is going to fix it....I plan on ordering a new fuel pump and having a mechanic replace it for me
I have checked all the fuses and also have ordered new ones just to have them on hand.....replaced the solenoid.....bypassed the seat safety control......checked the fuel filter and the fuel flows freely....Its just not getting to the injectors
whats the difference between a CK and a CX
/ fuel injection pump #28
Does the solenoid activate when the key is turned on??
Remove it from the pump, ground the mounting ear to ground, turn the key to start and see if the solenoid activates.
brand new solenoid....mechanic is coming here in the morning so Im going to let him do his thing
/ fuel injection pump #30
Basically appear to be the same tractor. Minor diff; I have a rocker drive pedal and linked brake pedal. CX has a quick connect bucket (nice) and a tilt steering wheel (nice). Some other creature comforts like arm rests, charging ports. Engine might be different block/displacement but HP seems the same. Mine is 2014
/ fuel injection pump #31
The problem I see with them are broken teeth on the gears, in the inj pump..
The broken teeth will lock the control rack either in the shut off position or the wide open throttle position..
Believe me when I tell you,
you really want this to happen in the s/o position.!!
/ fuel injection pump #32
CX 2410H weighs 2308 pounds; 87 cu. in. engine
CH 2620H weighs 2689 pounds; 101 cu.in engine
UPDATE:.....Dealer picked up the tractor and took it 2 hours away from where I live. 5 minutes after getting it off the flatbed, the Kioti mechanic had her running.
Turns out there was a fuse blown for the starter solenoid, a bad PTO Switch and two of the hydraulic hoses we switched around.
The previous owner had bypassed the PTO altogether.....*******.....So after a week I got her back in perfect order...Thanks to all who have assisted me with this pain in the ass problem......
2 Person Metal Pony Dolly (A64912)
2 Person Metal...
PORTA POTTY (A67714)
PRESSURE WASHER (INOPERABLE) (A68842)
PRESSURE WASHER...
2013 CHEVROLET CAPRICE POLICE CAR (A66091)
2013 CHEVROLET...
25057SFL (A64557)
25057SFL (A64557)
TAG 35" QUICK ATTACH EXCAVATOR BUCKET (A65053)
TAG 35" QUICK...
