Operating without a thermostat?
/ Operating without a thermostat? #21
With these older engines and the changing coolants available, I think it is hard to know what the best coolant is sometimes.
Good luck!
All the best,
Peter
I too would agree. You can't even find the old school green coolant anymore.
Prestone makes a non-long-life formula for, All Vehicles and All Years. Its the closest substitute for classic vehicles and machines.
/ Operating without a thermostat? #22
Yes, use what works for your engine, and you are comfortable with. If it isn't premixed 50/40, always use distilled water and use distilled water to flush unless your water source is naturally soft, low TDS water. Softened water is not recommended due to the higher ionic strength, specifically chloride that can cause corrosion to be accelerated.
Thanks for the tip on the Prestone. I missed that one six months ago when I was in the midst of coolant purgatory. One manufacturer discontinued the original coolant and was recommending a new coolant that would clog if any trace of the original coolant remained, and the engine cooling system was designed not to fully drain.:rolleyes: At the same time, I had a twenty year old engine designed for the toxic green coolant, and I was trying to find a reasonable replacement, with a bankrupt manufacturer. I wish I had known about it then; I sure could have used the Prestone. Sigh. Win some, lose some...
All the best,
Peter
  • Good Post
Reactions: irq
/ Operating without a thermostat? #23
All the best,
Peter
Some of those longlife coolants, like the poster images above have a limited shelf life in the bottle. Those coolants I would avoid totally. Yes, you are right, they get exposed to air with too much nitrogen and turn into SLUDGE ! Sludge will not cool any engine! I only use DI, distilled or twice RO water in a cooling system.
Ashland-Valvoline has this one, but I've never seen it in my area,
And PEAK,
/ Operating without a thermostat? #24
And PEAK,
bmaverick, I know what distilled means, but what does DI // twice RO mean as per water for cooling system?
I made the mistake of using my well water to top off my radiator in the El Camino and now I need to flush and change. I'll probably flush twice also, so I'm going to need quite a bit of distilled H2O.
And - I'm assuming that the three different types of antifreeze you show, are to be "stayed-away" from?!
Do you have a preferred brand that you use?? If so would you mention it? As with everything these days there are "numerous" choices in the antifreeze aisle and as pointed out - some choices have severe consequences. Thanks for any advice. Greg
/ Operating without a thermostat? #25
You might want to order a new radiator cap as well. After a time, rad caps loose their spring tension and won't hold any pressure and pressure is important because it raises the boiling point of the antifreeze.
/ Operating without a thermostat? #26
DI is deionized water and RO is reverse osmosis. I use distilled myself, readily available at any supermarket.
Both my Kubota's take ordinary green antifreeze and so does my diesel pickup truck. My focus takes long life and my wife's Burb takes Dexcool.
DI water is what they use +Urea in diesel exhaust fluid.
/ Operating without a thermostat? #28
Distilled water is steam vapor collected on a stainless hood into a stainless or glass basin.
DI water is De-Ionized. You can look up the process.
RO is Reverse Osmosis, going thru 2 times.
The three shown are the ones out there for ALL VEHICLES, FOR ALL MAKES AND MODELS. Meaning they are acceptable even of the old classics. These formulas are safer to use in the old systems, like your El Camino.
To flush out WELL TAP WATER, you will need to also use C-L-R. Well water is known to contain all kinds of things. My place runs both a sediment filter and then a 2-micron filter before the holding pressure tank. It's not quite RO.
As for preference, there is only one on the shelves in all the box stores, the Prestone. It in Walmart, Menards, AutoZone, etc.
The trouble maker coolants are the ones with For GM vehicles only or DexCool type formula. In fact the original GM DexCool formula had several Class Action Lawsuits for making sludge and destroying engines. GM with other woes then did a bankruptcy. The court then agreed with GM and gave a $500 voucher towards a purchase of a new GM vehicle as restitution. For the 17-million vehicle owners in the Class Action Lawsuit, it was the last day they would ever own another GM product. In fact, the boycott was very strong for a few years even after that. Only the 2nd US gov bailout saved them. Out of the 17-million owners, many were their own UAW and engineering employees. Entire generations of GM families walked away, swearing never to own their products ever again.
The original GM DexCool was also used in a few other selected vehicle brands outside GM too.
... and now you know the rest of the story, good day! -Paul Harvey
/ Operating without a thermostat? #29
First
Prev3 of 3
Unwatch
Today at 9:12 AM / Operating without a thermostat?
#21
[IMG alt="bmaverick"]https://www.tractorbynet.com/forums/data/avatars/m/225/225542.jpg?1614574142[/IMG]
bmaverick
Elite Member​
Sure you can. Autozone has it on the shelf and I don't buy the dilluted kind either. I mix mine with distilled water and use a Brix Refractometer to set the concentration. They are cheap and accurate.
/ Operating without a thermostat? #30
As I noted above, lots of customer-replaceable parts are the same as Datsun/Nissan of similar age.
I expect this includes your radiator cap so long as the pressure rating is the same.
That's what I have on the YM240. It was much easier to find, and cheaper, when defined as "70's Datsun".
/ Operating without a thermostat? #31
Just bought thermostat and gasket on Amazon. 18.99 free shipping. YM 336D
/ Operating without a thermostat? #33
bmaverick, Thank you for the detailed explanation and the clarification of the 3 pictured bottles. The advice of the CLR usage when flushing is also appreciated! I have the Prestone fluid on hand. I also have my well water to the house reverse osmosis & filtered, but I'll just go buy some distilled to be safest. I appreciate hearing "the rest of the story"! Greg
/ Operating without a thermostat? #34
Thank you for the detailed descriptions 5030. Appreciate the knowledge.
/ Operating without a thermostat? #35
Appreciate the thought but I have a cap tester and mine is ok. But I'll consider changing it when I flush since a new cap is small $.
/ Operating without a thermostat? #36
The 240 manaul clearly states use antifreeze At 40% soft water. What is the difference in type from back then ?. I use Diesel recomended Anti. At 35% Which is correct apparently. Doing it since 2008
/ Operating without a thermostat? #37
Can you explain what you mean here? I'm sorry, I'm not following the point or question. Thanks.
All the best,
Peter
/ Operating without a thermostat? #38
RUN The ANTI Freese AT 40% is what the 240 manual says. I run mine At 35% ?
2024 JCB 3TS8T Teleskid High Flow Compact Tracker Loader Skid Steer (A66734)
2024 JCB 3TS8T...
Jack Daniels Metal Decorative Sign (A66738)
Jack Daniels Metal...
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A63569)
2017 TROXELL 150...
2015 KEYSTONE BULLET CAMPER (A67714)
2015 KEYSTONE...
2015 GMC SIERRA 3500HD CC (A67714)
2015 GMC SIERRA...
2023 KOMATSU D61PXI-24 CRAWLER DOZER (A65056)
2023 KOMATSU...
