How many Amps to charge an EV?
   / How many Amps to charge an EV? #21
nope not suitable for the chargers I have experience with. Installation say alum. a no go.
Not supposed to use alum. wire as the charger is both a continuous use of high power (many hours) and regular use (very often)
ie: to much power to often but service drops are the same IMHO but its what the installation manual said.
but 2-2-4 alum. USE-2 / URD from Southwire is rated 165 amps when buried though??? so I'm clueless only sharing what installers book said.
I'm a proponent of copper as well; lower power losses.
Can you point to where that specification is? On the Southwire website, it doesn't even go that high for copper on 2-2-2-4;
All the best,
Peter
   / How many Amps to charge an EV? #22
Thanks. Aluminum would of been a lot cheaper. But I understand how much better copper is. I just hate paying for it!!!
If it wasn't your money, what size copper wire would be ideal to run?
I hear you on the cost of copper, but dealing with aluminum is not without issues in my book, especially in a place like Texas.
I would pull at least 2/0 copper to the panel, depending on how long the run is. After that, it is just sizing for a 60A circuit, 4-6ga, depending on the wire (TH vs THHN)
All the best,
Peter
   / How many Amps to charge an EV? #23
Eddie, instead of terminating in a electrical box, how about making a false panel in the wall to terminate your heavy cable in for now. In the future remove the false panel and finalize the outlet and its box at that time. I actually ran my romex wiring on the outside of the wall covering and built a 2x2 and osb over it to cover it. That way I could go back and add another wire to my new needs. Jon
   / How many Amps to charge an EV? #24
All the best,
Peter
I am no expert!!
I chated with Southwire about a year ago on their chat function from their web page and on the Lowes.com website under specifications both confirmed 2-2-4 for a service drop was rated up to 165 amps given a bunch of assumptions like run length, insulation they use, the high temp. rating they have on the insulation, etc....
So I am just parroting what I have been told by Southwire and from Lowes website
the no alum. observation comes from the chargers installation manual.
   / How many Amps to charge an EV? #25
It depends on your usage, but at least for us if we ever have two EVs it's going to be extremely unlikely that we'll need to change both up from near zero to full charge overnight at the same time. If we do need to charge two at once, one can be at a low rate.
   / How many Amps to charge an EV? #26
Consider just running conduit (make sure it's sized for more wire than you anticipate too, anchored well with really nice sweeping turns and a string left in it) from the panel to a couple likely install points (empty plug box with a blank faceplate) and forgo the wire for now - then you can add whatever wire, plug and breaker you really need, when you need it. Cheaper now too.
I think copper will pull through a conduit better - it's not as stiff in the same gauge and then the aluminum also has to be sized bigger which makes it that much more stiff.
[Aside - when I built my solar array I used 4/0 aluminum because no way was I going to pay for 2/0 copper; went a size bigger also to build-in expansion for another ground mount "later" - extra size cost about $200 in cable and may have required the bigger conduit. Built the conduit around the wire so I didn't have to pull 500+' of cable.]
Brilliant!!! I should of thought of this, but I'm super glad that you did.
My first thought was to just leave the wire in the wall and when I want to do something, I can remove the sheetrock. After thinking about it, what if I'm not around, or I sell the place, or my memory fails me? I should have something on the wall to indicate that the wire is in there.
I've seen access panels for plumbing, which might work. Or I might cut a hole in the sheetrock, and put a blank face plate over it. Once the faceplate is removed, the wire would be visible.
   / How many Amps to charge an EV? #28
Aluminum wiring is perfectly fine, as long as it’s sized correctly and all mating terminations are properly rated and applied for aluminum use.
I’ve specified it countless times on large circuits. It’s definitely a cost saving.
People still have unfounded fear from stories of it being misused in the 60’s-70’s residential wiring.
I read that Aluminum is supposed to be rated USE for inside the building. UDE is only used for outside, underground use because it's not fire rated. I haven't seen anything that says it's not OK to use USE for EV's, but I could be missing it in my searches.
Another question. Is there an ideal height for the EV outlet? A foot off the ground is where I place most of my 110 outlets in the house, but in my garage, I'm putting some at a foot off the ground, and some at 4 feet off the ground.
   / How many Amps to charge an EV? #30
Your AHJ has the final word on what is allowed, but USE is permitted in some areas;
Do keep an eye on the permitted bending radius of the cable, which may be in an issue.
I would put the outlet panel closer to 30-36" above ground. Most chargers are designed to hold coils of cable when not in use, which favors a higher location. I would also put in bracing to support the weight of the charger and cable.
All the best,
Peter
2010 Ford F550 Bucket Truck with Altec AT37G Boom (A56435)
2010 Ford F550...
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A59905)
2018 FREIGHTLINER...
1969 Lincoln Continental Mark III (A56857)
1969 Lincoln...
2024 CATERPILLAR 255 SKID STEER (A60429)
2024 CATERPILLAR...
2017 PJ TRAILER 20' T/A TRAILER (A58214)
2017 PJ TRAILER...
2022 Club Car Tempo Cart (A55852)
2022 Club Car...
