Bucket Hooks Tine Bucket opinions
/ Tine Bucket opinions #1
Spydermike72
Flushing MI
None at the moment, looking to purchase in the next 3 months
Good Morning All, I am looking for a cost effective way to pick up lots of brush and limbs/trees on the ground and move them to another area on the property (I have 20 acres). The obvious choice is a grapple hook but the finances are not there at the moment. My tractor dealer quoted me a Tine Bucket this morning for $1800.00. Seems a bit high but I am considering it. I also ran across clamp on debris tines from Vevor at a much lower cost. Just wanted to get some opinions of those that may have purchased items from Vevor ?
For background info I am using and LS MT2 35. Currently only have the front end loader for the front of the tractor. It is a pain manually loading the FEL up with limbs and then having to break or cut up the ones that are too big to fit.
Thank you in advance!
Mike
/ Tine Bucket opinions #2
Mike
/ Tine Bucket opinions #4
Just having the clamp on debris tines from Vevor is not going to help much....maybe double the branches per load. With a grapple, you can curl forward and compress way more debris and grab it with the grapple lid. Even a simple single lid bold on grapple would be an improvement.
/ Tine Bucket opinions #6
did hurricane cleanup with forks, it worked, but I quickly bought a grapple. If you see yourself staying on that 20 acre property for a while and see moving brush as a reoccurring task, really consider the grapple and of course the additional expense of the 3rd function. Just being able to grab and not needing to stack things before moving is a huge benefit for me.
/ Tine Bucket opinions #7
Agree....what would take me and wife all day moving limbs to burn pile (trailer) I could do in an hour with a grapple. Once you learn how to make piles and pick them up, it goes very fast.
/ Tine Bucket opinions #9
I have bucket tines from Rankin - $400. This setup works great when I have the bucket on the FEL and need to gather up brush and limbs.
Does not work as well as my grapple ( $4500 including WR Long third function ) but not nearly as expensive ( $400 ).
I converted the "clamp on" tines to a permanent installation. Four HD bolts all the way thru the bucket.
/ Tine Bucket opinions #11
JFS - I bought the same debris forks 48" when Titan had a sale on these a few years ago. I haven't used my pallet forks much since I got these.
Easily allows me to carry 3x the capacity of brush and stuff - also good for picking up logs - they are very sturdy and well built, easy on/off - 2-3 minutes.
if I had a QA bucket I would probably have a grapple.
/ Tine Bucket opinions #12
Overall I agree but I think you can get more than 3 x because you can heap the bucket more and you can extend past the bucket width.
One unexpected use is in the winter and spring to remove piles of compressed snow that fell off from metal roofs otherwise my yard stays wet for longer. My tractor and loader doesn’t always have sufficient power to break into the bank but the debris forks concentrate the force and breaks off larger pieces than I could without the forks.
/ Tine Bucket opinions #14
One limitation I found is debris forks do not handle light material very well unless it is piled and creates resistance. And when it’s piled it’s easier to balance on the loader which helps since you cannot clamp and hold the load like a grapple.
/ Tine Bucket opinions #16
I made a grapple out of debris forks, great idea but not functional.
The tines are only for loose, light material and will bend with any kind of force.
The arm attached to your existing loader bucket will work better than any manure tines for moving brush and a true grapple will clean up the best.
I ended up buying a grapple to clean up from the big trees cut and topped around the cabin.
/ Tine Bucket opinions #17
I made a rake that bolts to the lip of my bucket; the tines are 1" mild steel rod and they bend rather easily. All in all, it works great. I moved a large amount of brush with it already.
The tines are threaded and held on individually with large nuts.
Total cost was maybe $150 in material, and it took a day or two.
2018 FORD F-150 (A65643)
2018 FORD F-150...
UNUSED INDUSTRIAS AMERICA C10 10' FEEDER TROUGH (A60430)
UNUSED INDUSTRIAS...
Kivel Skid Steer Forks (A65640)
Kivel Skid Steer...
New/Unused Landhonor 8ft x 10ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
(1) 20 Yard Roll Off Dumpster and (1) 30 Yard Roll Off Dumpster (A65579)
(1) 20 Yard Roll...
New/Unused ATS T460 Mini Skidsteer (A65583)
New/Unused ATS...
