Bush Hog brand rotary mower
   / Bush Hog brand rotary mower #1
yanmars
I have a 6 foot Bush Hog brand rotary mower. Need to change the gear oil, it is almost yellow, looks like it could have gotten water in it. Sat out all winter uncovered. 80/90 weight gear oil sound correct for new fluid?
   / Bush Hog brand rotary mower #2
I use 90 W gear oil for my bushhog. I have started using synthetic oils to get a little more life out of them too.
   / Bush Hog brand rotary mower #5
Corn Head grease (0wt) may be a better option. It was made for gear boxes.
Just went to this oil this year in the BH brand BH and the Flail. Hoping it makes everything last longer.
   / Bush Hog brand rotary mower #6
That or fill the gearbox with grease, it will run forever.
I have an 8' Bush Hog withe a central gear box and one on either side that drive the blades.
Few years ago the right hand side one started to leak so much gear oil I couldn't keep up.
I packed it with old grease I had.
No problem.
If yours isn't leaking 90 gear oil is good.
   / Bush Hog brand rotary mower #7
Always ran 90W gear oil in mine, never a problem. Always best to set it on something non-permeable, up off the ground with a roof and ventilation all around, if you want the machine and fluids to last. My own sits in a small purpose-built shed, which was knocked together in a day for maybe $200:
   / Bush Hog brand rotary mower #8
No problem.
It will work everytime.
FOUR WAY BLADE SKID STEER ATTACHMENT (A58214)
FOUR WAY BLADE...
2017 Ford Fusion Sedan (A59231)
2017 Ford Fusion...
Brent 420 Grain Cart (A56438)
Brent 420 Grain...
2015 Peterbilt National NBT40 40 Ton Straight Boom Crane Truck (A60460)
2015 Peterbilt...
UNUSED FUTURE XLA59 - 59" DRUM SPIKE LAWN AERATOR (A52706)
UNUSED FUTURE...
2024 New Holland T8.410 MFWD Tractor (A55314)
2024 New Holland...
