Carolina Implement Grapple?
/ Carolina Implement Grapple? #1
Gypsyman
Quincy, FL
2020 Yanmar YT235C
While browsing grapples for my Yanmar YT235C I ran across an ad from a fairly large tractor dealer that's not far from me. After looking more closely at the pictures I liked what I saw so I started asking questions. He claims that they are made by Carolina Implement (not to be confused with Carolina Attachments). He stated that they are a 2-3 year old company and only sell through dealers so there is no website to look at. The look similar to a Wicked grapple to my eyes.
62" Heavy Duty 486 lbs
62" Standard Duty 440 lbs
Has anyone ever heard of Carolina Implements? Do you see anything in the photos that jumps out at you as a weakness? The overall design looks pretty stout to me.
/ Carolina Implement Grapple? #3
Yes - it DOES look stout. I like the middle arm and the hydraulic cylinders are plenty big enough. I think you found a winner.
The heavy duty version is $2000 and I might be able to get it a bit lower. That seems to be comparable to a lot of the other 60”-62” on the market for what appears to be a more well built unit.
It just seems odd that I can’t find anything on the company itself.
/ Carolina Implement Grapple? #5
AND that is a very respectable price. New company - it's not cheap to advertise on the internet.
/ Carolina Implement Grapple? #6
Make sure it has grease fittings on the ends of the cylinders and pivot points
I have it in my notes to check for grease points. I can see Zirk fittings on the upper cylinder connection points but I can’t see any others. A closer inspection will be required.
/ Carolina Implement Grapple? #8
That looks quite rugged; stout was mentioned prior, I think that's a good assessment from afar.
/ Carolina Implement Grapple? #10
I often wonder how much the 'boss' of this forum charges to be a paid advertiser on here???
Not that I would, because the products we make in the shop are motorcycle related and have nothing to do with tractors or anything even remotely related to this forum. I do advertise a bit on motorcycle related forums but because I've been doing it for so long now, most of it is word of mouth for us. Flipmeisters Specialty Products is known worldwide and it's the 'little old winemaker, me and my 2 employees.
The Internet is a wonderful place most times. It also allows one to do business worldwide without any personal interaction. I sell a lot of products we make offshore as in Europe and Japan and I've even sold to China in the past. Even have a distributor in Geneva, Switzerland.
/ Carolina Implement Grapple? #13
I'm not a fan of using threaded bolts as bearing pins for the lid. What other shortcuts did they take? Mild steel tube for the chassis?
Is that Ted's new business??? :ROFLMAO: 🤪 :whistle:
I haven't been following implements for some time. Can I assume that this relates to EA?
Good eye. That kind of observation is the type of input I was looking for. I wonder how hard it would be to source the correctly sized pins to replace the bolts?
/ Carolina Implement Grapple? #15
Those bolts are a little different, the ends are dimpled. Without looking closer, they could be pivot pins.
That grapple sure looks like this one
Looks heavy duty enough for what your tractor can put behind it. Does it really matter who built it, for repairs it’s mostly generic parts and weld and paint if needed. 2k (or better), price is pretty good for todays market.
If really concerned, maybe local dealer would give manufacturer (maybe importer) phone #?
Good find. It appears to be identical right down to the stickers. I wonder if these are just being imported and sold under multiple brand names?
As you stated, anything can be fixed with a welder as long as the steel is decent quality.
/ Carolina Implement Grapple? #18
Yes a stout build is Good, also the Company "Stout" grapples, but most of them are built for skid steers and are grade 50 or 70 steel. and can are between 500 and 1000lbs. Made in USA.
Family member has one on a Bobcat 250 tracked skid steer and it has been plenty tough
/ Carolina Implement Grapple? #19
In the link I added, the 3rd picture shows a Carolina and HD-(?) sticker. Again, maker or importer to me, wouldn’t be that important. If I was buying a bucket for a 100hp+, I’d want to try before I buy. Without doing something dumb, this grapple looks well put together and is a pretty good deal. Would I back drag using the upper teeth, no. Would I wrap a chain around the upper and pull, no. Would I push /pull a tree using the upper, no. Picking up trees / brush, junk, old fence posts, yes.
/ Carolina Implement Grapple? #20
My first grapple was a single lid unit I bought online. Used bolts for pins and the holes for the pins were cut using a flame torch. POS. Re-welding broken buttered welds covered with globs of high hide black paint is good fun.
I'd recommend checking it out in person before dropping cash.
17601CFL (A61572)
17601CFL (A61572)
2171 (A65055)
2171 (A65055)
2010 Dodge Grand Caravan Van (A64557)
2010 Dodge Grand...
UNUSED JCT QUADRUPLE TINE BALE SPEAR (A65055)
UNUSED JCT...
2019 TAKEUCHI TL12V2 SKID STEER (A65053)
2019 TAKEUCHI...
Hypac C530AH Pneumatic Wheel Compactor (A64553)
Hypac C530AH...
