TC45DA Electrical Plugs
/ TC45DA Electrical Plugs #1
dieselscout80
South Carolina
New Holland TC45DA
I don’t know what these two electrical plugs are for in the first two attached pictures of my TC45DA.
Also, in the last picture which one is the flasher for the hazard lights?
/ TC45DA Electrical Plugs #2
This might help:
  • DA Relay's.pdf
Thanks that covers all but the flasher unless it’s the diode #14.
/ TC45DA Electrical Plugs #4
What are you having trouble with?
/ TC45DA Electrical Plugs #5
Another filthy tractor, must be some sort of disease on here. One thing I always do is I keep all my electrical plugs and connections filled with electrical grease which won't help you with your issue but will help you down the road.
This is a clean tractor btw and they stay that way, even after a day in the field, cause they get washed when they come home......
/ TC45DA Electrical Plugs #7
Here is the location of the flasher module:
  • Flasher Module Location.pdf
Looks like my tractor must have it in a different location than the service manual shows.
My TC45DA is a very late build, so it may have changed as they were changing over to the next series.
Messicks shows it behind the dash, but the Boom 3045 newer series shows the same picture as thclimer posted. :unsure:
If the flasher costs what Messicks lists I’m not swaping it.
If the flasher costs what Messicks lists I’m not swapping it.
Well I found the flasher on the opposite side of the tractor.
Here’s a picture of the fuse box too.
The flasher appears to be an electronic too which is good.
  • Flasher Module Specs.pdf
Genie S60 Boom Lift (A64047)
Genie S60 Boom...
New 2025 NextGen 7x12 Utility Trailer (A61166)
New 2025 NextGen...
2017 Ford Explorer AWD SUV (A61569)
2017 Ford Explorer...
CASE TR310B SKID STEER (A62129)
CASE TR310B SKID...
2022 PETERBILT 579 DUMP TRUCK (A62130)
2022 PETERBILT 579...
LOT OF MISC SAWS (A62131)
LOT OF MISC SAWS...
