TC45DA Electrical Plugs
/ TC45DA Electrical Plugs #1
dieselscout80
South Carolina
New Holland TC45DA
I don’t know what these two electrical plugs are for in the first two attached pictures of my TC45DA.
Also, in the last picture which one is the flasher for the hazard lights?
/ TC45DA Electrical Plugs #2
This might help:
  • DA Relay's.pdf
Thanks that covers all but the flasher unless it’s the diode #14.
/ TC45DA Electrical Plugs #4
What are you having trouble with?
/ TC45DA Electrical Plugs #5
Another filthy tractor, must be some sort of disease on here. One thing I always do is I keep all my electrical plugs and connections filled with electrical grease which won't help you with your issue but will help you down the road.
This is a clean tractor btw and they stay that way, even after a day in the field, cause they get washed when they come home......
/ TC45DA Electrical Plugs #7
Here is the location of the flasher module:
  • Flasher Module Location.pdf
Looks like my tractor must have it in a different location than the service manual shows.
My TC45DA is a very late build, so it may have changed as they were changing over to the next series.
Messicks shows it behind the dash, but the Boom 3045 newer series shows the same picture as thclimer posted. :unsure:
If the flasher costs what Messicks lists I’m not swaping it.
If the flasher costs what Messicks lists I’m not swapping it.
Well I found the flasher on the opposite side of the tractor.
Here’s a picture of the fuse box too.
The flasher appears to be an electronic too which is good.
  • Flasher Module Specs.pdf
NEW HOLLAND B95B BACKHOE (A62129)
NEW HOLLAND B95B...
iDrive TDS-2010H...
JOHN DEERE 5403 TRACTOR (A62130)
JOHN DEERE 5403...
Kubota RTV 500R-A (A64047)
Kubota RTV 500R-A...
UNUSED WOLVERINE QC6-26-15G 3PT TRAILER MOVER (A62131)
UNUSED WOLVERINE...
UNUSED ATS GAC40Y 40 GAL.AIR COMPRESSOR (A62131)
UNUSED ATS GAC40Y...
