Log Grapple, Frost Bite and Does It Need Teeth?
/ Log Grapple, Frost Bite and Does It Need Teeth? #1
Oldtoad
Kennebec County, Maine
Kubota L4310, Bolens-Isiki
Did the shopping, ordered a Frost Bite GR-2o, put it together and it is looking good.
I see the holes where teeth would bolt up, wondering if teeth are needed.
As a low volume user, not likely the lower jaw would wear enough to justify, any opinions?
/ Log Grapple, Frost Bite and Does It Need Teeth? #2
OK - so I had to look at the FB web site. Good looking - strong grapple. My Land Pride grapple has teeth - right out on the last 6" of each shank. Both top & bottom lids.
To be honest - I have no idea if they help or not. I would - go ahead - use it as you got it. You will then determine if teeth are necessary or not. My guess - they are NOT really necessary.
You clamp down on any object - tight enough to keep it within the jaws - it's not going anywhere.
/ Log Grapple, Frost Bite and Does It Need Teeth? #3
The holes are for add-on optional extension tips. But no reason you couldn't teeth in there. Not really needed though. It is a great log grapple.
I bought my extensions from Sundown made for a GR40 grapple. Had to grind them a little.
gg
/ Log Grapple, Frost Bite and Does It Need Teeth? #6
Nice lookin logs GG. Straighter than a paralam.
/ Log Grapple, Frost Bite and Does It Need Teeth? #7
One thing I had to learn regarding grapple use. How to gauge the clamping force of my grapple. The WR Long 3rd function valving does NOT modulate. It's either on or off.
So - when grappling something soft - one must be watchful. You can - quite easily - crush or cut in half - a soft object. Such as - a pile of brush - my 55 gallon burn barrel - your winter pile of stored garden hose.
The crushing force of a grapple is much greater than most folks will realize - at first.
Thanks for the tip.
First mud, now snow and ice.
(4) Texas Built 25' Stand Alone Livestock Panels (A66408)
(4) Texas Built...
2022 CATERPILLAR 303.5CR EXCAVATOR (A65053)
2022 CATERPILLAR...
2016 CATERPILLAR 299D2 SKID STEER (A63276)
2016 CATERPILLAR...
3/8" Quick Attach Blank Plate (A66408)
3/8" Quick Attach...
213138 (A64276)
213138 (A64276)
2022 CATERPILLAR D1 CRAWLER DOZER (A65053)
2022 CATERPILLAR...
