Electric Winch for pulling logs/river debris after floods
   / Electric Winch for pulling logs/river debris after floods #41
I too am exploring practical reasonably priced winches for moving logs. As stated, low duty cycle is a drawback with battery powered electrics. I just stumbled on hydraulic winches that run off a vehicle's power steering pump. Has anyone here had experience with these and do you think they'd hold up moving logs?
One of many I saw on Amazon is below.
Interesting. Never heard of such a thing.
Wonder what the oil (fluid) temp gets after a couple heavy pulls? Would you need to add an oil reservoir or cooler?
Comments say that this has same speed as an electric winch. Many people find electric winches too slow for log work.
   / Electric Winch for pulling logs/river debris after floods #42
They are slow, about like watching grass grow... lol but at least they have a good duty cycle...
If you are careful with them, they last a long time.
SR
   / Electric Winch for pulling logs/river debris after floods #43
You'll need to regulate the pressure down to the 1500 psi the winches are made for. And you will have to make a frame and ground engaging blade/foot for stability like a forestry winch has. A way to operate it from a ways away from the tractor would make it safer. None of that is insurmountable but it adds to the cost and time to make it useable.
   / Electric Winch for pulling logs/river debris after floods #44
While the winch blade certainly provides a great deal of support for the tractor and the winch, to state it removed force off the 3ph is an overstatement. The winch is not detached from the tractor or the 3ph so stress is going to these.
Now this stress mimics the stress that a 3ph was designed to function under. In addition, with careful attention to what is happening, stress on the equipment can be reduced.
Pulleys have been mentioned. Pulleys are great additions to any cable pulling system. A pulley used to redirect a pull has very little effect on the force of the pull, however this does increase as the angle from a direct line increases.
The biggest point that seems to be overlooked is the effects of the increased pull weight generated by a pulley system of doubling (2 part) or more lines ran to the object (log)
This is multi part issue, I will probably miss a few.
-there is an increase of required line to do this
-while a 2 part line almost doubles the pulling power of the single part line, it DOES NOT increase the rated capacity of the equipment
-for every foot of linear movement a 2 part line requires 2 feet of line pull. If you increase the line parts, for each line part it takes 1 foot of line movement/line part for 1 foot of log movement
-there are available calculators for estimating log weight for download or online
-this is a repeat but extremely important, never exceed the Working Load Limits of your equipment, if you work at its rating break limit, you should expect equipment failure. When equipment is overstressed and breaks, bodily injury risk is greatly increased.
   / Electric Winch for pulling logs/river debris after floods #45
Recovery hydraulic (power steering) winches are the most expensive winch option out there.... I explored that when wanting a recovery winch for my Jeep....
For small operation's (mini ranch), the capstan either independent (self) power or tractor hydraulics (PB) seem most practical and cost effective.... Another idea may a PTO capstan winch (no not logging winch)...
If you don't have PB then there is cost of add hydraulics, that was a show stopper for me.... And a full logging winch is huge investment for small operation.... And electrical is basically not practical and tractor electrical system simply can not keep up with winch demands for extended use...
MY jeep has 100amp alternator and a 950 CCA AGM battery and on extended pull I can draw down system to about 8.5 volts and computer shuts down, and I have to wait for battery will recover enough to start If I don't have jump capabilities with me out in field ....This is just a example of what to expect from electric winch...
Ones needs to analyze the intended use to determine actual needs... In the end I opted for long chain and get as close to logs as possible and just drag them out and and gave up winch idea on tractor completely... Keep Jeep and winch as backup if I get tractor "stuck"...
Dale
   / Electric Winch for pulling logs/river debris after floods #46
I never stated it "removes" it, but it drastically lowers it!
It also matters where you are pulling from, the higher or lower pully? Pulling from the lower pully greatly "lowers" the pull on the top link and 3 point.
Also how the winch is anchored matters too...
SR
   / Electric Winch for pulling logs/river debris after floods #47
I'd want at least a 4 gallon output off the tractor ps pump. You probably won't have power steering at the tractor while diverted to the winch.
   / Electric Winch for pulling logs/river debris after floods #48
A 3pt logging winch is not in my budget, let alone remotely available used in this area.. I bought a length of roofers safety rope at a garage sale.. It most be 50 plus meters long, and even though technically expired for safety use, I have done a lot of skidding with it.. Using it to move timber out where it can be cut to length as rounds or to where I can get it attached to the tractor for skidding..
A couple strategically placed snatch blocks will let you easily move timber to where it is accessible.. It may be a little slower, but you will learn quick how to move timber easily.. Work smarter, not harder...
consider a chainsaw driven winch too, such as Lewis Winch. 900 bux on their site, claims to pull 4000lb w/o pulley
there is a similar Simpson capstan winch, only 1000 bucks (about 1/3 less expensive than Canadian product above, but looks to have similar performance, and also a Honda engine)
Edit: as a TBN member noted, Simpson winch uses a smaller engine, and is comparable to Portable Winch PCW3000, which is similar in price
   / Electric Winch for pulling logs/river debris after floods #50
Thanks Arrow.
I'm actually thinking of setting up an AC hydraulic pump to serve multiple purposes. This may never get past the planning stage. If it does the 4 gpm flow rate was exactly what I wanted to know.
   / Electric Winch for pulling logs/river debris after floods #51
Dale
Dale,
Your reply is runs along the lines of what I've read. For years I've noticed that AC hoists are much less powerful and more expensive than D C winches. Just the other day my eyes focused on the duity cycle of the DC winches. That must account for the price difference.
The hydraulic projects I'm dreaming about are a tiny trencher with interchangeable gasoline and AC motors (don't want to dig out my crawl space while breathing fumes) a hydraullic press, and a winch.
Dreams are cheap,
Stuck
   / Electric Winch for pulling logs/river debris after floods #52
This is a topic I’ve been researching for a while.
I have a receiver hitch welded on the front of my dump trailer for pulling logs (and stuff like tractors) up into it by myself. Currently a 4000 lb warn winch stays there.
It’s slow and hard on the battery for repeated pulls.
One of my ideas was to convert to a gasoline engine powered hydraulic pump and a mile marker hydraulic winch but am now exploring something like this.
I would like to move it from tractor to trailer to even the pickup if needed.
I used a cathead(capstan) for a few years when building cell towers and really like their usefulness and fine degree of control they are capable of.
   / Electric Winch for pulling logs/river debris after floods #53
I had trouble getting the Simpson company's website to load, until I realized that google was finding the wrong link (started with an http://, but really needed an https:// to work) Finally thought to try the secure web site prefix, and it worked: Simpson Winch
The Simpson SP/CW winch is powered by a smaller engine (Honda GX35) than the Portable Winch Company's PCW5000 (Honda GX50), so to get similar pulling power (2000# at 22 FPM for the Simpson vs 2200# for the PCW5000 2200# at 40 FPM), the Simpson unit is geared for lower speeds. (They also make a chainsaw powered winch.)
The Portable Winch company also makes the smaller PCW3000 winch which is also powered by a Honda GX35 engine. It sells for a similar price as the Simpson unit. The PCW3000 is rated for 1600# @ 33 FPM. The Simpson is rated for more pull, but at a slower speed: 2000# @22 FPM (at 1500#, it will do 25 FPM).
The Lewis Winch 400 MK2 is powered by your chainsaw. It runs 60-80 FPM (depending on how much cable you have on the drum. Pulling power is dependent on the size of your chainsaw, but it's rated for up to 4000# single line pull. I have heard mixed reviews on these. Some people love them, some can't stand them. Rather than a rope, it winds steel cable onto a drum. It comes with 150' or 3/16" cable. Many people end up cutting the cable shorter, since it can be a pain to get it all back on to the drum.
Which way you go is a matter of personal preference. I think any of them are a better longer-term solution for pulling logs out of the woods than using a 12V electric winch:
  • I have seen the PCW5000 in action, and have had a chance to use it a couple of times. I was impressed. If I did not own or could not justify a logging winch on my tractor (or did not have a trctor suitable for mounting a logging winch), I would own one of these.
  • I've never seen a Simpson winch or the PCW3000. The light weight would be tempting: 18-20#, but I think I would lean toward the higher pulling power and faster speed of the PCW5000.
  • The Lewis Winch sounds tempting with its higher pulling specs. I've only seen one used once. I'm not sure I'd want to mess with the cable on a portable unit. I also would not want to tie up a chainsaw mounting the winch on it. However, some people absolutely love it.
   / Electric Winch for pulling logs/river debris after floods #54
Not sure I would want a cable winch in woods (for small non "logging" operation) .... Think a rope capstan is more practical and easier to manipulate.... Safer too... A rope is not going to break with the whipsaw action a cable can...
Dale
   / Electric Winch for pulling logs/river debris after floods #55
I built a front hydraulic winch for my tractor sometime ago. I built it for a general purpose use.
I've pulling non running vehicles, stumps, trees, etc. The list goes on and on on how versatile this thing is.
Is it fast? No, but I also don't care. I did built it in a way that is slightly faster that the regular recovery winch, but on the other hand I don't really pull or skid logs, so speed is not really an issue.
It's very handy to pull trees when I'm cutting them and it might damage something if it falls to the wrong side.
Another positive thing is that the winch is always on the tractor and always ready to use. Simply move the lever to free spool, pull the cable, attach it, lock the spool and pull.
Keep in mind that my tractor had a subframe from factory tying the front of the tractor (engine, front weight bracket, axle, etc) to the bellhousing. Then when I built the loader, the subframe of the loader tie this factory subframe all the way to the rear axle. So it would need a lot of pulling power to break the tractor in half.
If I remember correctly from the numbers someone on the TBN so kindly ran for me, it had somewhere around 6000 lbs of pulling force, but being that I used an used hydraulic motor, I'm sure it's down to less than 5000 lbs which is still plenty to me.
Here is the link for the build thread: Hydraulic winch
Well, ordered the winch on Wed (from Sportsman's Guide), got the winch on Sun
Unpacked it, started it up and pulled a small log..
Hope to play with it a lot more this weekend.
   / Electric Winch for pulling logs/river debris after floods #57
I ordered the same one through Amazon along with a 328ft 1/2" pulling rope.. Ordered on last Thursday and supposed to be delivered today. Looking forward to setting it up and trying it out. I already have some pulleys, straps, and a pulling chain. I have a bunch of dead fallen ash to bring in for fire wood, and don't want to cut trails to get it. Three point winch is out of my budget and may not allow me to get to those downed trees. With the portable winch, I am thinking I might be able to use other trees to pull from to get the logs out. Will be interesting. Thanks OP for bringing your situation to the TBN. Helped me spend money. Thanks. Jon
Hopefully spend less money than originally intended, on a tool that will actually get the job done.
I never even heard about capstan or gas powered winches until I came to TBN with my problem, so I did not consider them.
I've also learned of other potential solutions (Tractor Capstan winches, chainsaw winches, etc)
Very good learning experience.. Forum helped me find a potentially (right tool) for the job at a reasonable cost.
Thanks forum.
   / Electric Winch for pulling logs/river debris after floods #59
I like the capstan idea.
Might just be my next DIY project.
Have most basics to make one in my stash.
-90 deg gear box, (60/1 ratio)
-spare PTO shaft with various ends c/w U joints
-nice chunk of 4" aluminum round (for drum) (might need more like 6" however)
-tools needed for such a fabrication.
Big question is, do I need one?
I already have a HD electric winch* all rigged to go and have used it a few times with success.
*mounted on a plate with 2 x 2 inch HD tube that inserts into my 3 PT ballast receiver + cables to reach my Anderson aux plug. (and it works well for limited usage)
   / Electric Winch for pulling logs/river debris after floods #60
Have a milemarker two speed winch on my truck. Uses the power steering pump. Has inline filter cooler. Scary strong for a truck. Use mostly for felling trees leaning the wrong way. Has to have a good anchor. Much better than any electric winches I have used.
Had a skidsteer Smart logging grapple that had a 12k warn hydraulic winch. Modified to also fit cat2 3pt hitch. Sold it to a local tree outfit. They brag good and how much they use it. They use it to feed the chipper. Save manpower, quicker and safer. Sadly Smart grapple went out of business.
Always wanted a to try a tractor logging winch. If I wanted to utilize my forest to the maximum it would be the way to go.
2022 Behnke Trailer (A55973)
2022 Behnke...
Honda UTV (A56859)
Honda UTV (A56859)
2004 Ford F-450 4x4 Venturo ET18KX 2 Ton Crane Service Truck (A59230)
2004 Ford F-450...
Alamo SHD96 Flail Mower
Alamo SHD96 Flail...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59230)
iDrive TDS-2010H...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
