Log Grapple, Frost Bite and Does It Need Teeth?
   / Log Grapple, Frost Bite and Does It Need Teeth? #1
Oldtoad
Kennebec County, Maine
Kubota L4310, Bolens-Isiki
Did the shopping, ordered a Frost Bite GR-2o, put it together and it is looking good.
I see the holes where teeth would bolt up, wondering if teeth are needed.
As a low volume user, not likely the lower jaw would wear enough to justify, any opinions?
   / Log Grapple, Frost Bite and Does It Need Teeth? #2
OK - so I had to look at the FB web site. Good looking - strong grapple. My Land Pride grapple has teeth - right out on the last 6" of each shank. Both top & bottom lids.
To be honest - I have no idea if they help or not. I would - go ahead - use it as you got it. You will then determine if teeth are necessary or not. My guess - they are NOT really necessary.
You clamp down on any object - tight enough to keep it within the jaws - it's not going anywhere.
   / Log Grapple, Frost Bite and Does It Need Teeth? #3
The holes are for add-on optional extension tips. But no reason you couldn't teeth in there. Not really needed though. It is a great log grapple.
I bought my extensions from Sundown made for a GR40 grapple. Had to grind them a little.
gg
   / Log Grapple, Frost Bite and Does It Need Teeth? #4
That Frost Bite grapple would work just great on the rocks I move around.
   / Log Grapple, Frost Bite and Does It Need Teeth? #6
Nice lookin logs GG. Straighter than a paralam.
   / Log Grapple, Frost Bite and Does It Need Teeth? #7
One thing I had to learn regarding grapple use. How to gauge the clamping force of my grapple. The WR Long 3rd function valving does NOT modulate. It's either on or off.
So - when grappling something soft - one must be watchful. You can - quite easily - crush or cut in half - a soft object. Such as - a pile of brush - my 55 gallon burn barrel - your winter pile of stored garden hose.
The crushing force of a grapple is much greater than most folks will realize - at first.
Thanks for the tip.
First mud, now snow and ice.
2007 Ford F-750 2,000 Gallon Water Truck (A55973)
2007 Ford F-750...
2019 Freightliner M2 106 Water Truck (A56858)
2019 Freightliner...
2025 SDLANCH SDLE20 MINI EXCAVATOR (A58216)
2025 SDLANCH...
2015 Peterbilt 389 T/A Sleeper Cab Truck Tractor (A55973)
2015 Peterbilt 389...
20FT X 30FT ALL STEEL CARPORT (A58216)
20FT X 30FT ALL...
2017 PJ TRAILER 20' T/A TRAILER (A58216)
2017 PJ TRAILER...
