Tired of oil change bull
Status
Not open for further replies.
   / Tired of oil change bull #1
domains
If you use the same brand and weigh you only need to change filter once a year, we ran 2 motors over 500tho miles this way, oil sludge is caused by mixing weighs and brands, alot of miss guided mechanics out there.
My dad Was a mechanic and was taught this in school, he would always say the black oil your throwing out is better than new, If you buy a new motor and want a certain brand of oil, flush it twice and never change oil again.
The filter is doing its job, stop wasting your money
   / Tired of oil change bull #2
Personally, I think your or your dad is/was FOS.
Oil gets black or dark brown from it being loaded with combustion by products and / or soot in the case of a diesel and the heat and cool cycles cause modern oils to incur depletion of the additive package. You need to refer to the physics of lubrication oils sometime.
I don't condone or do change my lube oils every season but I do stick at least the the maintenance schedules outlined in my owners manuals. I believe the engineers and designers of the engines know what they are doing better than your opinion.
I personally know a person who bought a new Chrysler Pacifica and never changed the oil and the motor tossed a rod at 85K and the shop I retired from replaced the engine and the rod bearings were toast due to contaminated oil that was unable to provide any more boundary lubrication.
You do what you want and I'll do what I deem correct. Never had an engine failure in 60 years due to a lubrication failure.
I find your comment meritless.
One of my brothers had a car that only lasted 120tho on it, he thought oil was oil and placed any weigh or brand, we took valve cover off and it was like thick vaseline all over, motor was worthless
rod at 85K lol that could be anything like low oil or was hard on it, instead of insults try some common courtesy
   / Tired of oil change bull #4
S
l doubt you’ll be answering any retorts with your out there stement. I’d say you’re more of a troll than anything else.
Oil sludge is caused by heat. It sludges over because of ingredient break down over time or rather quickly if too much heat such as the problem Toyota had several years ago that they attempted to blame owners for.
I think you should write them and give them your solution.
I'm not saying its better to not change oil but its a waste of money if you know what your doing
My IH674 10 years 1 oil change because theres only one brand here for it 15/40 , and no black smoke under full load but only got 2600 hours on it, In a winter season of blowing snow I go through maybe half a quart of oil, only change filter
And I saw the proof So I got no worries
S
Heat will mess up oil no doubt, i'm talking under normal running conditions
I never change oil in my cars, I only flush twice and use same brand, i'm not drag racing them, My last car toyota corolla 350tho miles and still ran like new, Got in an accident and scraped it
The proofs in the pudding folks, I understand You never tried it and you have your perspectives but I know what creates sludge when i see it
Theres alot of people that think same weigh different brands are ok, equals sludge aswell
Brown oil is caused by condensation, Not letting motor run full temp, water in oil, I know a guy that started his parked car motor 5 mins in winter every week, plugged oil pump and seized motor
   / Tired of oil change bull #14
I knew id find alot of fan boys with this topic , Call me a troll all you want because everyone's a troll to what they push onto others, This is only a conversation and observation on my part
  • Good Post
Reactions: D&D
   / Tired of oil change bull #17
No one pushes anything on anyone.
You have an opinion that you feel is based on observation but l can guarantee not everything you see is necessarily explained correctly.
Oil changes color mostly because of heat and not condensation. Contaminates are the other factor for color change.
Water ( condensation) being clear cannot change color of anything and is why they call it the universal solvent but you come here and make outlandish and incorrect assertions and then blame us for calling you out.
So state your observations but don’t get your panties bunched up at us when your reasonings are out the window and depicted as such.
   / Tired of oil change bull #18
Water in oil is immediately obvious. It doesn't turn it brown in the manner you're describing. In any real quantity, it turns the oil into more of what looks like chocolate milkshake. Oil turns darker in use over time due to particulates and carbon that build up in the oil and are suspended. Fuel and often small amounts of condensation (mostly engines that are frequently started for short durations or vehicles left outside in the weather with a lot of large temperature swings) are also going to be found in oil in higher concentration over time. It is a fool's errand to run the same oil for too long, IMO.
   / Tired of oil change bull #19
I was being as 'courteous' as I could muster in commenting on your what I consider to be a very obtuse post. I could have been much more blunt and condescending but I tempered my comment. In fact I edited it 3 times before posting it. Far as I'm concerned to put it bluntly, I think you and your dad are FOS, but out of respect for your late father I won't say any more.
   / Tired of oil change bull #20
Thinking back, your last thread was obtuse as well. I'm done with this thread as your comments fly in the face of what I feel is correct and prudent. I have to agree with others, you are a troll. Outta here...
Status
2010 Toyota 7FDKU40 7,350lb. Straight Mast Diesel Forklift (A60460)
2010 Toyota...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2015 Ford Transit Connect Passenger Van (A59230)
2015 Ford Transit...
2008 TEXAS BRAGG 20 UTILITY TRAILER (A55745)
2008 TEXAS BRAGG...
gps trailers (A56859)
Year: 2019 Make: Dodge Model: Durango Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A59231)
Year: 2019 Make...
