Looking to buy a tractor?
/ Looking to buy a tractor? #1
Protegejustin19
Kubota l3301
Trying to figure out what tractor to buy is like pulling teeth! I’m looking for something in the compact size to do small jobs and not tear up the yard. I have Kubota svl75-2 I use for heavy lifting and shredding. I’m caught between buying a small 1025r size tractor or something like a Branson/tym 2515. Mainly want it for tilling and landscape rake. The problem is I may end up getting rid of the skid steer and that’s making the decision a little harder because I would buy something bigger then if I still had it. The compact or sub compact I’d use now for cleaning/maintaining newly made trails and food plots/garden making. Any advice/helps appreciated
/ Looking to buy a tractor? #2
Give yourself time to better settle on your usage needs perhaps.
/ Looking to buy a tractor? #3
You will be disappointed with the lift capacity of any compact tractor compared to the skid steer, regardless of size. That said, it’s hard to tell what you will really be using the machine for. Are you making trails with the SVL? Food plots, what size how many. I am happy with my 2320 (similar size to 2025r) for some smaller plots less than an acre. If I was doing anything more, then I would want a bigger machine.
Also, what dealers are near you? Happy with the Kubota dealer?
/ Looking to buy a tractor? #4
I see disappointment in your future. My tractor basically sits in the shed after I got my skid steer. They make hydraulic driven skid steer tillers that might be a better option for you. Maybe try renting or demoing a tractor before you buy to make sure you’ll be satisfied.
/ Looking to buy a tractor? #5
How big of an area would you till? How much would you use the loader? The subcompacts are really only good for a couple of acres from my experience, and tilling or mowing more than a two-acre property regularly just takes too much time. Also, I would keep the skid steer if you ended up going with a subcompact because a subcompact wouldn't even attempt to lift something that a skid steer would lift with ease. There are hydraulic tillers that go on a skid steer, and many other attachments. If you do end up getting rid of the skid loader, I would definitely want at least a 40-horsepower and relatively heavy tractor that could lift heavy pallets. I had a 1025r for a couple of years, and almost always used my heavier Kubota for work other than mowing.
/ Looking to buy a tractor? #6
Consider keeping the skid steer and adding a tractor. The 2 together make a great combo
/ Looking to buy a tractor? #7
You might want to check out the Yanmar tractor line:
willy
/ Looking to buy a tractor? #8
At today’s prices, why buy a new sub compact when you are only doing some tilling and raking. Buy something used and keep the skid steer.
/ Looking to buy a tractor? #9
Maybe a ~4000 lb tractor with turf tires? Lifts pretty heavy things, (I picked up the front end of a car this weekend to put some blocking under it), and can run some good size implements.
I like mine anyways, but I don't mind marking up the lawn if needed with my Ag tires. I can't say I've wanted a skid steer too often, and have never bothered to rent one, but doing stuff like spreading gravel inside a 30x60' shed would've been faster with a skid steer, but I got it done a bit slower without taking down the shed with my tractor and some hand raking...
For things like commercial landscaping use, a SS is better overall, but for a homeowner with some land, the one tool that does most things OK is a good size tractor IMO.
/ Looking to buy a tractor? #11
There is only so much raking to do. It's awesome when I need it, but rarely use my rake. I break the garden in the spring with a tractor plow, but maintain it during the summer with a walk behind tiller. Not sure that I'd spend the money on a subcompact or compact tractor to only do these limited jobs if I didn't have other work to do.
/ Looking to buy a tractor? #12
I have had two TYM a 394 and now a 494 loved them both. Resoanable priced. Built much stronger than similar models. I would buy TYM any day.
/ Looking to buy a tractor? #13
It amazes me how mant people love skidsteers, i hate em, noisey, hot costraphobic bone shakers, and dont even get me started if you have to open a gate. Sure they load and do construction work very efficiently and the hydraulic flows are awesome but they are no way a substitute for a tractor in a rural setting, complimenting is another story but i would compliment a tractor (and did) with an excavator before a skid steer, even a wheel loader is better.
/ Looking to buy a tractor? #14
You just haven’t had a good skid steer more accurately a CTL.
/ Looking to buy a tractor? #15
I getting ready to sell my two tractors---1st a Kubota B2410-4WD HST with 60 in Mid-mount mower.. 2nd is a New Holland TC40A 4WD. both in great conditoin
/ Looking to buy a tractor? #16
i havnt had a good skid steer because there are none :)
where i work we have several different ones and we also have a volvo articulated wheel loader, theres always arguments of who gets to operate the volvo.
the bigger ones over here tend to be refereed to as positracks. regardless they are all a pain to get in and out off and are claustrophobic and throw you around,
/ Looking to buy a tractor? #17
A loader is good at loading things as the name implies. They’re nearly worthless for dirt work, brush mowing or basically anything besides loading stuff.
/ Looking to buy a tractor? #18
Thats why you get a tractor.
2006 Ford F-250 4x4 Crew Cab Pickup Truck (A61573)
2006 Ford F-250...
2010 Workhorse Custom Chassis W62 Delivery Truck with Liftgate (A61573)
2010 Workhorse...
Grapple Rake Mini Excavator Attachment (A61572)
Grapple Rake Mini...
COMBINE RIM FOR JOHN DEERE (A63291)
COMBINE RIM FOR...
Challenger 65C/70C/75C/85C Tractor Parts and Service Manuals (A63117)
Challenger...
2012 International WorkStar 7300 AWD Altec DC47TR Insulated Digger Derrick Truck (A60460)
2012 International...
