DJ54
Elite Member
- Joined
- Jan 20, 2009
- Messages
- 4,632
- Location
- Carroll, Ohio
- Tractor
- IH Farmall 656 gas/ IH 240 Utility/ 2, Super C Farmalls/ 2, Farmall A's/ Farmall BN/McCormick-Deering OS-6/McCormick-Deering O-4/ '36 Farmall F-12/ 480 Case hoe. '65 Ford 2000 3 cyl., 4 spd. w/3 spd Aux. Trans
If your shoes still have a tendency to gouge through the soft driveway when not frozen yet, here's a thought. Here's the blade I have Dad built back in around 1964 for the Farmall A we had at that time. Originally it had a regular cutting edge on it but was too aggressive for the pneumatic Lift-All system to keep up cutting depth when pushing dirt, worse in a soft driveway plowing snow. He flipped the cutting edge for snow, but not good for pushing/cutting dirt so took it off and used it as is. He used it enough pushing dirt he literally wore the corners of the rolled 3/8" moldboard blade off enough you can see the added corner pieces so it was back to gouging when plowing early snows. It sat for 25-30 years until I got my A. I needed something to plow snow for my own place then and it was back to raking stone back on the driveway.
Back 15+ years ago when I discovered these tractor forums I saw where guys were slipping PVC pipe on the cutting edges. Worked great until it got real cold, then the PVC would shatter. I wanted a more permanent solution, and remembered I had some 1-1/4" pipe I'd gathered up someone was going to throw away. I used my plasma cutter using a piece of angle iron inverted on it as a straight edge and cut a slot in it wide enough to slip over the bottom of the moldboard. Cut and drilled 5 tabs you see on the front and put a bolt through them and welded them in place. Had another 5 for the back, welded them on, then drilled through the tabs and holes that were already in the moldboard and used Gr. 5 bolts to hold it on. Works great when plowing snow, pretty well floats over the stone on the drive and pretty well eliminates raking stone back on the drive come Spring. Also prevents the gouging when pushing loose dirt like when making a fill.
I can attest to 6,000+ tons of bank run fill that little tractor and blade have pushed & finished when making new bases for my new building here, plus shaley clay filling in a pond at the other place, plus all of snow I've pushed with it in all these years. It's worn some but impressed it has lasted this long.
All that to say it might be something to consider if the shoes don't hold it up out of the stone.
