Another MX6 Brush Hog Failure
/ Another MX6 Brush Hog Failure #161
And by the way, any of you with a current MX6 shaft problem OR sitting there worrying about it, really should make an appointment and talk to the closest John Deere district service rep. You are not necessarily after anything or begging $, you want to know for sure what the problem is/was. As noted above I believe it had to do with the center bolt coming loose but I've not talked to any Deere district people. You should.
/ Another MX6 Brush Hog Failure #162
IF I had an MX6, I'd be making an appointment with an auctioneer!
There are MUCH better rotary cutters out there for similar money, and you don't have to worry about them breaking!!
SR
/ Another MX6 Brush Hog Failure #163
The unit I have actually has a key in the shaft that bolts on the stump jumper. I contacted JD on 7/6/19 1-800-537-8233- I have contacted my local dealers and they have not offered any help. If others could contact JD that would be a great help.
/ Another MX6 Brush Hog Failure #164
View attachment 611822View attachment 611823View attachment 611824View attachment 611821
So you guys really haven't found a box that will just mount back up on the JDMX6 cutter? I have the same issue, cutter has less than 100 hours easily. I priced JD and that's not going to happen and I found the same gearboxes at the Green Part Store for the exact gear box for 891.00 and a new version of that gear box for 891.00. My issue is I dont want to put this kind of money in something that I don't even know if the casting problem was fixed. I did find the shaft kit on ebay and that vendor told me he had sold over 1000 of these kits to fix the MX models. JD has not responded to me at all on this matter but you would think they would want to at least admit there is a problem. I will most likely buy a USED bush hog that looks like it want last because those usually last forever.
From your pictures, I see you have the made in China gear box. I thought only the made in Spain gear boxes were the problem MX mowers. Now I know there are not any "immune" from failure MX mowers.
/ Another MX6 Brush Hog Failure #165
Wow ! Looking at one of your images it looks like you have a NUT on the shaft with a cotter key !? That is a whole different ballgame. Mine was probably an earlier unit but in any case had a bolt with no keeper or cotter key or anything to hold it there other than torque/tightness. Maybe a lock washer, I can't remember. Anyway a secured nut versus a bolt would be a significant difference. Probably also blows my theory of the stump jumper flying off and causing the shaft breakage.
/ Another MX6 Brush Hog Failure #166
How can you tell?
/ Another MX6 Brush Hog Failure #167
I bought an mx6 from Coker tractor in Arab, Alabama last fall. D!,& ***** me didn’t think to look under it before I brought it home. After the first use “not hitting anything”,I noticed a huge dent in the stump jumper. Then I read all the stories on the mx failure. I figure they’re putting big ***** dents in the stump jumper to void the warranty! Look at your hog underneath before you take it home or receive it from delivery!!!!!! The stump jumper is like 3/8” thick! If I would have hit something to make a dent like that I would have knew it right off. Plus the stump jumper is spinning and could not get a dent in it like a huge sledgehammer hit it several times in one spot.
/ Another MX6 Brush Hog Failure #169
Post #158, picture 3, the tag says "Made in China". The made in Spain gear boxes have "Spain" cast on the gear box.
I couldn’t see it on my phone sorry
/ Another MX6 Brush Hog Failure #170
Yes mx7 is trash also output shaft broke as if someone sawed it off. Sabatoge. We had a local dealer that did a great job fixing these tractors and JD ran them outa bizzness just to come in town and lay down. Took 3 tractors to them they fixed 1. I told them they need to get sum girls to work on the tractors. Smh. Sold me a no good battery and I had to take the tractor to the shade tree mechanic to fix it. Their just clowns. JD wants to make it illegal to work on your own tractor. Their is a youtube video "Motherboard tractor Hacking" I encourage everyone to watch.
/ Another MX6 Brush Hog Failure #171
The MX Series Brushhog mowers do have some serious gearbox issues that JD is trying hard to ignore. There are companies out there duplicating these shafts for much cheaper than JD parts.
/ Another MX6 Brush Hog Failure #172
I hate to revive this post. I was aware.of the problem. And hoped.I was immune. I was cutting overgrown dog fennel and ragweed. The pics is after I flipped it over in the dirt, other wise it all would have been clean metal. Broke below and above the c-clip groove. I'm looking for a solution that doesn't include John Deere. It's an older model, but I haven't put more than 50 hours on it, granted some of them hard hours but slip it h was always properly adjusted, even on the loose side because those replacement disks are a lot cheaper than a gearbox. It looked brand new when I bought it. serial# W00mx6x017219
/ Another MX6 Brush Hog Failure #173
I broke one of these a few years back. That had a made in Spain gearbox which is supposed to be the better of the two. I think the other box is made in China or Mexico. I also bought one of those MX6 decks with a broken shaft in it. I found a replacement for it on EBay. I sold that one and bought the made in Spain deck only to shear the shaft just like yours a few months later. I replaced that one with another new gear set from Ebay. That was a few years back. So far it has been good. Looking at your shaft, that has been cracked for awhile and worked itself back and forth until the very center oval area let go. Look on Ebay for a new gear set. I read about another gearbox that can be fitted to work on these mowers. It will take modifications. I believe the entire box is cheaper than a gear set. Just Google MX6 gearbox substitute or replacement.
/ Another MX6 Brush Hog Failure #174
I replaced the shaft, but by the time got parts and got it all back together was told could have purchased a new aftermarket gear box for less. So far has had no issues after several years of use.
/ Another MX6 Brush Hog Failure #175
I read that the aftermarket gearbox is not a drop in item. Which brand of gearbox was this?
/ Another MX6 Brush Hog Failure #176
Just seeing this for some reason.
The guy that did the repair work was the one who suggested would have been cheaper to just replace the gear box. He does quite a bit of fabrication on equipment. We never discussed which gear box as I already had the gear set. Very possible any modification required would not have seemed an issue to him.
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A63688)
2023 Kubota...
JLG SKYTRACK 6042 TELESCOPIC FORKLIFT (A65056)
JLG SKYTRACK 6042...
Ford 3910 Tractor w/ Great Bend Loader (A64047)
Ford 3910 Tractor...
2007 Class A Motorhome (A66738)
2007 Class A...
2018 Ford Escape SUV (A66738)
2018 Ford Escape...
2003 30ft Rinker Captiva Boat w 2017 30ft Tri-Axle HMDE Boat Trailer (A66738)
2003 30ft Rinker...
