Another MX6 Brush Hog Failure
/ Another MX6 Brush Hog Failure #121
I think the worst part about this whole saga, is the MX's are highly reguarded line and it seems the 6 is the one unit with the issues. I like the design and gauge of the units. One would think that deere would step up to the plate on fixing this as I'm sure there's a hefty margin on these cutters.
Matt
/ Another MX6 Brush Hog Failure #122
It also has happened to the MX5 and MX7 models--anything with the "dual deck" and extra long output shaft. Spanish, Mexican or Chinese, Comer made them for Deere, and Deere printed the new country of origin and offered longer warranties to increase confidence in the same old gearbox. A global economy.
/ Another MX6 Brush Hog Failure #123
What does the "dual deck" mean?
Does the MX6 have a longer output shaft?
SR
/ Another MX6 Brush Hog Failure #124
The MX6 has 2 top decks that hide the support brackets for the mower. I guess the argument is that water runs off better. It is a really clean looking deck. Makes it heavier. Better? You decide. I run a Brown.
/ Another MX6 Brush Hog Failure #125
Can you point to where you heard this? I had only heard of a few MX5's and now on the 7's?
Matt
/ Another MX6 Brush Hog Failure #126
Well, I have a MX5 that sheared the output shaft, and in the search for a replacement found the gearbox used on the 5, 6, and 7 series were all the same--also the same were formerly used by a company called Tiger out of Canada on their batwing mowers.
I suspect there are a lot more 6's out there than the other two (single spindle 7's don't seem too popular for any shredder line). I have to admit I have not seen a published failure regarding MX7 or Tiger mowers gearboxes, but given that the output length and gearbox design are the same, I would consider them to be at risk for the same episode. I replaced my busted spanish JD (Comer) with the updated Chinese gearbox (also from Comer) that uses a castle nut instead of a bolt for attachment.
The output shaft is definitely more robust now, but to reuse an MX deck you need an output that is 50-100% longer than a typical output shaft is... I could not find anyone but Comer making one that spans the distance.
The MX's use two sheets of steel to keep the topside free of dents (except the front 25% or so) and do all the damage on the underside, and ties the two together using a steel bowl. The spacing from the top of the top deck to the bottom of the steel reinforcing bowl (that spans and ties together the decks and mounts the box) are why they are so hard to find a replacement for. I don't think batwings and larger mowers tend to have quite as varied a diet as the smaller shredders get.
/ Another MX6 Brush Hog Failure #127
Is it just the deck design, i see other brands with the smooth deck design & wonder if they're using twin decks as well?
Also assuming all manufacturers are using basically the same gear boxes?
Ronnie
/ Another MX6 Brush Hog Failure #128
Some smaller manufacturers don't use the smooth top designs. Deere design is unique in that it is a two piece smooth top design. Bush Hog. Woods, etc...use a single piece on top. It helps facilitate water run off.
/ Another MX6 Brush Hog Failure #129
For whatever it is worth, I had a Deere MX6 with the Spanish-made gearbox for 10 years driven by a JD4700. I hit some hellacious rocks with it,usually mowed pasture weeds and some bushes and saplings. Clusters of 5 or 6 2" thick autumn olive bushes definitely slowed it down but no failures. Hardest steel blades I ever saw. I did have the stump jumper fly off a couple of times after 4 or 5 years ownership but that amounted to me failing to realize the torque specs. Once it was back on there with a socket buster of a long cheater arm it was just fine. I read all these MX6 horror stories but I was either lucky or mine was a good one. Meanwhile, in later years I use a Bush Hog 297 seven ft hog and it is 1460 lbs and a lot stronger than the "medium duty" tag implies. Driven by a MF2660. Bush Hog parts books show a different part # for each of the 5,6 and 7ft unit gearboxes. Mine developed a crack and began to leak lubricant near the hold down bolt pattern, vertical, after 4 years use. Dealer said I had abused it. I said he was full of bullcrap. Bush Hog Corp.said they had a few do that, neither they nor their supplier could explain it AND THEY WOULD BACK IT REGARDLESS OF THE GUARANTEE. The harsh dealer put the new one from Bush Hog on. He failed to get the nut tight enough on the stump jumper but other wise I'm good to go. I don't see anyone backing their cutters like Bush Hog. It is a shame to hear the response Deere has been reported to be giving their customers in these forums.
/ Another MX6 Brush Hog Failure #130
Some of the other manufacturers use different gearbox ratios through their line--I figured they were targeting a particular blade tip speed at PTO speed. As I type, if memory serves, the MX6 blade tip speed was as high as any I found (I wanted that over the MX5 after I bought--the extra 6" of radius on each side pushed the 6 up over 12000 fps). Either way I broke the smaller one instead, and the cut quality was fine before and after. Just broke and got disavowed.
What Bush Hog did for you, was what I had kind of expected from JD, and what I will purchase for going forward.
/ Another MX6 Brush Hog Failure #131
Ronnie
I'm not sure i understand what that means??
But, I'd have to say, NO they don't all have the SAME basic gear box...
SR
/ Another MX6 Brush Hog Failure #132
Origin of manufacture is what i meant. Seems to be the longer length is the culprit here regardless of where they were made.
Ronnie
/ Another MX6 Brush Hog Failure #133
Thought I had a “good one” until this afternoon. Mowed most of the morning. No issues. Mowing around plowed field. Hit a small dirt pile and heard change in sound. Looked back and stump jumper sitting in the mowed grass. Over the years have had MUCH worse encounters, but today was it. Sheared output shaft. Had contemplated selling it couple years ago, but thought I was good. I typically skip the clutch every spring, but admit I had not yet done it this year.
/ Another MX6 Brush Hog Failure #134
SR
They absolutely do not all have the same gearboxes. John Deere likes to be different so that you have to use their parts at a premium price.
/ Another MX6 Brush Hog Failure #135
Go on EBay and search for the shaft for your mower. There are companies making these shafts now due to the high demand for them.
/ Another MX6 Brush Hog Failure #136
Ronnie
It is the length and size of the gearbox shaft that is the problem. The "made in Spain" shafts are the ones that are breaking the most. The China shafts are much more beefier. I have seen and heard of both of these gearboxes shearing shafts. I would really like to see John Deere go out with one of there mowers and try to cut the size diameter trees that they claim these mowers are capable of cutting. I think they would be in for a rude awakening. I have sheared gearbox shafts on both the made in Spain and made in China gearboxes. Neither of those breaks was from hitting rocks or stumps or cutting down larger diameter trees than these mowers should be able to handle according to John Deere.
/ Another MX6 Brush Hog Failure #137
The length of shaft possible cause but the 2 that I have seen is where a groove is cut into the shaft to hold a lock ring. look closely at your broken shaft and see where a oval smooth cut deeply into the shaft.
anyone know the part number of where to locate a replacement shaft.
ken
/ Another MX6 Brush Hog Failure #138
Will check that out. Have been pleased with the quality of cut and the unit is in good shape. Would like to get it back going. Thanks for info.
/ Another MX6 Brush Hog Failure #139
These shafts do break at the clip ring slot because the shaft is thinner there. Makes ure you buy the right one. The Spanish version is not the same as the Chinese version. Take your gearbox apart to see the shaft before ordering one.
/ Another MX6 Brush Hog Failure #140
Thanks for heads up. I looked up the part on JD Parts and see there appears to be two different versions of the Bevel Gear. I believe mine is the Spanish version. If I can replace the broken part and get another 14 years out of it I will be better off repairing.
2005 MACK CV713 MIXER TRUCK (A65643)
2005 MACK CV713...
2018 RoGator 1100C (A63688)
2018 RoGator 1100C...
1995 Freightliner FLD120 Tandem Dump (A62613)
1995 Freightliner...
Great Dane Van Trailer 1989 (A63689)
Great Dane Van...
1500 Gallon Stainless Steel Tank (A64127)
1500 Gallon...
3pt Tractor Weight Set (A64127)
3pt Tractor Weight...
