Socket Organizers
/ Socket Organizers #21
So, what do you guys like, that keeps sockets organized, and where you can quickly grab a strip of say, 3/8" metrics from the shed to the work area,
Tekton makes an organizer for 3/8 sockets that holds the sockets with a quarter turn that impressed me. The SAE holds 15 sizes from 1/4” to 1” , one row of standard and 1 row of deep; the metric is similar with 19, 6mm to 24mm. Each holder is about 4” wide x 20” long, fine on the workshop wall, but too large to carry to the worksite. Also a typical job usually requires only a few sizes. When I get a round tuit, I will weld a half-dozen steel pegs to a metal tote tray to carry those sockets I need for a particular job.
My pass-thru ratchet set came with an over-sized, molded plastic display rack with illegibly marked round pegs that did not hold the sockets securely. I bought a 1-1/2” x 4-1/2” x 10-1/2” steel case on Amazon, welded pegs in 2 rows, color coded the pegs and marked the sizes legibly. When the lid of the case is latched, the sockets are secure. Photos below.
/ Socket Organizers #22
I trimmed the molded case my socket set arrived in to fit my rollaway toolbox.
Works great and have done similar with other tools in molded plastic cases...
/ Socket Organizers #23
I bought socket sets in plastic carry cases. These totes fit opened up in my tool box and if needed I can grab the box and take it with me. Best ones I bought are black with white lettering marking the size on them.
/ Socket Organizers #24
I used to toss the cases because the plastic hinge would break in no time...
Now I repurpose kind of...
/ Socket Organizers #26
My better quality tool plastic cases--Milwaukee, Fein, Jonesway--have pin-type hinges. Pittsburgh (Harbor Freight) et al have flat plastic hinges that tear when flexed.
Besides the hinges, blow-moulded plastic cases have other disadvantages. They are formed for the specific tool and may not be adaptable for other tools; they are excedingly wasteful of space. Note that Ultrarunner trims his and likely uses them only as trays in his tool chest.
I decry the passing of the 20th century all-steel tool cases and have re-purposed Milwaukee, Makita, and Bosch steel cases for different tools.
/ Socket Organizers #27
I bought the same set you have in the first post and they weren't broken when I got them, been using them with good results for a couple years, if close I would just exchange them... maybe open first before leaving the store... I'm pretty sure I like that style better than their other plastic version with the size labeled on the posts
/ Socket Organizers #28
I have a fairly large Snap On Box at my shop, The top dray ( largest one in the chest ) is where the sockets and torque wrenches live. For the sockets, I have been using the organisers from Home depot, Red for standard size, blue for metric. They have worked well. The 3/8'' are in the ones with the plugs, The 1/2'' are on magnetic holders that are also colour coded.
/ Socket Organizers #29
I sure miss the old metal socket sets. They fit anywhere and can hold a few extras.
Deutz F3L912 3-Cylinder Air-Cooled Diesel Engine - 48 HP - Industrial Pump Takeout (A63689)
Deutz F3L912...
2001 Peterbilt 330 4,000 Gallon Water Truck (A64194)
2001 Peterbilt 330...
2019 CATERPILLAR TL642D TELESCPOPIC FORKLIFT (A62129)
2019 CATERPILLAR...
Bulk Lot of NEW Motorcycle Control Cables - Motion Pro & Biker's Choice (A63118)
Bulk Lot of NEW...
Auger Drill Bit Skid Steer Attachment (A61572)
Auger Drill Bit...
1059 (A63291)
1059 (A63291)
