New L2501 advice needed
/ New L2501 advice needed #41
Is it me, or does 325/350# sound weak for box blade/ballast?
Ballpark you should be shooting for about the same weight on the 3pt as you are lifting with the loader. For an economy L that would be a little over 1,000lbs. 1,500lbs on my Grand L.
/ New L2501 advice needed #42
R4's. bro tek 3" spacers to be ordered for sure Bro-Tek
Thinking a 5' BB would be better to fit in tight spaces, could go 6' if I could find either that weighed close to 600/700# and not spend $1.5K
May just get a cheap Ballast box and load w/bricks if I can hit the weight (2/3rd's of loader capacity I think)
You won’t be happy with a 5’ blade because consider that you should cover your rear wheel tracks even when the blade is angled.
/ New L2501 advice needed #43
SNIP
One thing I wanted was R14's, having loaded R4's gives me pause. Flats don't sound like fun. More "what NOT", given I can't reduce weight when it's not needed being delicate???
SNIP
Sorry, have more questions than answers ATM.
Great stuff, keep'em coming!!!
The alternative to loading tires is to buy wheel weights. Kubota offers weights for many of their models,
but doesn't always advertise them. Look in the parts books as sometimes they are listed there.
The downside to wheel weights has always been the initial expense. Otherwise they are mostly a win.
Where you may see more wheel weights than loaded tires is with farmers and long time tractor owners.
Slopes are a problem with tractors. You are wise to approach them carefully. On my land, I rarely drive across slopes. Some do. From your picture I would feel more comfortable driving straight up and down. Remember to keep it in 4wd when coming down a slope; tractors only have brakes on the rear wheels, and having it in 4wd connects the front tires to the rear. That reduces the chances of sliding or creating a runaway downhill - which is something most of us have done..... once......
For the same reason, I don't like to carry a load in the bucket when driving down a slope. I simply do not want to do anything to lighten the rears or reduce their traction. If I absolutely have to carry a load down a slope I often back down, in 4wd, and slowly.
rScotty
/ New L2501 advice needed #44
Made it about 1/2 way through posts, but. Loaded tires can be good, but they are loaded, and can't be quickly/cheaply unfilled/refilled, so a 6 ft box blade might be a better choice and or wheel wheels.
Since you mentioned slopes and erosion, you can be 100% good on a slope, and a tire hits a fairly minor, hidden, wash out, and go from stable to not very fast. Let's say 15% cross slope, run into a 8" wash out with the down hill tire, and suddenly your at 29%. Not trying to worry you, just be careful.
/ New L2501 advice needed #45
I’m trying to think of a reason why I would want to unload my rear tires? 🤔
Put an ETA-66-XDCMP-BB in my cart (which may not be large enough to cover tracks w/spacers), no idea what it's going to cost after delivery (dropped off at the front gate), checkout does not say, I'll call tomorrow before hitting the buy button.
430# is not going to be enough ballast, about 500# light. Seems nothing is going to be heavy enough for loader work/front axle kindness. Gonna have to load the BB somehow. That's a lot of stuff just for ballast.
Maybe just grab the 3" bro tek spacers (for sure) and ballast box, see how that works.
Obviously, I'm not the first dealing w/this issue.
/ New L2501 advice needed #49
Maybe you wouldn't, or it might depend on what they are loaded with. Or maybe you got a great deal on wheel weights.
Or for flotation, hard surface traction, softer ride, or just don't wamt so much weight or compaction.
Lots of reasons......
/ New L2501 advice needed #50
If you had a bigger tractor it might be more of a problem but those economy series tractors are excessively light to start with. The tires on my L3800 are loaded and I can’t see any good reason you’d ever want to take it out. I’d slap on cast weights in addition to the fluid if I had them. The weight will make traction better not worse. The front tires cause more compaction and turf damage. What weight the fluid adds really doesn’t change that aspect. Any ride benefits with such a small tire to start with would be extremely limited. You’d accomplish a lot more to throw away the crappy seat. If you did happen to have a good reason you would just drain the tires and be done with it. You definitely aren’t going to load the tires for one job and unload them for another. If you had iron hub weights you aren’t going to be taking them on and off either.
/ New L2501 advice needed #51
I dont see where our OP lives; but my last tractor had just normal water filled tires (well, water filled tubes). We do get freezing weather, but I don't think I've ever seen Temps actively below 32 for more than 24 hours. Never had an issue.
Looking at your list of equipment, I would imagine you would load this thing down ;)
I bought an over grown yard tractor, more of a EDC swiss army knife that's heavy on the front axle, skinny in the butt.
I hear ya on the seat thing, I'll suffer...
/ New L2501 advice needed #54
You can make an inexpensive counter weight with a 55 gallon barrel and some crushed stone some concrete and pipe and get the quick attach from HF or TSC and adapt it.
Don't underestimate the 400 Lbs hanging 2' off the back (BB or rear blade) as it's further back - the thing about the barrel or any box is taking on and off when you want to use the 3PT implement.
/ New L2501 advice needed #55
Ballast on the three point is important. Loaded tires and/or wheel weights help but are not enough. I went years without rear ballast and finally bought a ballast box, a huge improvement, it takes that rocking back and forth on the front axle away when using the end loader.
My ballast box is filled with cheap stuff or nearly free stuff, old brake rotors, old weight lifting weights etc. My owners manual calls for something like 750 pounds of 3 point ballast but I’m probably more like 500 pounds which helps a lot.
/ New L2501 advice needed #56
Depending on your specific use case; compaction.
Fuel usage & speed too. Roading my tractor with vs without an impliment cuts my max speed on a particular hill from a little over 7mph to under 6. 1,000lbs or so on a 40mph machine that is in the 6k range with loader & loaded tires is noticeable at times.
I wouldn't run without loaded tires ever though. The extra traction & stability are more important. Well, unless I sprung for wheel weights, but they do the same thing.
/ New L2501 advice needed #57
One thing about DIY ballast on the 3pt is to try not to use anything that can shift and actually cause you to tip.
Am I the only one that's looked for SSQA pallet forks that can mount on 3pt/Quick Attach???
Thant would kill about 10 birds w/one stone.
AGT Top Cat Brush Cutter (A64047)
AGT Top Cat Brush...
2018 Tycrop Vector Belt VB-16H Sand Belt (A64194)
2018 Tycrop Vector...
3ft Metal Jeep Tailgate (A65583)
3ft Metal Jeep...
Landhonor MPF-11-2000G Skid Steer Pallet Forks  (A62679)
Landhonor...
2020 Freightliner M2 106 Johnston VT652 Sweeper Truck (A64556)
2020 Freightliner...
250 Gallon Diesel Fuel Tank w/ Pump (A64047)
250 Gallon Diesel...
