Agrotk excavators: Does anyone have one? Opinions/comments/critiques?
   / Agrotk excavators: Does anyone have one? Opinions/comments/critiques? #41
I've had my Kat 12 since May 2023. My honest opinion is to look at other brands.
I've had to put lock washers, locktite and lock nuts (where I could get to the bolt end) on just about every thing bolted.
The bolts on the track base got so loose one day that the whole top portion almost separated, ie, tracks and turn table in one place and on the ground beside it the dog house and arm on its side. Some bolts were never even put in to hold components together.
YES I still have and use it , but only because I can't sell it and still sleep well at night.
There are plenty of affordable options out there.
   / Agrotk excavators: Does anyone have one? Opinions/comments/critiques? #42
I have 3 Agrotk H-12 excavators with the Briggs and Stratton Engine. They are a great little machine where I live in Florida. Plenty of power for Florida soils and very fast machines. I had to swap a couple hoses to change the control pattern to my preference which took 20 minutes. I also cut out the existing engine cooling vents for much better cooling and super easy access to the engine. Although assembled in China, the machine incorporates name brand components that are extremely durable and easy to obtain if ever needed. I have only ONE single complaint with these machines and that is that they are "jerky". I have many thousands of hours operating equipment, especially excavators of all sizes. I can just barely operate these things without getting totally beat up. It's like jumping on a mechanical bull at high speed.
Now, I know that somebody out there probably knows an easy cure for this and I would dearly love to hear it !!!
   / Agrotk excavators: Does anyone have one? Opinions/comments/critiques? #43
Sorry for the earlier erroneous post. I am unfamiliar with this site. However he goes:
I just bought a H12. It arrived and all looked good initially. However I discovered some things as I tried to use it.
First, I pulled out the choke to start it. Wouldn’t start. I discovered that I had to pull out the choke beyond the normal stop before the engine would start (about 6”). As soon as it starts I push the choke back in.
After using the excavator for several minutes I discovered that it was leaking hydraulic fluid into the chassis. I didn’t discover that until the chassis filled with enough fluid to leak onto the ground. I then discovered that the enclosed wrenches to access the hydraulic couplers were virtually useless as they didn’t provide access to get to the hydraulic couplers in order to tighten. There were 3 loose couplers.
To remove the side and rear plates you need a 17mm, 18mm, 1/2”, and socket and drive extenders at least 9” long. There us no 18mm wrench in tool box. This is required to remove the sides and back plate in order to remove them to access the hydraulics. Note that all the plates are bolted together as well on the bottom where an adjustable crescent wrench ( or box wrench) is required. Note that the counterweight also has to be partially removed to remove the rear plate.
The engine can’t be accessed without removing the side plates. There is no oil stick.
When time to lubricate, there are both regular grease fittings AND low profile grease fittings. The enclosed grease gun only has an adapter for regular fittings and also doesn’t accept standard lithium grease tubes. To lubricate a low profile grease fitting adapter is required.
The throttle arm totally disassembled itself as the pin just fell out. Easy fix with a finish nail once I figured out how it was to look.
Finally the controls required some time to become acquainted with as they will stall the engine without enough throttle.
Despite all that, for $8K it can’t be beat. I have a Deere 310 SE but because of limited access I needed a much smaller unit. I used it to remove and relocate very large and heavy rocks as well as an infestation of Russian Sage roots. Renting a unit for the 3 month project probably would have cost the same.
I plan to sell it in the spring so we shall see how the resale holds up.
   / Agrotk excavators: Does anyone have one? Opinions/comments/critiques? #44
I also just bought an H12 and I found this place and registered because there is that 70 page thread on these things here. That seemed like the most information on them in one place.
My cost was $5300 + tax. Which is the cheapest I have ever seen a mini-ex of any kind, even a busted up one.
I am a homeowner and live in a city, so anything larger is not really an option. This machine fit through my fence gate. I have a retaining wall to fix and a bunch of landscaping fails to correct in the yard, plus there is also my parents' place that could use work. Renting one would probably eventually cost the same as this, plus there is the whole thing of being under the gun to return on time.
I am by no means an expert on equipment, and everything that follows is my opinion and guesses, so if anyone wants to correct me that would be great.
So far I have used it to do a couple of decidedly non-excavatory things, such as pulling a car into my driveway and yanking an old chainlink fence post out. That all worked fine.
The machine came with a very cheap tool box containing two manuals (machine and motor), a tool set (two open end wrenches, a screwdriver, and a spark plug wrench), the cheapest grease gun I have ever seen (although it does include both fittings for standard zerks and for whatever those conical things are), and a plastic bag of some seriously suspect-looking grease. I don't plan on using the grease or the grease gun.
I got better at dealing with the jerkiness in about 20 minutes - it's a matter of habit to a large degree. Although, I think lengthening the control sticks might help.
The engine is an off the shelf Briggs & Stratton. It's kinda hilarious how they made a remote choke for it just by drilling a hole in the choke lever and bending the cable into it.
The only problems I had so far were caused likely by the prep after it came off the boat. The gas wasn't very good, and there was so little, I stalled out driving it off the trailer. Also, hydraulics were underfilled. Fresh gas and a little fluid to top off the hydro tank took care of it.
There are a few things that are design faults to my eye. Nothing that is really bad, just things being annoying.
The B&S engine is clearly a generic unit, and isn't really meant to be installed in an enclosure. Took me forever to figure out the oil situation. It actually has two fillers and two drains - one set at the back and one at the front. You can get to the rear fill by pulling the rear grille. That's something like 8 10mm bolts. They really should be latches. Rear fill has a tiny dipstick, you can at least check oil. Don't do it on a hot engine, you will probably burn yourself on something.
You can access the front filler and drain by pulling the floor panel. Two 12mm bolts. I am not sure you can actually get a bottle in there to fill it, and while that drain is more accessible, I don't see a way to get a pan under it. Probably worth looking into screwing a hose in there and making a remote drain. Also, B&S manual says they have a longer fill tube, which might help, although I haven't found a part number for it yet.
Same floor plate hides the battery, it's under your left foot as you sit on the machine. Also a dumb place for it - if you ever have to jump it, gotta pull that floor plate.
The hydraulic tank doesn't seem to have a drain. I think when/if I am going to change out fluid, I will have to unscrew a hose, which I think is the suction hose for the pump. Kinda thinking of seeing if I can get a T fitting in it and route a short hose to the outside as a drain.
Manual says the only filter in the hydro system is a strainer on the pickup. That kinda seems not enough - I am pretty sure there should be more filtration. I think I can add a filter kit to the return line pretty easy.
I read that there are some issues with heat both on the motor and in hydraulics. I haven't used it enough to see them, but it seems reasonable. The motor has a cooling fan built in, but it's like 10 inches away from the outside, not even near the side grille. Maybe a duct would help, or some people seem to have had good luck with electric fans.
I also will probably look into a hydraulics cooler. Seems like cheap insurance. Really not sure where I could mount it, though. Manual says "don't let it get too hot", but doesn't really say how hot that is, which is kinda goofy.
   / Agrotk excavators: Does anyone have one? Opinions/comments/critiques? #45
Well, AgroTK now has their QH12 1-ton mini-X on sale for $6199 + tax, including US shipping. Shipped from Chicago.
That is an amazing price, but does not include many attachments or spares. Those willing to brave a direct import can score attachments and spares for much much less. With all costs in mind, you will probably not do much better than $6200 per unit, however.
The AgroTK website has a minimal parts diagram, and there still seems to be no hyd oil filter or cooler, and no wheel brakes.
The QH12 Agro TK I purchased at the same sale as my SDLooL 380 Mini Skid, Does have a Hydraulic Filter, but no Cooler or Wheel Brakes. It is an Exact Copy of my FF Industrial FF12 I purchased last spring.
I am still trying to figure out the Origin Company, but I believe Yancheng Cross i the closest I have seen. Oil Tank under the Floor is the hardest one to spot
   / Agrotk excavators: Does anyone have one? Opinions/comments/critiques? #46
I just got the L-12 ----- WAY better than the H-12 setup. These things are confusing cause they all look alike but are totally different inside!
The L-12 has the rear hood that raises up to get to the motor and the H-12 does not,--only the seat tips and you cant get anywhere near the motor to work on it or check the oil.
As for quality,--- well NONE of the grease fittings work, gotta go buy decent ones AND course everything is metric on it. Motor on mine came with the intake valve stuck open,---had to take the head off and the valve and chamber was full of something melted and burned to the surfaces! Wot a crock!!
Digger itself is fair,---no production machine for sure but great for the tiny places the 580 ck wont fit in and I'm too damn old for shovels anymore!
The thumb gotta come off to use the digger, tossed mine in the junk pile, blade gotta have a taller plate welded on top to keep dirt in front of the blade and not fall behind it! I would like to have the grapple bucket and rake along with the ripper tooth for mine, IF I get the motor runnin again.
$4,000 or less should buy one.
   / Agrotk excavators: Does anyone have one? Opinions/comments/critiques? #47
Congrats (or condolences) on the new mini-X, Sonny.
Got pix of what happened inside the intake? I assume you got the Briggs XR2100. It is built in China, but is a good engine. Hopefully fixable.
The blade will interfere with the bottom of the house in raised position if you weld anything on its top edge. The first machines that got the cast bolt-on counterweight did not account for that, and there was interference. Your best bet here is to rig up some sort of protection for the cylinder, and take small bites when dozing. I have not done this yet.
Buying these machines is a case study in forensics. :)
   / Agrotk excavators: Does anyone have one? Opinions/comments/critiques? #48
... IF I get the motor runnin again.
After some cold weather starting difficulties I found out these B&S engines now come from the factory with a Torch spark plug. Torch is a Chinese company and they put out some really crappy spark plugs. Through the years of me finding them in various small engines the one constant was how better they would work once going to a reputable spark plug brand.
I replaced mine with a Honda brand NGK (made in Japan!) https://www.amazon.com/dp/B00AJV1XQU?psc=1&ref=ppx_yo2ov_dt_b_product_details and the difference is noticeable. Starts easy and runs smoothly through all throttle positions. I like it so much I bought 2 more plugs to have on hand. You have to be careful that someone does not sell you the resistor type (BPR6ES) of the plug. I had to return an order from the first place I bought a NGK plug from because they shipped the wrong one.
   / Agrotk excavators: Does anyone have one? Opinions/comments/critiques? #49
This one has the XR 250000 motor in it not the 210000. The spark plug has the B & S logo on it so who knows what it is.
Didnt think to take pix of the intake but it was hard melted on carbon like crud, and NEW motor right off the shipping crate should NOT have anything on it!
Did finally get valve unstuck and out,--cleaned up, reground the valve and ready to put the head back on. Also the carb is plugged partly cause it only runs with the choke half on which I can live with IF necessary but what the hell did they try to run in it before they boxed it up at the factory?? Got me beat! Anyway these motors say B & S on them but I was told they are chimineese clones of Hondas. I have no idea but they do look like Hondas and sound like them so who knows! I just want it to run and dig.
I did get a half hour digging when the valve stuck open for the second time and I took the head off to see what was going on. Called the local AUTHORIZED B & S dealer for warranty service and of course was denied right out of the gate which I knew would happen but just wanted to make the dealer squirm! LOL! Ya by it ,---Ya own it,--- YA fix it yourself!
Another thing I ran into was the grease fittings! NONE of the ones they put in at the factory will take grease! gotta replace every one of them with known good ones! Of course they METRIC chit too so gotta go buy more stuff!
Bucket side plates gotta come off,--- all the big bolts stickin out interferes with dumping the bucket and the tooth bolts are kinda in the way so looking to drive carriage bolts in them with nuts on the bottom side OR just weld them on since I will never wear them out in the rest of my lifetime.
Track tighteners need to be converted to bolt and spring instead of using grease gun! Thats a real crock!
Anyway the problems continue with it! LOL!
Might eventually make a nice digger out of it if I live long enough!
   / Agrotk excavators: Does anyone have one? Opinions/comments/critiques? #50
Mine has the B&S Logo but also says Torch. You should have gotten an engine manual that specifies the spark plug and gap. Sorry you got a damaged engine with a new unit. Have you contacted the Seller about it? Or perhaps the AGROTK industrial outfit in Chicago. There is supposedly a year Warranty on these things
Instead of removing the side cutters consider doing what I did which is to weld them on and then remove the bolts. I also ground a bevel on the face to help with root busting.
   / Agrotk excavators: Does anyone have one? Opinions/comments/critiques? #51
Well, it looks like B&S has changed the name of the XR2100 420cc single-cyl engine to XR 13.5, at least in the US. The model name is 25T2. They also offer a 14hp Vanguard 408cc single cyl engine, called Vanguard 400 (model name, 25V3). Dunno what they make and ship in other parts of the world, tho engine factories exist in China and other places. You should find the model name on the maker plate. Does is say 25T2?
Neither engine is a Honda clone, tho some clone parts, like carbs may fit. The Honda clones in the US now go all the way up to 500ccs, tho factories in China have yet to clone the top-of-line EFI Honda single cyl engines, as I have found anyway. The engine I put in my mini-X is a 420cc Chonda from Duromax (China), and is rated 16hp. It has worked flawlessly.
Honda, Kohler, Briggs, and Chonda are the 4 1-cyl choices for EPA- and CARB-legal engines in the US. Kohler seems to use the most robust internal engine parts that I have seen of these brands. Both Honda and Kohler are very expensive, and have thumpers with EFI, up to 390cc and 429cc, respectively. B&S has an EFI thumper with 408cc. If EFI was not so expensive, I would have one.
   / Agrotk excavators: Does anyone have one? Opinions/comments/critiques? #52
I dont know a great lot about these new models, so my info is probably wrong! I do know it has the sheet with it saying 250000 13.5 motor. cant see in there very good but will try looking with a mirror and try to find numbers or tags.
I did get the head cleaned up and ground the valves in it today. Runs now but carb is gummed up with that crap,---got it clean enough to pull the bucket good so maybe it will self clean a bit more. Digs great for now ---light even works, also the fan on the oil cooler runs.
   / Agrotk excavators: Does anyone have one? Opinions/comments/critiques? #53
Just for reference. The B&S engine that came on my excavator has printed on the pull start/flywheel cover 13.5hp. The engine manual that I got is for 190000, 250000 model with a copyright date of 2022. Nowhere do I see any XR designation though in the sales listing when I bought it was mentioned as coming with the XR2100 engine.
The manual does list a 2 year warranty but reduced to 1 year if commercial use for non XR or Vanguard. If it is a XR series than 2 years without limitation. Vanguard is 3 years.
   / Agrotk excavators: Does anyone have one? Opinions/comments/critiques? #54
I see a couple of these small ex's listed for sale in Middle Tennessee at dealers where they've dropped the asking prices. There were asking around $9,500 and now they seem to be around $7,000 or thereabouts, although I haven't looked closely at the model number or specs to see if there's something else going on. Seasonal selling? Economy softening?
   / Agrotk excavators: Does anyone have one? Opinions/comments/critiques? #55
Market in US has been flooded. Last Sat, the local monthly auction had 65 unused Chinese excavators listed, almost all of them 1-ton-ish. Previous month was 52 of them. Saturation has pushed final bids down to as low as $3000. Out-the-door, under $4K. The handful of 3-4.5T units may get as high as $15K, with cabs.
I think the auction companies are bringing in their own full containers, but they are losing money at $3K final bid.
   / Agrotk excavators: Does anyone have one? Opinions/comments/critiques? #56
Would be interesting if someone that has bought one at that reported low Auction price makes a post. I distrust these firms to sell at less than their cost plus profit. What I suspect instead is they simply shuffle the equipment to the next Auction when the bids do not reach the minimum level they have set.
   / Agrotk excavators: Does anyone have one? Opinions/comments/critiques? #57
The company I referred to above does exactly that for some of its items. Hidden or secret reserve. RBAuctions, which I am naming, does not do that as far as I can tell or have heard.
I do not know if there are hidden reserves for these excavators. The Diggit EM15 I referred to above was bought at that auction and had no reserve, or the final bid of $5200 was above it. That is very cheap, and may be below cost.
   / Agrotk excavators: Does anyone have one? Opinions/comments/critiques? #58
I also noticed an agrotek LRT23 ride on mini skid steer marked down to $7,700 at a local tractor dealer. The L12 ex was priced at $5,960.
   / Agrotk excavators: Does anyone have one? Opinions/comments/critiques? #59
Looking over on the Agrotk industrial site I do see a 1-ton (730kg actual) listed for $4900 with free shipping it is the QS12R. By the pictures of it though it really looks like they cut every possible corner in construction.
ETA: BTW I noticed they actually have a spec sheet on the hydraulic for this model. The 18Mpa is ~2600psi and the flow of 23.4L/min is ~6gpm
   / Agrotk excavators: Does anyone have one? Opinions/comments/critiques? #60
I Did last month. A QH12 And a SL380 Mini Skid Steer. Long way away from Home, but that is not the Auction's Fault.
The last Sale, last week, prices held pretty much at what I paid for the Hoe, the Skid prices dropped $500 from what I paid.
But those Auction Prices are legit, Price Shown, + 5% Fee + Tax, they load you.
2019 VOLVO A45G FS OFF ROAD DUMP TRUCK (A60429)
2019 VOLVO A45G FS...
2018 Keystone Outback Super-Lite 330RL T/A Travel Trailer (A59231)
2018 Keystone...
2022 Schulte 2500 Giant Rock Picker (A56436)
2022 Schulte 2500...
2023 CAN-AM DEFENDER RTV (A59823)
2023 CAN-AM...
2014 Mazda 2 Hatchback (A59231)
2014 Mazda 2...
V.E. ENTERPRISES 500 BBL FRAC TANK (A58214)
V.E. ENTERPRISES...
