It’s here!
/ It’s here! #101
Well said. I think the only drawback is that with emissions, running at lower RPM just leads to more frequent regen.
As long as the engine has a decent load on it to keep the exhaust temps high, it shouldn't be an issue.
The reason for the high RPM requirement for the DPF is usually because the owners just can't put enough load on the engine to increase those exhaust temps.
/ It’s here!
I ran it at about 2000rpm. I'm not thinking I'll see a regen this year. At 85F and running a tiller, I think the DPF was plenty hot.
/ It’s here! #103
Although I don't have any DPF system, the guy who delivered my L2501HST told me to keep the RPM up because the hydrostat pump requires higher RPMs.
Between the HST transmissions and the DPF systems, I suspect operating at higher RPMs is now becoming a norm.
I've always idled my engine before shutdown for at least 30 seconds or longer after running it hard. Is that now a bad idea?
/ It’s here! #104
Nope still a good idea.
While the hydro's do like rpm they don't need wide open rpm unless the other parts of the job do.
/ It’s here!
I need restrictors for my snowblower chute controls, where is a good place to find them?
Hmm, I think I posted a link in this thread as to where I bought mine, but they were imported from Europe as my top link is from Italy and metric. There have to be a number of purveyors or flow limiters in the US... in fact I searched many of them, but they didnt carry BSP thread
/ It’s here! #111
Surplus Center has the adjustable ones.
/ It’s here! #115
I'll be damned, I didn't know you could buy them, I've been making my own.
/ It’s here!
Got the urge to check the front axle fluid tonight… nothin on the dipstick.
It says to measure without the cap screwed in.
Added almost a quart of 80w90 to get it in the range. Added a total of 1.5qt to get it near the top. I have 15 hours on the unit. Never really used 4wd. Total capacity is about 2 gallons. I’m sure it’s fine, but it appears to have been missed on pre delivery.
/ It’s here! #118
That seems to be a common complaint with all tractor colors.
/ It’s here! #119
It isn't confidence inspiring when the dealer delivers a tractor with low fluid levels. I checked my L2501 on delivery, and it arrived with low fluid levels in the front axle and the transmission.
/ It’s here!
I think I know why. I takes a lot of time for the level to correct after filling. It can take some driving to get the oil worked into all the crevices in the gears. I had to fill, wait a few mins, fill, wait a few mins… so I can see them having it topped off, only for it to need correcting after a few hours of use. Maybe this is why it’s so common
SKID STEER VIBRATORY ROLLER (A62613)
SKID STEER...
Front Tank Bracket (A64126)
Front Tank Bracket...
(INOP)1989 NISSAN D21 EXTENDED CAB TRUCK (A65054)
(INOP)1989 NISSAN...
Bandit 250XP Wood Chipper (A63689)
Bandit 250XP Wood...
Towable Dual-Line Pipe Road Crossing Trailer (A63689)
Towable Dual-Line...
2025 IRET13 Electric Tricycle (A64194)
2025 IRET13...
