• Thank you for participating in the Summit Tractors Community. Per special arrangement with the TBN team, Summit Tractors will regularly monitor and contribute to this forum to help ensure that the community has direct access to Summit. You can ask and find answers to a range of topics directly from Summit and from other TBN users. The Summit Tractors brand is here to stay with the recent acquisition of the Summit Tractors brand by ITL, the 5th largest tractor manufacturer in the world. Yes, we make our own tractors, something very important for our owners and prospective owner to know. Summit’s founder continues to lead operations and the U.S. team that supports our retailers, tractor owners and TBN users.
Ad top of page
Online Ordering and the First 10 Hours
/ Online Ordering and the First 10 Hours #1
isleview
Member
Summit Tractors TX25
Maybe this‘ll be useful to those of you thinking about ordering a Summit Tractor online.
TLDR; based on my experience so far, I’d highly recommend ordering a tractor from Summit. My recommendation boils down to Summit’s excellent customer service and tech support so far (~10 hours in):
I ordered my TX25 and four implements from Atwoods On 9.12.23. The TX25 arrived 9.26.23 with BoxPlane and Grapple attached (bucket was neatly strapped into the Grapple). The other two implements will arrive sometime today, 9.28.
The online order process was great but Atwoods hasn’t been responsive to email questions. I’m not sure what the issue is, but my questions were pretty simple and I had to call them to get the answers I wanted.
But more importantly, Summit has been very responsive in all circumstances online and by phone. Whether it was answering questions about delivery, parts or my first technical issue, Summit‘s been easy to reach and eager to help.
The freight company Summit used was excellent. The TX25 arrived at the promised time looking fantastic.
I put several hours in the seat the day it arrived and a few more yesterday. Even in such a short time, I ran into two issues that Summit addressed immediately.
The TX25 was missing a part and it only took a quick text to get it on its way to me.
Yesterday, I had my first technical issue that required me to park the TX25 while I reached out to Summit. I have to say, the fact that I had to park it about 24 hours after taking delivery left me more than cranky.
I got ahold of someone at Summit very easily and the fix took just a few minutes. While we were chatting, Summit mentioned that the company is working on a different part design to eliminate the problem going forward. Another positive data point.
Great customer service, responsive technical support. Both hugely important aspects of owning a machine like this and just what you‘d expect from a solid customer-centric business.
I have to say, I made a bit of a leap of faith ordering the tractor and implements (about $35,000 so far) online rather from a local dealer. Especially where I’m located.
While I’m still keeping my fingers crossed that Summit and the TX25 continue to exceed expectations, the first two days turned out to be a real-world stress test of Summit’s products and its business model.
Well done, Summit, and thank you.
/ Online Ordering and the First 10 Hours #3
What was the issue/part? May be good to share if others could be facing the same issue.
I appreciate the review. I'm still very interested in ordering one of these online and am watch for others' experiences. Thanks for taking an early leap!
Hi, @bradleykd,
A metal shield (about 4in x 12in) located below the ignition switch and under the floor mat came in contact with the universal joint that spins very close to that metal guard.
The shield can come into contact with the u-joint in certain circumstances, such as when the TX25 is incorrectly strapped down for transport and the shield is bent toward the u-joint.
When the two parts come into contact it makes an alarming racket; it was so loud I could hear it fairly well even through my ear protection. It sounded a lot like an engine failure (valve, piston, etc), which is why I parked it.
Thankfully, while it’s rare occurrence, ST immediately knew what had most likely caused the problem and pointed me to the part. The fix, as I mentioned, took just a few minutes.
I was told ST is redesigning that part to make it less likely to come in contact with the u-joint. I assume that means creating a more robust shield and forming it with little more clearance.
The main takeaway was how responsive ST has been to this and every other question I’ve had about the TX25. I’m now at 30 hours and it’s been a great experience so far.
A quick followup relating on two of the Summit implements I ordered with my TX25.
The Summit Landscape Rake and the Summit Rear Blade are “limited cat. 1“ not CAT 1.
This means those implements do not share the same 3 point dimensions as CAT 1 (they’re effectively CAT 0 with CAT 1 lift arm pins) and are not quick-attach compatible as a result.
There are adapters readily available for the top link connection but the lower lift arm pins are set too narrow for the quick attach by several inches on each side.
I’m looking, so far unsuccessfully, for a CAT 0 to CAT 1 quick-attach conversion. In the meantime I’m swapping out the implements much more slowly than I’d like to.
So, if a QA blade and rake for the TX25 are important to you, you’ll want to look at something from Dirt Dog, etc.
/ Online Ordering and the First 10 Hours #6
@isleview, Would a longer cat1 pin work for the QH issue? Or maybe one with longer threads and a spacer block. Just a couple suggestions to look at. Sounds like your new "toy" is working well for you. Also great that ST is stepping up to the plate with their endeavor! Let's hope that continues for you and others that will purchase their products. We'll done Summit!
/ Online Ordering and the First 10 Hours #7
Was the OP able to see one in person and test drive it before buying?
@isleview, Would a longer cat1 pin work for the QH issue? Or maybe one with longer threads and a spacer block. Just a couple suggestions to look at. Sounds like your new "toy" is working well for you. Also great that ST is stepping up to the plate with their endeavor! Let's hope that continues for you and others that will purchase their products. Well done Summit!
Hi, @Topzide. Great suggestion.
I was unable to find a long enough draw/lift pin locally. I did find a discontinued adjustable SpeeCo “extra long” pin, S07021900, at O’Reilly with a claimed 6.25 inches overall length.
The problem is, the same part number on SpeeCo’s site states that it’s 5.00 inches overall, which isn’t long enough to solve the problem. I‘ve been holding off thinking the correct data was on SpeeCo’s side. But I caved this afternoon and ordered two sets.
We’ll see if they’re actually in stock and what actually shows up in a few days. I’ll report back.
The “extra long” draw/lift pins arrived. They’re ~6.5 inches overall. They have two nuts not one, of course, which was key in this case.
Both the Summit LRX60 and RBX60 with these wider pins only overlap the SpeeCo QH by ~0.25 inch with the top link centered (see photos). That’s not enough, obviously.
So, I’ll keep looking for a better option.
(In the meantime, I‘ll try some bushings or, better, have a brace fashioned to address that gap. Maybe a simple U-shape drilled for the pins will strengthen the connection and take up some of that gap, which is substantial.
Had I done thorough research, I would have gone with a true Cat1 blade and rake route. In fact, King Kutter, the manufacturer, offers true Cat1 options of both...alas, they’re not available in Harvest (aka, Summit) Green ;-)
/ Online Ordering and the First 10 Hours #10
Put a piece of pipe over pins to close the gap.
HAMM H11 PADFOOT ROLLER (A58214)
HAMM H11 PADFOOT...
2019 MACK PINNACLE (A55745)
2019 MACK PINNACLE...
2022 THOMPSON PUMP 6X6S1 PORTABLE PUMP (A59823)
2022 THOMPSON PUMP...
2015 JOHN DEERE 35G EXCAVATOR (A52707)
2015 JOHN DEERE...
2018 CATERPILLAR TL642D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
SEMI AUTOMATIC QUICK CHANGE FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
Ad bottom of page
