Too many tiller options
/ Too many tiller options #1
Atypical_decorum
NYC
Ultra-Wide B7500 & looking for a 100hp
Hey all. I'm in the middle of purchasing a smaller tractor and need a tiller for it. The tractor is a New Holland TN75S with 16 speed ranges and MFWD. The tires are set to their widest at about 96" and I'd like to see if there's something you know I'd be able to run or if I MUST set my tires more narrow.
I'd love to get a reverse tine tiller. From my research it looks like I might have to get something smaller, then have a welder offset it to cover 1 tire track and just work like that.
What do you think?
/ Too many tiller options #2
How many acres do you need to cultivate?
Will you grow a market crop or is this for food plots on hunting land?
Is your land flat, sloped or mixed? How much of each category?
Describe your soil.
How many acres do you need to cultivate? The main spot is about 1 acre on a hill Slope - about 15 to 18 degrees. The second area is about 1/2 acre on a slip about 20 degrees.
Will you grow a market crop or is this for food plots on hunting land? This is for my families food. Tomatoes, broccoli, cucumbers, herbs, beans, etc etc.
Is your land flat, sloped or mixed? How much of each category? It's nearly all sloped. At the steepest you can't walk and the flatest is about 10 degrees. There's about 7 acres of flat area in the hollar, but it's lined by 75ft trees and there's no sun but 3hrs a day. I'm planning on getting new wheels made for the tractor for some wide and shorter tires to lower my CG and add room for ballast.
Describe your soil. It's mostly clay and scattered flat rocks I'll need to take out as I find them. The soil will have to be amended. There's spots of good soil but not much. I'm adding perlite and vermiculite amongst other things. My last garden was about half the size and we didn't need to shop for much during the year and supplied our neighbors too. All year eating is the goal of this garden.
/ Too many tiller options #4
New Holland TN75​
New Holland TN75 tractor photo
1999 - 2003
TN Series
Utility tractor
Production
Manufacturer:New Holland
Type:Utility tractor
Factory:Jesi, Italy
TN75S:Super Steer
New Holland TN75 Weight
SuperSteer ROPS Shipping:5370 lbs
2435 kg
New Holland TN75 Power
Engine (gross):75 hp
55.9 kW
Engine (net):72 hp
53.7 kW
PTO (claimed):62 hp
46.2 kW
PTO (tested):63.9 hp
47.7 kW
/ Too many tiller options #5
What do you think?
I would consider a little smaller tiller like in the link below and offset the tiller by adjusting the sway chains on your tractor 3 point to the right or left.
/ Too many tiller options #7
For 1-1/2 acres of sloped land, I would be concerned with potential rain erosion. Has erosion been a factor in the past?
Consider some form of Conservation Plow:
With extensions, available in 96" width:
8' + 10' widths:
YouTube:
Up to 96" Width:
With extensions available in 96" width:
There's been no erosion. But I can also put swales in if needed.
8' + 10' widths:
96" Width:
How would thaat do in fluffing the soil for my additives?
/ Too many tiller options #10
A Field Cultivator without a rear basket does not fluff soil at all. Example: Dirt Dog APP. Fissures allow rain to carry nutrients down, with decreasing amounts carried down at over 6" depth.
A Field Cultivator with a rear basket, like the Perfecta, will fluff your soil a little. Look at output shown during various videos.
Conservation plow output is heavy enough that neither wind nor rain will carry away nutrients nor seeds. Good on moderate slopes.
These implements are for SECONDARY TILLAGE.
/ Too many tiller options #11
Four (4) foot to Forty (40) foot width Tiller Options:
Several of the videos looked like it was tilled with the amount of fluffiness shown. I'm guessing the perfecta wouldnt accomplish that in my clay based soil?
I'm open to any option really, as long as I can get my additives in it make hills.
/ Too many tiller options #13
I have and use a 72” 9 shank version of that plow. It deep penetrates and aerates the soil but doesn’t make a fluffy planting bed. I follow up with a tiller after the deep soil plowing. I have a clay loam soil type.
/ Too many tiller options #14
Describe your soil.
It's mostly clay and scattered flat rocks.
A spring-protected All Purpose Plow like the Dirt Dog brand or very, very similar Bush Hog brand APP will penetrate and fissure optimally moist soil 10" - 12" deep anywhere a Roto-tiller will mix the same optimally moist soil 5" deep. However, these relatively light, spring-protected conservation plows only come in max 85" width, which would be a no more than a moderate pull for your TN75S. (An "L" shape implement frame has only so much torsion resistance.)
While designed for SECONDARY tillage, I have pulled the Dirt Dog APP through long established Bahia pasture grass with 7" to 9" roots when the soil below was optimally moist. The purpose was deep aeration of the pasture. Heavy sod growing on rock free sandy-loam in Florida.
Did you read the long Dirt Dog review LINK in Post #7?
Unprotected S-tine Field Cultivators are generally much less robust than APPs with spring protection.
However, Unverferth, maker of the Perfecta, is a full-on implement producer for the Big Ag market. The Perfecta has a strong box frame. The Perfecta has shanks (Models 10-12-14) available in three degrees of robustness. Others do not. I suggest you call Unverferth Customer Service and discuss your soil directly with them. Discuss what width Perfecta your TN75S can pull with each of three tines of varying robustness.
Unverferth manufactures Perfectas for 600-horsepower tractors.
Did you watch all the YouTube LINKS to Perfecta videos?
Your next heavier option is a spring-protected Chisel Plow. Buckeye Tractor produces four Chisel Plow variants rated for 75-horsepower tractors.
/ Too many tiller options #15
Describe your soil.
A spring-protected All Purpose Plow like the Dirt Dog brand or very, very similar Bush Hog brand APP will penetrate and fissure soil anywhere a Roto-tiller will churn the same soil. However, these relatively light, spring-protected conservation plows only come in 85" width, max, which would be a moderate pull for your TN75S.
Did you read the Dirt Dog review LINK in Post #7?
The unprotected S-tine Field Cultivators are generally much less robust than APPs with spring protection.
However, Unverferth, maker of the Perfecta, is a full-on implement producer for the Big Ag market. The Perfecta has shanks available in three degrees of robustness. Others do not. I suggest you call Unverferth Customer Service and discuss your soil directly with them. Discuss what width Perfecta your TN75S can pull with each of three tines of varying robustness.
Your next heavier option is a heavy, spring-protected Chisel Plow, but your TN75S does not have enough weight/power to pull any but the smallest Chisel Plow through clay based soil with rocks. Buckeye Tractor produces four Chisel Plow variants rated for 75-horsepower tractors.
Details in the green tab labeled Price List.
The Fred Cain 8’ unit would work well with the OP’s tractor (sold by everything implements). I have the Fred Cain plow and pull the 7’ 9 shank model easily at maximum depth with my 60hp tractor in my heavy soil.
/ Too many tiller options #16
Fred Cain, Dirt Dog and Bush Hog APPs are identical except for paint colors.
Everything Attachments no longer markets the Fred Cain proprietary brand. Sad.
/ Too many tiller options #19
What do you think?
I would not get a reverse rotation tiller. It throws the rocks toward the tractor. I have a 72" Bush Hog tiller that I really like. Forward rotation.
/ Too many tiller options #20
What do you think?
90" to 99" Tractor Rotary Tillers - Rototillers www.durattach.com
2022 John Deere X730 Lawn Mower (A63116)
2022 John Deere...
2015 Ford Transit 250 Cargo Van (A61573)
2015 Ford Transit...
1992 21ft Four Winns 205 Sundowner Boat w/ 21 Ft. Boat Trailer (A61574)
1992 21ft Four...
Caterpillar 988G Wheel Loader Service Manuals Vol. 1 and Vol. 2 (A63117)
Caterpillar 988G...
48in Forks and Frame Skid Steer Attachment (A61572)
48in Forks and...
2025 78in. Hydraulic Dual Cylinder Rock Grapple Skid Steer Attachment (A61572)
2025 78in...
