AZ ranch
/ AZ ranch #1,461
Yes, I used treated wood for the fascia on the lower side.
I will also be putting a gutter on there to collect rain water.
I just bought some treated southern pine for an outdoor project. The lumber yard guys say to let it dry for a week on a flat surface in the sun, so that it will take stain or paint better. I left it out from Friday till Wednesday, 6 full days in the full sun. I left it on my 16' trailer out in the middle of the field and turned it every day. People will also tell you to get the green copper sulfate or whatever it is treated with, off before painting.
/ AZ ranch
I think if I put my new boards out in the sun like that, that they would be pretzels in a couple days. 😄
im not plannings on painting that board. Maybe a coat of varathane.
/ AZ ranch #1,463
I put some clear solvent based waterproofer on 2 of the boards, and I put some polyurethane stain on the outer board that shows. It came out a lot darker than I wanted, but hey, it's all I had "in stock".
The boards just soaked up both products.
/ AZ ranch
I finished the shingles!
I was too tired to go take a picture, as I split wood all morning.
I’ll send a pic tomorrow.
/ AZ ranch #1,466
It’s not possible to get the treatment off the boards. The wood treatment is done under pressure, so it’s deep in the wood. And that’s a good thing to ****** rot and insects.
/ AZ ranch #1,468
Prevent is now a censored word?
/ AZ ranch
I’m still going to cover those green rakes.
/ AZ ranch
I finished almost all the outside. I have landscape fabric under the gravel. I like the exhaust fan, as it’s temperature controlled.
I started filling up one of the beds inside today.
/ AZ ranch
Where did you purchase the fans?
Is the louver operated manually?
Building a similiar greenhouse, except it is only 3 feet below grade on two sides.
The 12 inch fan I got from HD. The louvers open automatically when the fan comes on. I need to make some smaller ones for the little fan. I don’t remember where I got it. It several years old and has a switch based on humidity while the big fan is set to temperature.
2019 JCB 457 (A60462)
2007 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A58214)
2007 INTERNATIONAL...
Allmand Maxi-Lite Sho-HD S/A Towable Light Tower (A60352)
Allmand Maxi-Lite...
2019 CATERPILLAR 326FL EXCAVATOR (A62129)
2019 CATERPILLAR...
2018 Jayco JayFlight 264BH (A62613)
2018 Jayco...
2006 Dodge Ram 1500 Pickup Truck (A61568)
2006 Dodge Ram...
