Is DEF that bad?
/ Is DEF that bad? #1
Atypical_decorum
NYC
Ultra-Wide B7500 & looking for a 100hp
Is DEF/DPF that bad?
Things I've heard:
1. If you don't run wide open long enough the back pressure from the soot buildup will damage engine.
2. DEF damages stuff when it leaks.
3. Engine stays choked for power.
4. All the crud is burned out eventually making the system essentially useless... Like poopin in a bag and saying you're not pooping, then dumping it later.
5. Prone to failure.
As most of us have, I'm considering a tractor with DEF. But I'm nervous about it because the EPA doesn't usually change things for the better or care about the end product at all.
/ Is DEF that bad? #2
Sounds like you are mentioning DEF and DPF. One reason I chose a mechanical injected tractor, the DPF is an accessory, and not integrated into the operation of the engine. I think most DPF issues are user error however.
/ Is DEF that bad? #3
DEF and DPF both add failure points. DPF does burn an engine faster if it works properly, if it works improperly it destroys the engine quickly or set your vehicle on fire depending. DEF adds a lot of complexity, in many ways it stops user maintenance of the engine because of the complexity of the system. If you can avoid it great, but that's getting harder and harder to do as older nice tractors become harder to find.
/ Is DEF that bad? #4
Wikipedia
https://en.wikipedia.org › wiki › Diesel_exhaust_fluid
def fluid from en.wikipedia.org
Diesel exhaust fluid (DEF; also known as AUS 32 and marketed as AdBlue) is a liquid used to reduce the amount of air pollution created by a diesel engine generating 75-horsepower or more.
DIESEL PARTICULATE FILTERS
Stricter Tier IV off-road diesel engine emission reduction standards phased in dealer tractor inventory during 2009 - 2012, impacting tractor prices.
Tier IV emission standards require tractor manufacturers to add or revise pollution reduction technology on new tractors generating over 19 kW power = 25.4794 horsepower.
A Diesel Particulate Filter (DPF) is used by the majority of tractor manufactures for emissions control on OVER 24.4794 horsepower tractors.
Tier IV technology complicates the engine and exhaust package and is a significant cost factor. The pollutants emitted by a TierIV technology tractor are about 1% of the pollutants emitted by a pre-Tier IV tractor.
Diesel Particulate Filter (DPF) captures exhaust particulates (soot) in a ceramic matrix. When tractor engine runs sufficiently hot, accumulated particulates burn off periodically without operator intervention. If engine is not run continuously hot long enough to burn off particulates, diesel soot accumulates in the matrix. Once heavy soot accumulates in DPF the tractor forces soot clearance with the tractor parked and throttle open to about 2,200 rpm for about sixteen minutes, which makes the DPF REALLY HOT to burn off all accumulated soot. Burning off accumulated soot, either during operation or parked is called REGENERATION.
/ Is DEF that bad? #5
Regeneration is an infrequent DPF event with my Kubota three cylinder, 37-horsepower engine. Generally once every sixty engine hours. (Very consistent in Florida due to warm weather.)
60 hours X 60 minutes = 3,600 minutes.
16 regeneration minutes /3,600 = .00444 = 4/10s of 1% of engine time is consumed during parked regeneration.
Fuel cost for sixteen minute parked regeneration @ 2,200 rpm ~~$1.00.
Forty percent of my regenerations occur during operation, sixty percent parked.
The average residential tractor operates eighty engine hours per year, according to industry surveys.
3,000 hours DPF Life / 80 hours = 37.5 years of residential use prior to DPF replacement.
Diesel Particulate Filter supersedes tractor muffler.
At some point in time DPF needs to be replaced.
At some point in time tractors with mufflers need the muffler replaced.
/ Is DEF that bad? #6
Things I've heard:
What tractor are you considering? What size?
/ Is DEF that bad? #9
/ Is DEF that bad? #10
I've had a 100hp tractor with a DPF. I run hard, so the DPF did it's job, and in 10 years, I never had to replace the DPF. I didn't just poot around doing short chores on that tractor.
Now, fast forward 10 years and I traded the previous 100hp tractor in on a new 120hp tractor with the same engine, but it uses DEF and has no DPF.
Tractor runs great, no loss of power, no extra fuel burned when the DPF comes on, because it doesn't have one. Only uses DEF when it needs it, according to how I use the tractor.
Funny thing is, my new 120hp tractor uses LESS fuel in a day's time than my previous 100hp did. I attribute that to not having a DPF.
Given the choice, I'd pick a tractor with DEF over a tractor with a DPF.
Was operating that older tractor after dark once when the DPF came on, and the whole exhaust pipe was so hot when it was regening, it was glowing red. That has to be hard on the entire exhaust system.
Some DEF systems had sensors corrode and go bad, forcing the equipment into "limp" mode until the sensor was replaced. This caused a huge shortage of sensors world wide for many manufacturers. Nothing wrong with the system or the DEF in most cases. Just the bad sensors that would corrode and throw false readings. But it appears the later sensors are much less corrosive, and are standing pretty steady now.
/ Is DEF that bad? #11
I'm looking at a JD 5085EL
One small word here. If you are looking at an "E" series tractor, bear in mind that the "E" series is their "Economy" series, made to compete with lesser priced imports and other economy priced tractors. They just aren't as rugged as the more premium tractor models.
JD, Case, New Holland and others make an "Economy" series of tractors.
Personally, for how I use a tractor, the "economy" tractors are just not a good fit. Not that I abuse my tractors, but I spend lots of hours in them using them for what tractors should be used for. I'd tear the guts out of an "economy" tractor, just doing what I do. Those "E" tractors are for people who don't use a tractor to make a living, but more for weekend light to medium use, because they are built accordingly.
/ Is DEF that bad? #12
One known problem with DEF fluid is that it freezes so in colder climates it can be problem if the pump back system does not pump the lines empty when shutting down. If not pumped out the lines freeze, swell and break. DEF fluid is corrosive so when thaws it raises heck with anything it touches. Fendt has had lots of DEF problems, I have heard of a few Deeres having problems during fall and winter use in this area. Not sure on sizes and how operated though.
/ Is DEF that bad? #13
I’ve not had any problems out of my 40 and 74 hp machines with DPFs but I’ve seen pretty garbage reliability out of DEF machines.
/ Is DEF that bad?
I thought the E stood for the economy mode the PTO was able to use. Not a different line of tractor. Is that correct/incorrect?
Edit. I'm incorrect. E from M is the difference of a chassis and a lot of other stuff. Looks like I'm on the search again.
/ Is DEF that bad? #15
No doubt there’s some issues with DPF & DEF. Especially the early models.
However, I have found a lot of it is urban lore or just flat out bullchit started by guys with older trucks that don’t even one a DEF or DPF truck.
Then some guys try to modify or remove the equipment, void their warranties and cry they have a truck the dealer won’t fix.
/ Is DEF that bad? #16
Some do work well, but at some point you are gunna have an issue. That's a guarantee. Too many sensors and electronics.
And all it takes is one bad dealer tech to make your world a nightmare.
Not a tractor but I ran a DD15 that was the most horrible experience I ever had. It was at dealer at least once a week. Chasing issues over and over. And in the end the biggest issue was the technicians sticking their test probes into wire harnesses to test for power. Well guess what happened there? Salt got in those little holes and rotted the harness out, unbeknownst to anyone.
So you may have a tractor that works flawless, but just be sure to budget money for either failed sensors or for when the time comes you have to pay to clean or replace DPF's, SCR injectors, etc.
/ Is DEF that bad? #17
I’d say it’s a pretty safe bet that the DPF equipped diesel in my Kubota won’t put in the 50 years of reliability the 3306 in my dozer has.
/ Is DEF that bad? #18
And it won’t pump tons of soot and other pollutants into the atmosphere as well as the 3306 in your dozer, either.
Its also noteworthy that a DPF is an exhaust after treatment system that is repairable and replaceable.
Given the choice, I’d rather not have one, too. However, the world of diesels changed over a decade ago and DPF or DEF systems are as common on a diesel engine as an alternator.
/ Is DEF that bad? #19
I’m pretty sure the 3306 isn’t killing the environment. It actually runs pretty clean compared to a lot of old diesel. If it actually mattered that much they should have started with trains and boats and planes.
2011 BRENNER TANK TRAILER (A67714)
2011 BRENNER TANK...
Ford 340B Loader Attachment
Ford 340B Loader...
2015 PETERBILT 389 (A67714)
2015 PETERBILT 389...
2019 Peterbilt 520 T/A EZ-Pack 40Yd Front Loader Garbage Truck (A66736)
2019 Peterbilt 520...
2018 Toyota Tacoma 4x4 Ext. Cab Pickup Truck (A66736)
2018 Toyota Tacoma...
2007 INTERNATIONAL MAO25 SERVICE TRUCK (A66091)
2007 INTERNATIONAL...
